httpd configuration: custom pre/post not shown
flexjoly
Apeldoorn, Netherlands
change httpd configuration with custom-files
At first our compliments on the very nice skin and the nice features!
Only the httpd-config is a bit less intuitive.
It is not easy to see which custom (1-4) you are editing currently.
The token-popup is not on the edit-page (/admin/custom-httpd/<domain>/nginx/customize/custom1).
And the custom- pre/post files are not shown in the edit-page any more.
And the custom-files in the token-popup are almost unreadable because it does not wrap the text but shows many '\n' and '\r'.
We use the .pre and .post custom files to preset and use tokens.
Example:
custom.pre
|?DEBUG_LOG=#change to 1 to get nginx debug info in the error-log|
|?DEBUG_LOG=0|
custom.post
|*if DEBUG_LOG="1"|
error_log /var/log/nginx/domains/|DOMAIN|.error.log debug;
|*endif|
Now first I have to search in the all-tokens popup in the previous screen(!) where I have to set my debug-log parameter to 1.
I would help a lot if:
- the tokens-popup is visible in the edit-page
- the pre-/post- custom-files are shown in the edit-page (with good line-wrapping)
- the current custom-part is better highlighted
I hope you understand what I mean, because I find it hard to explain :confused::rolleyes:
Thanks in advance,
Lydia
smtalk
Administrator
Staff member
LT, EU
"View all available tokens" has been added. "- the current custom-part is better highlighted" - may you send us a screenshot? We'll be looking into pre-/post- custom file request soon. Thank you!
smtalk
Administrator
Staff member
LT, EU
If you have some suggestions for the current version - yes :) If everything works as expected - no.
