problem building custombuild 1.2
Equand
Found /usr/local/directadmin/custombuild/httpd-2.2.9.tar.gz
Extracting /usr/local/directadmin/custombuild/httpd-2.2.9.tar.gz...
Configuring httpd-2.2.9
configure: WARNING: you should use --build, --host, --target
configure: WARNING: invalid host type:
checking for chosen layout... Apache
checking for working mkdir -p... yes
checking build system type... config.sub: missing argument
Try `config.sub --help' for more information.
configure: error: /bin/sh build/config.sub failed
/usr/local/directadmin/custombuild/configure/ap2/configure.apache: --with-ssl=/usr: not found
*** There was an error while trying to configure Apache 2. Check the configure/ap2/configure.apache file
anybody help
system already has customapache 1.3 installed with php4 - the most simple installation out of the box of directadmin
i need to upgrade it to ap2+php5+zend optimizer
FreeBSD ##### 6.3-RELEASE FreeBSD 6.3-RELEASE #0: Wed Jan 16 04:45:45 UTC 2008 root@dessler.cse.buffalo.edu:/usr/obj/usr/src/sys/SMP i386
smtalk
Administrator
Staff member
LT, EU
Did you touch /usr/local/directadmin/custombuild/configure/ap2/configure.apache ?
Equand
all i did is ./build all
i didn't touch configs except for adding optimizer in options
nmb
Got similar error with custombuild 1.2 and CentOS 5.2 64 bits. Tried 1.1 with another machine before and didn't have problem like this. Also, just tried 1.1 on the same machine that has problem with 1.2 and it works flawlessly.
Backing up certificate and key, and turning off httpd for DirectAdmins's check.
/usr/local/directadmin/custombuild/configure/ap2/configure.apache: line 33: --with-ssl=/usr: No such file or directory
________
EXPERT INSURANCE
DirectAdmin Support
Administrator
Staff member
I've made a very slight change to the configure.apache in the 1.2 configure.apache file. There was a single space after the \ character, which seems to affect the configure on some boxes. The space is gone now. Do "./build update" and try again.
