Help after reboot a server users were gone !!!
XXXENIGMAXXX
After reboot a server users were gone. On the right the quantity of users is written but in the menu to see users they are not displayed. Though users like normally I work. Also at users in the menu problems Cron are not displayed. Though actually in/usr/local/directadmin/data/users/user/crontab.conf they are. This updating PHP has been made of the last that up to 5 versions on a server. Operational system FreeBSD 6.2
I apologize for my bad English and I hope for the prompt help!
chatwizrd
Type as root in ssh:
echo "action=cache&value=showallusers" >> /usr/local/directadmin/data/task.queue
/usr/local/directadmin/dataskq d
XXXENIGMAXXX
# echo "action=cache&value=showallusers" >> /usr/local/directadmin/data/task.queue
# /usr/local/directadmin/dataskq d
In debug mode
Debug set to level 10
root priv set: uid:0 gid:0 euid:0 egid:0
pidfile written
staring queue
done queue
Has executed. But users and have not appeared.
nobaloney
California
We had a similar problem once with a full partition that kept certain files from being written to.
DirectAdmin Support
Administrator
Staff member
Check for this file:
/usr/local/directadmin/data/admin/show_all_users.cache
That's the file that is being referred to.
If it's empty, you can always delete it and DA will try to generate the data on the fly (which can get slow if you have a lot of users).
Past that, after deleting it, then run the cache command again (as mentioned above) to recreate this file.
