astra:/home/admin# strace -fF exim -Mc 1M5t8Q-0004W8-Oc
execve("/usr/sbin/exim", ["exim", "-Mc", "1M5t8Q-0004W8-Oc"], [/* 15 vars */]) = 0
uname({sys="Linux", node="astra.techwarepc.com", ...}) = 0
brk(0) = 0x95b3000
brk(0x95d4000) = 0x95d4000
getrlimit(RLIMIT_STACK, {rlim_cur=8192*1024, rlim_max=RLIM_INFINITY}) = 0
setrlimit(RLIMIT_STACK, {rlim_cur=2044*1024, rlim_max=RLIM_INFINITY}) = 0
getpid() = 17799
rt_sigaction(SIGRTMIN, {0x8254430, [], SA_RESTORER, 0x82681c8}, NULL, 8) = 0
rt_sigaction(SIGRT_1, {0x8254470, [], SA_RESTORER, 0x82681c8}, NULL, 8) = 0
rt_sigaction(SIGRT_2, {0x8254530, [], SA_RESTORER, 0x82681c8}, NULL, 8) = 0
rt_sigprocmask(SIG_BLOCK, [RTMIN], NULL, 8) = 0
rt_sigprocmask(SIG_UNBLOCK, [RT_1], NULL, 8) = 0
_sysctl({{CTL_KERN, KERN_VERSION}, 2, 0xbfe7da80, 35, (nil), 0}) = 0
rt_sigaction(SIGALRM, {0x8255a60, [], SA_RESTORER, 0x82681c8}, NULL, 8) = 0
fstat64(2, {st_mode=S_IFCHR|0620, st_rdev=makedev(136, 0), ...}) = 0
getpid() = 17799
rt_sigaction(SIGUSR1, {0x8255a60, [], SA_RESTORER|SA_RESTART, 0x82681c8}, NULL, 8) = 0
rt_sigaction(SIGHUP, {SIG_IGN}, {SIG_DFL}, 8) = 0
rt_sigaction(SIGPIPE, {SIG_IGN}, {SIG_DFL}, 8) = 0
rt_sigaction(SIGCHLD, {SIG_DFL}, NULL, 8) = 0
umask(0) = 022
geteuid32() = 0
getuid32() = 0
getgid32() = 0
setgid32(0) = 0
setuid32(0) = 0
getrlimit(RLIMIT_NOFILE, {rlim_cur=1024, rlim_max=1024}) = 0
getrlimit(RLIMIT_NPROC, {rlim_cur=97*1024, rlim_max=97*1024}) = 0
getgroups32(32, [0]) = 1
setgroups32(0, []) = 0
getegid32() = 0
geteuid32() = 0
geteuid32() = 0
getegid32() = 0
setgid32(0) = 0
setuid32(0) = 0
open("/etc/exim.conf", O_RDONLY|O_LARGEFILE) = 3
fstat64(3, {st_mode=S_IFREG|0755, st_size=36112, ...}) = 0
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0xbfe7d42408330020) = 0xb7f7f000
read(3, "#################################"..., 4096) = 4096
read(3, " #\n# "..., 4096) = 4096
read(3, "7\n# see also check_recipient seco"..., 4096) = 4096
read(3, " runs under the\n# uid of \"nobody\""..., 4096) = 4096
socket(PF_FILE, SOCK_STREAM, 0) = 4
connect(4, {sa_family=AF_FILE, path="/var/run/.nscd_socket"...}, 110) = -1 ENOENT (No such file or directory)
close(4) = 0
open("/etc/nsswitch.conf", O_RDONLY) = 4
fstat64(4, {st_mode=S_IFREG|0644, st_size=475, ...}) = 0
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0xbfe7d2f408330020) = 0xb7f7e000
read(4, "# /etc/nsswitch.conf\n#\n# Example "..., 4096) = 475
read(4, ""..., 4096) = 0
close(4) = 0
munmap(0xb7f7e000, 4096) = 0
open("/etc/ld.so.cache", O_RDONLY) = 4
fstat64(4, {st_mode=S_IFREG|0644, st_size=27934, ...}) = 0
old_mmap(NULL, 27934, PROT_READ, MAP_PRIVATE, 4, 0xbfe7cda408330020) = 0xb7f78000
close(4) = 0
access("/etc/ld.so.nohwcap", F_OK) = -1 ENOENT (No such file or directory)
open("/lib/i686/cmov/libnss_compat.so.2", O_RDONLY) = 4
read(4, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\20\16\0\0004\0\0\0\204"..., 512) = 512
fstat64(4, {st_mode=S_IFREG|0644, st_size=30436, ...}) = 0
old_mmap(NULL, 33356, PROT_READ|PROT_EXEC, MAP_PRIVATE, 4, 0xbfe7ccb408330020) = 0xb7f6f000
old_mmap(0xb7f76000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 4, 0xbfe7ccb408330020) = 0xb7f76000
close(4) = 0
open("/lib/i686/cmov/libnsl.so.1", O_RDONLY) = 4
read(4, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\00001\0\0004\0\0\0\230"..., 512) = 512
fstat64(4, {st_mode=S_IFREG|0644, st_size=87800, ...}) = 0
old_mmap(NULL, 100328, PROT_READ|PROT_EXEC, MAP_PRIVATE, 4, 0xbfe7cacc08330020) = 0xb7f56000
old_mmap(0xb7f6b000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 4, 0xbfe7cacc08330020) = 0xb7f6b000
old_mmap(0xb7f6d000, 6120, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0xbfe7cacc08330020) = 0xb7f6d000
close(4) = 0
open("/lib/i686/cmov/libc.so.6", O_RDONLY) = 4
read(4, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\260e\1\0004\0\0\0\4"..., 512) = 512
fstat64(4, {st_mode=S_IFREG|0755, st_size=1413540, ...}) = 0
set_thread_area({entry_number:-1 -> 6, base_addr:0x95bce20, limit:1048575, seg_32bit:1, contents:0, read_exec_only:0, limit_in_pages:1, seg_not_present:0, useable:1}) = 0
old_mmap(NULL, 1418864, PROT_READ|PROT_EXEC, MAP_PRIVATE, 4, 0xbfe7ca8008330020) = 0xb7dfb000
old_mmap(0xb7f50000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 4, 0xbfe7ca8008330020) = 0xb7f50000
old_mmap(0xb7f53000, 9840, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0xbfe7ca8008330020) = 0xb7f53000
close(4) = 0
open("/lib/i686/cmov/ld-linux.so.2", O_RDONLY) = 4
read(4, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\20\10\0\0004\0\0\0\240"..., 512) = 512
fstat64(4, {st_mode=S_IFREG|0755, st_size=125536, ...}) = 0
old_mmap(NULL, 128632, PROT_READ|PROT_EXEC, MAP_PRIVATE, 4, 0xbfe7c9bc08330020) = 0xb7ddb000
old_mmap(0xb7df9000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 4, 0xbfe7c9bc08330020) = 0xb7df9000
close(4) = 0
munmap(0xb7f78000, 27934) = 0
mmap2(NULL, 1048576, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb7cdb000
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb7f7e000
close(4) = 0
old_mmap(NULL, 27934, PROT_READ, MAP_PRIVATE, 4, 0xbfe7cce408330020) = 0xb7f78000
close(4) = 0
open("/lib/i686/cmov/libnss_nis.so.2", O_RDONLY) = 4
read(4, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\20\31\0\0004\0\0\0\314"..., 512) = 512
fstat64(4, {st_mode=S_IFREG|0644, st_size=38444, ...}) = 0
old_mmap(NULL, 41532, PROT_READ|PROT_EXEC, MAP_PRIVATE, 4, 0xbfe7cbf408330020) = 0xb7cd0000
old_mmap(0xb7cd9000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 4, 0xbfe7cbf408330020) = 0xb7cd9000
close(4) = 0
open("/lib/i686/cmov/libnss_files.so.2", O_RDONLY) = 4
read(4, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\320\30\0\0004\0\0\0\250"..., 512) = 512
fstat64(4, {st_mode=S_IFREG|0644, st_size=42504, ...}) = 0
old_mmap(NULL, 45720, PROT_READ|PROT_EXEC, MAP_PRIVATE, 4, 0xbfe7c9f008330020) = 0xb7cc4000
old_mmap(0xb7cce000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 4, 0xbfe7c9f008330020) = 0xb7cce000
close(4) = 0
open("/etc/passwd", O_RDONLY|O_CLOEXEC) = 4
fcntl64(4, F_GETFD) = 0x1 (flags FD_CLOEXEC)
_llseek(4, 0, [0], SEEK_CUR) = 0
fstat64(4, {st_mode=S_IFREG|0644, st_size=6442, ...}) = 0
mmap2(NULL, 6442, PROT_READ, MAP_SHARED, 4, 0) = 0xb7f7d000
_llseek(4, 6442, [6442], SEEK_SET) = 0
munmap(0xb7f7d000, 6442) = 0
close(4) = 0
close(4) = 0
close(4) = 0
close(4) = 0
close(4) = 0
chdir("/var/spool/exim") = 0
setgid32(8) = 0
read(3, "elist\n# accept if envelope sender"..., 4096) = 4096
read(3, "$sender_address_domain\n \n# # deny"..., 4096) = 4096
read(3, "#########################\n# "..., 4096) = 4096
close(4) = 0
open("/etc/group", O_RDONLY|O_CLOEXEC) = 4
fstat64(4, {st_mode=S_IFREG|0644, st_size=2461, ...}) = 0
mmap2(NULL, 2461, PROT_READ, MAP_SHARED, 4, 0) = 0xb7f7e000
_llseek(4, 2461, [2461], SEEK_SET) = 0
munmap(0xb7f7e000, 2461) = 0
close(4) = 0
close(4) = 0
close(4) = 0
close(4) = 0
close(4) = 0
close(4) = 0
close(4) = 0
read(3, "o passwd entry we have to drop th"..., 4096) = 4096
close(4) = 0
close(4) = 0
close(4) = 0
close(4) = 0
close(4) = 0
close(4) = 0
close(4) = 0
read(3, "turn_path_add\n user = \"${lookup{"..., 4096) = 3344
close(4) = 0
close(4) = 0
read(3, ""..., 4096) = 0
close(3) = 0
munmap(0xb7f7f000, 4096) = 0
getpid() = 17799
time(NULL) = 1242615969
getpid() = 17799
open("/var/spool/exim/input//1M5t8Q-0004W8-Oc-D", O_RDWR|O_APPEND|O_LARGEFILE) = 3
fcntl64(3, F_GETFD) = 0
fcntl64(3, F_SETFD, FD_CLOEXEC) = 0
fcntl64(3, F_SETLK64, {type=F_WRLCK, whence=SEEK_SET, start=0, len=19}, 0xbfe7d5a0) = 0
fstat64(3, {st_mode=S_IFREG|0640, st_size=19, ...}) = 0
open("/var/spool/exim/input//1M5t8Q-0004W8-Oc-H", O_RDONLY|O_LARGEFILE) = 4
fstat64(4, {st_mode=S_IFREG|0640, st_size=678, ...}) = 0
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0xbfe7d41408330020) = 0xb7f7f000
read(4, "1M5t8Q-0004W8-Oc-H\nroot 0 0\n<root"..., 4096) = 678
close(4) = 0
open("/var/spool/exim/input//1M5t8Q-0004W8-Oc-J", O_RDONLY|O_LARGEFILE) = -1 ENOENT (No such file or directory)
open("/var/spool/exim/msglog//1M5t8Q-0004W8-Oc", O_WRONLY|O_CREAT|O_APPEND|O_LARGEFILE, 0640) = 4
fcntl64(4, F_SETFD, FD_CLOEXEC) = 0
fchown32(4, 8, 8) = 0
fchmod(4, 0640) = 0
fcntl64(4, F_GETFL) = 0x8401 (flags O_WRONLY|O_APPEND|O_LARGEFILE)
fstat64(4, {st_mode=S_IFREG|0640, st_size=81, ...}) = 0
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0xbfe7d49c08330020) = 0xb7f7f000
open("/etc/system_filter.exim", O_RDONLY|O_LARGEFILE) = 5
fstat64(5, {st_mode=S_IFREG|0644, st_size=12784, ...}) = 0
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0xbfe7d34c08330020) = 0xb7f7e000
read(5, "# Exim filter\n## Version: 0.17e\n#"..., 12288) = 12288
read(5, "name=/name= \n#\t |begin (?>\\s+) ["..., 4096) = 496
close(5) = 0
open("/usr/lib/gconv/gconv-modules.cache", O_RDONLY) = 5
fstat64(5, {st_mode=S_IFREG|0644, st_size=25700, ...}) = 0
old_mmap(NULL, 25700, PROT_READ, MAP_SHARED, 5, 0xbfe7be1808330020) = 0xb7f78000
close(5) = 0
open("/usr/lib/gconv/CP1254.so", O_RDONLY) = 5
read(5, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0`\3\0\0004\0\0\0\360"..., 512) = 512
fstat64(5, {st_mode=S_IFREG|0644, st_size=9472, ...}) = 0
old_mmap(NULL, 12316, PROT_READ|PROT_EXEC, MAP_PRIVATE, 5, 0xbfe7b73008330020) = 0xb7cc0000
old_mmap(0xb7cc2000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 5, 0xbfe7b73008330020) = 0xb7cc2000
close(5) = 0
open("/usr/lib/gconv/ISO8859-1.so", O_RDONLY) = 5
read(5, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0`\3\0\0004\0\0\0\364"..., 512) = 512
fstat64(5, {st_mode=S_IFREG|0644, st_size=9476, ...}) = 0
old_mmap(NULL, 8220, PROT_READ|PROT_EXEC, MAP_PRIVATE, 5, 0xbfe7b72c08330020) = 0xb7cbd000
old_mmap(0xb7cbe000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 5, 0xbfe7b72c08330020) = 0xb7cbe000
close(5) = 0
--- SIGSEGV (Segmentation fault) @ 0 (0) ---
+++ killed by SIGSEGV +++
