How to not manage DNS for a domain ?
bokan
I want to host a website using directadmin but no mail and not manage any DNS feature for this domain.
I know I can uncheck "Use this server to handle my emails." and configure alternative MX.
But those mx are subject to change and I don"t want this to cause a problem later. For example mails from other users or hosted website sent by smtp through the same server will not reach destination.
Is it possible ?
Please clarify your inquiry. I'm not quite sure what you are asking about. You can disable DNS editing for users, check their packages at a reseller level.
Hello, thanks for answering.
I just want to host a website on a domain, but not having any DNS service for this domain on this server.
If the php script want to send a mail, or connect to a webservice with the same base domain (webservice.samedomain.com) it should query external DNS for resolving this domain.
I fear there is no way to do that in Directadmin.
It is possible to completely disable Named http://help.directadmin.com/item.php?id=25, but not for some domain.
