named problem
tsiou
Larisa, Greece
Hi, I post it here because it's freebsd's question.
I recently chrooted bind, so i have in my rc.conf named_enable=yes etc.
i linked /usr/local/etc/rc.d/named to point to /etc/rc.d/named
After a system restart i see that bind started twice (i believe one from rc.conf and one from DA)
How can i stop DA's startup command?
paix
ua
## Updating bind to ports version
make install clean -C /usr/ports/dns/bind9
#check replase base
#if some errors, rerun make install clean
echo 'named_enable="YES"' >> /etc/rc.conf
# named symlink
mv /usr/local/etc/rc.d/named /var/4delete
ln -s /etc/rc.d/named /usr/local/etc/rc.d/
perl -pi -e "[email protected]/named [email protected]#./named [email protected]" /usr/local/etc/rc.d/boot.sh
/etc/rc.d/named restart
tsiou
Larisa, Greece
After a reboot i see that :
Oct 6 10:16:03 pindos named[850]: starting BIND 9.3.4-P1 -t /var/named -u bind
Oct 6 10:16:03 pindos named[850]: command channel listening on 127.0.0.1#953
Oct 6 10:16:03 pindos named[850]: command channel listening on ::1#953
Oct 6 10:16:03 pindos named[850]: running
Oct 6 10:16:04 pindos named[910]: starting BIND 9.3.4-P1 -t /var/named -u bind
Oct 6 10:16:04 pindos named[910]: could not listen on UDP socket: address in use
Oct 6 10:16:04 pindos named[910]: creating IPv4 interface em0 failed; interface ignored
Oct 6 10:16:04 pindos named[910]: creating IPv4 interface lo0 failed; interface ignored
Oct 6 10:16:04 pindos named[910]: not listening on any interfaces
Oct 6 10:16:04 pindos named[910]: couldn't add command channel 127.0.0.1#953: address in use
Oct 6 10:16:04 pindos named[910]: couldn't add command channel ::1#953: address in use
Oct 6 10:16:04 pindos named[910]: could not listen on UDP socket: permission denied
Oct 6 10:16:04 pindos named[910]: running
And every hour i see that :
Oct 6 04:36:34 pindos named[894]: could not listen on UDP socket: permission denied
Oct 6 04:36:34 pindos named[894]: creating IPv4 interface em0 failed; interface ignored
Oct 6 04:36:34 pindos named[894]: creating IPv4 interface lo0 failed; interface ignored
Oct 6 04:36:34 pindos named[894]: not listening on any interfaces
It seems that it's starting twice on reboot and every hour i thing DA is trying to (re)start it?
In DA's show services seems as running...
The weird thing is that i don't have DA's ./named in boot.sh..
With a grep named * in rc.d i only get results from named file which is linked to /etc/rc.d/named
daveyw
/dev/null
Maybe the port is already in use. Also theire is something wrong with your interface..
paix
ua
tsiou also you could do next:
named_enable="YES" in rc.conf
mv /etc/rc.d/named /usr/local/etc/rc.d/named
Then you should enable run named by directadmin in
rc.d/boot.sh script.
That will guarantee that named runs only one during boot.
IT_Architect
That fixed my problem. I wish I knew how you know how to set up all of the symlinks etc. I notice bind is at 9.6 now. I don't know if there are any advantages or drawbacks to that.
