phpMyAdmin additional configure problem
indexs
Greetings folks!
Yesterday i was updating my server and went in to problem with phpmyadmin.
So the problem is, i get one error message at the bottom of phpmyadmin.
Error message:
The phpMyAdmin configuration storage is not completely configured, some extended features have been deactivated. To find out why click here.
I understand that i need to make changes for the missing configuration, but is there any manual for this according to DirectAdmin. I don`t want to mess up phpmyadmin if the config files are not compatible with DA.
Any suggestions please would be appreciated.
Thank you!
Info about phpMyadmin:
version - 3.4.10.1
MySQL client version: 5.1.61
Server: Linux Debian 5.0
Hmm... the people have the same problem, but no solution for this... :(
I have done the update as usual
./build clean
./build update_versions
I`m seeing this:
$cfg['Servers'][$i]['pmadb'] ... OK
$cfg['Servers'][$i]['relation'] ... not OK [ Documentation ]
General relation features: Disabled
$cfg['Servers'][$i]['table_info'] ... not OK [ Documentation ]
Display Features: Disabled
$cfg['Servers'][$i]['table_coords'] ... not OK [ Documentation ]
$cfg['Servers'][$i]['pdf_pages'] ... not OK [ Documentation ]
Creation of PDFs: Disabled
$cfg['Servers'][$i]['column_info'] ... not OK [ Documentation ]
Displaying Column Comments: Disabled
Browser transformation: Disabled
$cfg['Servers'][$i]['bookmarktable'] ... not OK [ Documentation ]
Bookmarked SQL query: Disabled
$cfg['Servers'][$i]['history'] ... not OK [ Documentation ]
SQL history: Disabled
$cfg['Servers'][$i]['designer_coords'] ... not OK [ Documentation ]
Designer: Disabled
$cfg['Servers'][$i]['tracking'] ... not OK [ Documentation ]
Tracking: Disabled
$cfg['Servers'][$i]['userconfig'] ... not OK [ Documentation ]
User preferences: Disabled
Quick steps to setup advanced features:
Create the needed tables with the script/create_tables.sql. Documentation
Create a pma user and give access to these tables. Documentation
Enable advanced features in configuration file (config.inc.php), for example by starting from config.sample.inc.php. Documentation
Re-login to phpMyAdmin to load the updated configuration file.
The question is: Is it safe to perform thous configs?
In what sql i need to create tables with the ./script script/create_tables.sql.
Is it really necessary to: "Create a pma user and give access to these tables."
I believe you've got there active links to documentation, why don't you simply spend an hour or a couple to carefully read this? Since you're not the first who asks the same, and nobody gave an answer, you'd better research it by yourself. And as soon as you manage to solve it, you might want to share with your solution, and it's OK if you don't want to share ;)
One thing should be mentioned, you should copy your updated (modified) config.inc.php from /var/www/html/phpmyadmin/ to /usr/local/directadmin/custombuild/custom/phpmyadmin/config.inc.php in order to protect it from beign overwritten.
p.s. Working on config.inc.php you hardly can destroy anything on the server, so don't worry about it a lot.
I was reading the manual to again today! :)
Last time it was about 1:00 at night when i have read the help manual :p now i`m getting some sens of that! I think i can solve this and i will deferentially post the solution.
It's very easy to fix these errors, when you open the config.inc.php file you see the following lines, you have to uncomment these:
/* Storage database and tables */
$cfg['Servers'][$i]['pmadb'] = 'phpmyadmin';
$cfg['Servers'][$i]['bookmarktable'] = 'pma_bookmark';
$cfg['Servers'][$i]['relation'] = 'pma_relation';
$cfg['Servers'][$i]['table_info'] = 'pma_table_info';
$cfg['Servers'][$i]['table_coords'] = 'pma_table_coords';
$cfg['Servers'][$i]['pdf_pages'] = 'pma_pdf_pages';
$cfg['Servers'][$i]['column_info'] = 'pma_column_info';
$cfg['Servers'][$i]['history'] = 'pma_history';
$cfg['Servers'][$i]['tracking'] = 'pma_tracking';
$cfg['Servers'][$i]['designer_coords'] = 'pma_designer_coords';
$cfg['Servers'][$i]['userconfig'] = 'pma_userconfig';
And you have to create and give up an control user
$cfg['Servers'][$i]['controluser'] = 'username';
$cfg['Servers'][$i]['controlpass'] = 'password';
and you have to create the next tables:
-- SQL Commands to set up the pmadb as described in Documentation.html.
-- This file is meant for use with MySQL 5 and above!
-- This script expects the user pma to already be existing. If we would put a
-- line here to create him too many users might just use this script and end
-- up with having the same password for the controluser.
-- This user "pma" must be defined in config.inc.php (controluser/controlpass)
-- Please don't forget to set up the tablenames in config.inc.php
-- Database : `phpmyadmin`
CREATE DATABASE IF NOT EXISTS `phpmyadmin`
DEFAULT CHARACTER SET utf8 COLLATE utf8_bin;
USE phpmyadmin;
-- Privileges
-- (activate this statement if necessary)
-- GRANT SELECT, INSERT, DELETE, UPDATE ON `phpmyadmin`.* TO
-- 'pma'@localhost;
-- Table structure for table `pma_bookmark`
CREATE TABLE IF NOT EXISTS `pma_bookmark` (
`id` int(11) NOT NULL auto_increment,
`dbase` varchar(255) NOT NULL default '',
`user` varchar(255) NOT NULL default '',
`label` varchar(255) CHARACTER SET utf8 COLLATE utf8_general_ci NOT NULL default '',
`query` text NOT NULL,
PRIMARY KEY (`id`)
ENGINE=MyISAM COMMENT='Bookmarks'
-- Table structure for table `pma_column_info`
CREATE TABLE IF NOT EXISTS `pma_column_info` (
`id` int(5) unsigned NOT NULL auto_increment,
`db_name` varchar(64) NOT NULL default '',
`table_name` varchar(64) NOT NULL default '',
`column_name` varchar(64) NOT NULL default '',
`comment` varchar(255) CHARACTER SET utf8 COLLATE utf8_general_ci NOT NULL default '',
`mimetype` varchar(255) CHARACTER SET utf8 COLLATE utf8_general_ci NOT NULL default '',
`transformation` varchar(255) NOT NULL default '',
`transformation_options` varchar(255) NOT NULL default '',
PRIMARY KEY (`id`),
UNIQUE KEY `db_name` (`db_name`,`table_name`,`column_name`)
ENGINE=MyISAM COMMENT='Column information for phpMyAdmin'
-- Table structure for table `pma_history`
CREATE TABLE IF NOT EXISTS `pma_history` (
`id` bigint(20) unsigned NOT NULL auto_increment,
`username` varchar(64) NOT NULL default '',
`db` varchar(64) NOT NULL default '',
`table` varchar(64) NOT NULL default '',
`timevalue` timestamp NOT NULL,
`sqlquery` text NOT NULL,
PRIMARY KEY (`id`),
KEY `username` (`username`,`db`,`table`,`timevalue`)
ENGINE=MyISAM COMMENT='SQL history for phpMyAdmin'
-- Table structure for table `pma_pdf_pages`
CREATE TABLE IF NOT EXISTS `pma_pdf_pages` (
`page_nr` int(10) unsigned NOT NULL auto_increment,
`page_descr` varchar(50) CHARACTER SET utf8 COLLATE utf8_general_ci NOT NULL default '',
PRIMARY KEY (`page_nr`),
KEY `db_name` (`db_name`)
ENGINE=MyISAM COMMENT='PDF relation pages for phpMyAdmin'
-- Table structure for table `pma_relation`
CREATE TABLE IF NOT EXISTS `pma_relation` (
`master_db` varchar(64) NOT NULL default '',
`master_table` varchar(64) NOT NULL default '',
`master_field` varchar(64) NOT NULL default '',
`foreign_db` varchar(64) NOT NULL default '',
`foreign_table` varchar(64) NOT NULL default '',
`foreign_field` varchar(64) NOT NULL default '',
PRIMARY KEY (`master_db`,`master_table`,`master_field`),
KEY `foreign_field` (`foreign_db`,`foreign_table`)
ENGINE=MyISAM COMMENT='Relation table'
-- Table structure for table `pma_table_coords`
CREATE TABLE IF NOT EXISTS `pma_table_coords` (
`pdf_page_number` int(11) NOT NULL default '0',
`x` float unsigned NOT NULL default '0',
`y` float unsigned NOT NULL default '0',
PRIMARY KEY (`db_name`,`table_name`,`pdf_page_number`)
ENGINE=MyISAM COMMENT='Table coordinates for phpMyAdmin PDF output'
-- Table structure for table `pma_table_info`
CREATE TABLE IF NOT EXISTS `pma_table_info` (
`display_field` varchar(64) NOT NULL default '',
PRIMARY KEY (`db_name`,`table_name`)
ENGINE=MyISAM COMMENT='Table information for phpMyAdmin'
-- Table structure for table `pma_designer_coords`
CREATE TABLE IF NOT EXISTS `pma_designer_coords` (
`x` INT,
`y` INT,
`v` TINYINT,
`h` TINYINT,
ENGINE=MyISAM COMMENT='Table coordinates for Designer'
-- Table structure for table `pma_tracking`
CREATE TABLE IF NOT EXISTS `pma_tracking` (
`db_name` varchar(64) collate utf8_bin NOT NULL,
`table_name` varchar(64) collate utf8_bin NOT NULL,
`version` int(10) unsigned NOT NULL,
`date_created` datetime NOT NULL,
`date_updated` datetime NOT NULL,
`schema_snapshot` text collate utf8_bin NOT NULL,
`schema_sql` text collate utf8_bin,
`data_sql` longtext collate utf8_bin,
`tracking` set('UPDATE','REPLACE','INSERT','DELETE','TRUNCATE','CREATE DATABASE','ALTER DATABASE','DROP DATABASE','CREATE TABLE','ALTER TABLE','RENAME TABLE','DROP TABLE','CREATE INDEX','DROP INDEX','CREATE VIEW','ALTER VIEW','DROP VIEW') collate utf8_bin default NULL,
`tracking_active` int(1) unsigned NOT NULL default '1',
PRIMARY KEY (`db_name`,`table_name`,`version`)
) ENGINE=MyISAM DEFAULT CHARSET=utf8 COLLATE=utf8_bin ROW_FORMAT=COMPACT;
-- Table structure for table `pma_userconfig`
CREATE TABLE IF NOT EXISTS `pma_userconfig` (
`username` varchar(64) NOT NULL,
`config_data` text NOT NULL,
PRIMARY KEY (`username`)
ENGINE=MyISAM COMMENT='User preferences storage for phpMyAdmin'
Oh thank you, but i already did it found the solution -> here <-
Only thing is that it`s Russian, if someone needs help with translation i can make a post with explanations in English!
I was checking the "suhosin", but will this work with php 5.3.10 or i need roll back the php version?
The extensnion would work, the patch for 5.3.10 is still not avaible.
For install the suhosin extension search this forum for update.script
Regards
