httpd-lsrecaptcha.conf settings not being applied
chwba
I have changed /usr/local/lsws/conf/httpd-lsrecaptcha.conf to the following content to activate reCAPTCHA. After I have restarted OLS gracefully.
lsrecaptcha  {
  enabled                      1
  siteKey                 6LfmisYUAAAAAOgLBe-xDvWPWgQooG3GLHCwVz
  secretKey               6LfmisYUAAAAAP9TRx6uOGrwZNuIoTQ_xAns
  type                            2
  maxTries                    3
  allowedRobotHits       3
  botWhiteList  {
  google.com
  regConnLimit            15000
  sslConnLimit            10000
Yet the GUI does not display the changes as per the below screenshot, what am I missing?
chwba
Figured out there is a filed called httpd_config.conf where all the config files are being "included", obviously httpd-lsrecaptcha.conf is commented out by default..
jayw1
USA
Thanks, I'm still trying to figure out where everything is as well. I'm used to the GUI.
Did you find how to create realms yet? I want to htpasswd protect directories and files.
smtalk
Administrator
Staff member
LT, EU
CB 2.0 rev. 2343 has it uncommented now :) They had issues with 1.5 at that time, and we reverted to 1.4 and commented line out (it was a leftover). Thank you for the report!
