lenny with exim auth problem
metalalin
Romania, Bucharest
Hello there,
I'm a fresh member of this forum and software client, i think this is great, by for the last past days i have been dealing with some kind of a headake configuring exim on my debian lenny distro.
I've try over and over again to google-it (on the exim auth problem) but there where poor topics related to my issue, but one link came in front of all, an archive, and it's about a past problem that a user had with exim in 2006, wich it never find solution.
Here's the link :
http://www.directadmin.com/forum/archive/index.php/t-15697.html
I've even tried to install exim4, and switch the 2 versions of exim.pl i've found, one (older) from templates and the one from direct admin /servicies site.
Same think with exim.conf and exim4.conf.
The single big difference from the other users that shared the same problem is that i cannot send mail neither from squerremail, nor from other mail client ( but i can login and verify, dovecot work fine- i see).
Some logs:
login authenticator failed for localhost ([89.xx.xx.xx]) [127.0.0.1]: 535 Incorrect authentication data (set_id=client)
login authenticator failed for ([10.xx.xx.x]) [86.xx.xx.xx]: 535 Incorrect authentication data (set_id=client)
tcp 0 0 0.0.0.0:10025 0.0.0.0:* LISTEN 27073/exim4
tcp 0 0 0.0.0.0:25 0.0.0.0:* LISTEN 27073/exim4
tcp 0 0 0.0.0.0:2525 0.0.0.0:* LISTEN 27073/exim4
Some some help will be great.
Tnks in advance.
metalalin
Romania, Bucharest
Ok, i've tried that link and still the problem persists.
I must mention that in clients web page on the mail section i see : Cannot open the user password file for reading .
Then i've searched the passwd file @ /etc/virtual/domain.com/passwd, on clients folder and found that passwd is an empty file.
I belive that exim reads this file for authentication on users mail, as i can not send email, but i can authenticate on dovecot and search the inbox for emails.
Also, after finding the passwd file being empty i've check the /home/client/.shadow file wich appear to be ok and written.
In DA log it shows this line :
Socket write error: fd is connected to a pipe or socket whose reading end is closed. When this happens the writing process will also receive a SIG_PIPE signal. (Thus, the write return value is seen only if the program catches, blocks or ignores this signal.)
I'm stuck in a loop :D ...someone ?
DirectAdmin Support
Administrator
Staff member
We use "exim" and not "exim4".
I would recommend first getting rid of the exim4 package.
Once gone and stopped, type:
./exim.sh
which would re-install ours. A quick redo of scsi's comment would be a good idea to ensure you've got a clean exim.conf:
http://help.directadmin.com/item.php?id=51
If you're running dovecot don't forget to repatch.
Note that for system account login, (eg same as DA login) for email, the /etc/virtual/domain.com/passwd does not apply at all. In fact, no domain applies for the system account email. It's real domain is your hostname. The /home/username/.shadow file is used for smtp-auth, and the /etc/shadow is used for everything else (dovecot, da login, ssh). If smtp-auth is failing try the following:
Resave the password through DA. Click the big icon at the top, change the password, then repeat to set it back to the one you want. This should reset the /home/username/.shadow file's value. It might have been out of sync, or perhaps incorrect permissions. This will reset the value and permiissions.
