pppplus
- Dec 19, 2008
Hi
From yesterday, impossible to connect via FTP :
On filezilla, I've :
Nothing change from... a very long time.
No problem to connect with ssh, no problem in websites.
Problem to connect with FTP is on all accounts.
I've created a new one to test, I've changed an existing password to test...
I've found nothing interesting in logs.
I've read this : http://help.directadmin.com/item.php?id=249
=> nothing in /etc/proftpd.vhosts.conf
I've tried that :
Status: Resolving address of xxxx.fr
Status: Connecting to 12.34.56.57:21...
Status: Connection established, waiting for welcome message...
Status: Initializing TLS...
Status: Verifying certificate...
Status: TLS connection established.
Status: Connected
Status: Retrieving directory listing...
Command: PWD
Response: 257 "/" is the current directory
Command: TYPE I
Response: 200 Type set to I
Command: PASV
Response: 227 Entering Passive Mode (12,34,56,57,139,186).
Command: MLSD
Error: Connection timed out
Error: Failed to retrieve directory listing
I've tried that :
/etc/init.d/proftpd stop
proftpd -n -d 20
2015-01-25 08:03:37,838 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): RELINQUISH PRIVS at mod_auth.c:1493
2015-01-25 08:03:37,838 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): USER PRIVS 501 at mod_auth.c:796
2015-01-25 08:03:37,838 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): retrieved UID 501 for user 'admin'
2015-01-25 08:03:37,838 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): RELINQUISH PRIVS at mod_auth.c:799
2015-01-25 08:03:37,838 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): set TZ environment variable to 'CET'
2015-01-25 08:03:37,838 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): Preparing to chroot to directory '/home/admin'
2015-01-25 08:03:37,838 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): ROOT PRIVS at auth.c:1424
2015-01-25 08:03:37,838 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): RELINQUISH PRIVS at auth.c:1427
2015-01-25 08:03:37,838 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): Environment successfully chroot()ed
2015-01-25 08:03:37,838 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): ROOT PRIVS at mod_auth.c:1542
2015-01-25 08:03:37,838 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): SETUP PRIVS at mod_auth.c:1564
2015-01-25 08:03:37,838 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): in dir_check_full(): path = '/', fullpath = '/home/admin/'.
2015-01-25 08:03:37,838 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): dispatching POST_CMD command 'PASS (hidden)' to mod_cap
2015-01-25 08:03:37,838 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): mod_cap/1.1: uid = 501, euid = 501, gid = 502, egid = 502
2015-01-25 08:03:37,838 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): mod_cap/1.1: capabilities '= cap_chown,cap_setgid,cap_setuid,cap_net_bind_service+ep'
2015-01-25 08:03:37,838 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): dispatching POST_CMD command 'PASS (hidden)' to mod_tls
2015-01-25 08:03:37,838 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): dispatching POST_CMD command 'PASS (hidden)' to mod_ratio
2015-01-25 08:03:37,838 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): dispatching POST_CMD command 'PASS (hidden)' to mod_delay
2015-01-25 08:03:37,838 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): dispatching POST_CMD command 'PASS (hidden)' to mod_log
2015-01-25 08:03:37,838 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): dispatching POST_CMD command 'PASS (hidden)' to mod_ls
2015-01-25 08:03:37,838 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): dispatching POST_CMD command 'PASS (hidden)' to mod_auth
2015-01-25 08:03:37,838 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): unable to display DisplayLogin file 'welcome.msg': No such file or directory
2015-01-25 08:03:37,838 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): dispatching POST_CMD command 'PASS (hidden)' to mod_rlimit
2015-01-25 08:03:37,838 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): dispatching POST_CMD command 'PASS (hidden)' to mod_xfer
2015-01-25 08:03:37,838 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): dispatching POST_CMD command 'PASS (hidden)' to mod_core
2015-01-25 08:03:37,838 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): dispatching LOG_CMD command 'PASS (hidden)' to mod_log
2015-01-25 08:03:37,838 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): dispatching LOG_CMD command 'PASS (hidden)' to mod_readme
2015-01-25 08:03:37,838 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): dispatching LOG_CMD command 'PASS (hidden)' to mod_ratio
2015-01-25 08:03:37,838 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): dispatching LOG_CMD command 'PASS (hidden)' to mod_auth
2015-01-25 08:03:37,838 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): USER admin: Login successful.
2015-01-25 08:03:37,886 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): dispatching PRE_CMD command 'OPTS UTF8 ON' to mod_tls
2015-01-25 08:03:37,886 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): dispatching PRE_CMD command 'OPTS UTF8 ON' to mod_core
2015-01-25 08:03:37,886 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): dispatching CMD command 'OPTS UTF8 ON' to mod_core
2015-01-25 08:03:37,886 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): in dir_check_full(): path = '/', fullpath = '/home/admin/'.
2015-01-25 08:03:37,886 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): dispatching PRE_CMD command 'OPTS_UTF8 ON' to mod_tls
2015-01-25 08:03:37,886 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): dispatching PRE_CMD command 'OPTS_UTF8 ON' to mod_core
2015-01-25 08:03:37,886 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): dispatching CMD command 'OPTS_UTF8 ON' to mod_lang
2015-01-25 08:03:37,886 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): mod_lang/1.0: Handling OPTS UTF8 ON (current encoding is 'UTF-8')
2015-01-25 08:03:37,887 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): dispatching LOG_CMD command 'OPTS_UTF8 ON' to mod_log
2015-01-25 08:03:37,887 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): dispatching LOG_CMD command 'OPTS UTF8 ON' to mod_log
2015-01-25 08:03:37,945 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): dispatching PRE_CMD command 'PBSZ 0' to mod_tls
2015-01-25 08:03:37,945 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): dispatching PRE_CMD command 'PBSZ 0' to mod_core
2015-01-25 08:03:37,945 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): dispatching CMD command 'PBSZ 0' to mod_tls
2015-01-25 08:03:37,945 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): dispatching LOG_CMD command 'PBSZ 0' to mod_log
2015-01-25 08:03:37,988 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): dispatching PRE_CMD command 'PROT P' to mod_tls
2015-01-25 08:03:37,988 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): dispatching PRE_CMD command 'PROT P' to mod_core
2015-01-25 08:03:37,988 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): dispatching CMD command 'PROT P' to mod_tls
2015-01-25 08:03:37,988 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): in dir_check_full(): path = '/', fullpath = '/home/admin/'.
2015-01-25 08:03:37,988 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): dispatching POST_CMD command 'PROT P' to mod_xfer
2015-01-25 08:03:37,988 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): dispatching LOG_CMD command 'PROT P' to mod_log
2015-01-25 08:03:38,035 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): dispatching PRE_CMD command 'CWD /domains/xxxx.fr/public_html' to mod_tls
2015-01-25 08:03:38,035 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): dispatching PRE_CMD command 'CWD /domains/xxxx.fr/public_html' to mod_core
2015-01-25 08:03:38,035 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): dispatching PRE_CMD command 'CWD /domains/xxxx.fr/public_html' to mod_ratio
2015-01-25 08:03:38,035 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): dispatching CMD command 'CWD /domains/xxxx.fr/public_html' to mod_ratio
2015-01-25 08:03:38,035 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): dispatching CMD command 'CWD /domains/xxxx.fr/public_html' to mod_core
2015-01-25 08:03:38,035 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): in dir_check_full(): path = '/domains/xxxx.fr/public_html', fullpath = '/home/admin/domains/xxxx.fr/public_html'.
2015-01-25 08:03:38,035 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): dispatching POST_CMD command 'CWD /domains/xxxx.fr/public_html' to mod_readme
2015-01-25 08:03:38,035 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): dispatching LOG_CMD command 'CWD /domains/xxxx.fr/public_html' to mod_log
2015-01-25 08:03:38,081 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): dispatching PRE_CMD command 'TYPE I' to mod_tls
2015-01-25 08:03:38,081 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): dispatching PRE_CMD command 'TYPE I' to mod_core
2015-01-25 08:03:38,081 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): dispatching CMD command 'TYPE I' to mod_xfer
2015-01-25 08:03:38,081 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): dispatching LOG_CMD command 'TYPE I' to mod_log
2015-01-25 08:03:38,125 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): dispatching PRE_CMD command 'PASV' to mod_tls
2015-01-25 08:03:38,125 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): dispatching PRE_CMD command 'PASV' to mod_core
2015-01-25 08:03:38,125 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): dispatching CMD command 'PASV' to mod_core
2015-01-25 08:03:38,125 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): in dir_check_full(): path = '/domains/xxxx.fr/public_html', fullpath = '/home/admin/domains/xxxx.fr/public_html'.
2015-01-25 08:03:38,125 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): Entering Passive Mode (12,34,56,57,136,233).
2015-01-25 08:03:38,125 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): dispatching LOG_CMD command 'PASV' to mod_log
2015-01-25 08:03:38,170 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): dispatching PRE_CMD command 'MLSD' to mod_tls
2015-01-25 08:03:38,170 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): dispatching PRE_CMD command 'MLSD' to mod_core
2015-01-25 08:03:38,170 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): dispatching CMD command 'MLSD' to mod_facts
2015-01-25 08:03:38,170 ns1crea.xxxx.fr proftpd[26529] 12.34.56.57 (81.48.61.116[81.48.61.116]): in dir_check_full(): path = '/domains/xxxx.fr/public_html', fullpath = '/home/admin/domains/xxxx.fr/public_html'.
2015-01-25 08:03:58,172 ns1crea.xxxx.fr proftpd[26523] 12.34.56.57: scrubbing scoreboard
2015-01-25 08:03:58,172 ns1crea.xxxx.fr proftpd[26523] 12.34.56.57: ROOT PRIVS at scoreboard.c:1497
2015-01-25 08:03:58,172 ns1crea.xxxx.fr proftpd[26523] 12.34.56.57: RELINQUISH PRIVS at scoreboard.c:1500
2015-01-25 08:03:58,172 ns1crea.xxxx.fr proftpd[26523] 12.34.56.57: ROOT PRIVS at scoreboard.c:1531
2015-01-25 08:03:58,172 ns1crea.xxxx.fr proftpd[26523] 12.34.56.57: RELINQUISH PRIVS at scoreboard.c:1637
2015-01-25 08:03:58,172 ns1crea.xxxx.fr proftpd[26523] 12.34.56.57: finished scrubbing scoreboard
