Problem to install PHP script .I need HELP
semco
:confused:Hello
I have problem to install PHP script
When I Had cpanel hosting I had no problem to install any PHP
now I moved my website to directadmin and lot of problems to install any scripts
.I am trying to install my
Web directory
Was working in cpanel host
http://enomal.com/
When I follow my install link is like this
http://enomal.com:2222/CMD_FILE_MANAGER/domains/enomal.com/public_html/install/index.php
is not finding root to installer
In Cpanel my link was
http://enomal.com/install/index.php
And no problem I could run install process
any IDEA to fix this :eek: :confused:
nobaloney
California
Where did you install the installer (what is the complete path of the installer files)?
Note that I had to rename your thread (PHP is not BHP) so people could find it and understand what it's about) and move it; it's really a user issue.
semco
I installed in public_htm/install folder/install index.php
instead installer I got file ?
@package PHPLinkDirectory # @version 3.3.0 # ################################################################################ */ require_once '../include/config.php'; require_once 'include/version.php'; require_once 'include/functions.php'; require_once 'install/config.php'; require_once 'libs/intsmarty/intsmarty.class.php'; require_once 'libs/smarty/SmartyValidate.class.php'; require_once 'libs/adodb/adodb.inc.php'; //Detect web-server software define ('IS_APACHE', ( strstr($_SERVER['SERVER_SOFTWARE'], 'Apache') || strstr($_SERVER['SERVER_SOFTWARE'], 'LiteSpeed') ) ? 1 : 0); define ('IS_IIS' , strstr ($_SERVER['SERVER_SOFTWARE'], 'Microsoft-IIS') ? 1 : 0); $fn = INSTALL_PATH.'temp/templates'; if (!is_writable ($fn)) @ chmod ($fn, 0777); if (!is_writable ($fn)) { exit ("The installer cannot start!\n
\n Please make sure that the folder ".$fn." is writeable by the user the webserver runs under."); } //Create dummy variable to test if session variables are supported session_start(); $_SESSION['sessionTest'] = 1; session_write_close(); session_start(); $step = (!empty ($_REQUEST['step']) && preg_match ('`^[\d]+$`', $_REQUEST['step']) ? intval ($_REQUEST['step']) : 1); $step = ($step < 1 || $step > 6 ? 1 : $step); //Do not allow more/less steps than default $language = (!empty ($_SESSION['language']) ? $_SESSION['language'] : 'en'); $clear_all = 0; //Determine core templates folder $core_tpl = (defined ('CORE_TEMPLATES') && CORE_TEMPLATES != '' ? CORE_TEMPLATES : 'Core'); if (!is_dir ('../templates/'.$core_tpl) || !is_dir ('../templates/'.$core_tpl.'/install')) exit ( "The installer cannot find it's template files!\n
Please make sure that the folders templates/{$core_tpl}/ and templates/{$core_tpl}/install/ are available and readable by the user the webserver runs under."); $tpl = new IntSmarty($language); $tpl->template_dir = '../templates/'.$core_tpl; $tpl->compile_dir = '../temp/templates'; $tpl->cache_dir = '../temp/cache'; $tpl->compile_check = false; $path = request_uri(); $path_parts = pathinfo ($path); $path_parts['dirname'] = preg_replace ('`/install[\.]*`i', '', $path_parts['dirname']); define ('DOC_ROOT', $path_parts['dirname']); define ('INSTALL_ROOT', DOC_ROOT.'/install'); define ('TEMPLATE_PATH' , 'templates/admin'); define ('FULL_TEMPLATE_PATH', DOC_ROOT.'/templates/admin'); if (!$_SESSION['nologin'] && !isset ($_SESSION['phpld']['adminpanel']['id']) && defined ('DB_DRIVER') && defined ('DB_HOST')) { $db = ADONewConnection(DB_DRIVER); if($db->Connect(DB_HOST, DB_USER, DB_PASSWORD, DB_NAME)) { $check = $db->GetOne("SELECT COUNT(*) FROM `{$tables['user']['name']}` WHERE `LEVEL` = '1' AND `ACTIVE` = '1'"); if (!empty ($check)) { $_SESSION['return'] = DOC_ROOT.'/install/index.php'; http_redirect(DOC_ROOT.'/admin/login.php'); } else $_SESSION['nologin'] = true; } } else $_SESSION['nologin'] = true; //Assign fatal error tracker $fatal = 0; switch ($step) { //SELECT LANGUAGE case 1 : $tpl->assign('languages', select_lang()); $tpl->assign('btn_next', 1); $tpl->assign('title', _L('Select Language')); if (empty ($_POST['submit'])) { //Clear the entire template cache $tpl->clear_all_cache(); //Clear all compiled template files $tpl->clear_compiled_tpl(); } elseif (!empty ($_POST['submit']) && !empty ($_POST['language'])) { //Store language preferences $_SESSION['language'] = (!empty ($_POST['language']) ? $_POST['language'] : 'en'); //Redirect to next step $step++; http_redirect(INSTALL_ROOT.'/index.php?step='.$step); } $tpl->assign($_POST); break; //CHECK REQUIREMENTS case 2 : //Check requirements $requirements = check_requirements(); //Check for important requirements foreach ($requirements as $key => $req) { if (isset ($req['fatal']) && $req['fatal']) { //Found at least one fatal error $fatal = 1; } } $tpl->assign('req', $requirements); if ($fatal != 1) { $tpl->assign('btn_next', 1); } $tpl->assign('btn_back', 1); $tpl->assign('fatal', $fatal); $tpl->assign('title', _L('Welcome')); if (!empty ($_POST['submit'])) { $step++; http_redirect(INSTALL_ROOT.'/index.php?step='.$step); } elseif (!empty ($_POST['back'])) { $step--; http_redirect(INSTALL_ROOT.'/index.php?step='.$step); } break; //INSTALL/UPDATE DATABASE & CONFIGURATION case 3 : //This step needs more resources //Try increase them tweak_memory_limit(64);//64Mb memory tweak_time_limit(450);//7.5 minutes $tpl->assign('db_drivers', $db_drivers); $tpl->assign('btn_next', 1); $tpl->assign('btn_back', 1); $tpl->assignLang('title', _L('Database Settings')); if (empty ($_POST['submit']) && empty ($_POST['back'])) { $_SESSION['values'] = array ('db_driver' => 'mysql'); $_SESSION['values']['db_driver'] = 'mysql'; $_SESSION['values']['db_host'] = (defined ('DB_HOST') ? DB_HOST : ''); $_SESSION['values']['db_name'] = (defined ('DB_NAME') ? DB_NAME : ''); $_SESSION['values']['db_user'] = (defined ('DB_USER') ? DB_USER : ''); $_SESSION['values']['db_password'] = (defined ('DB_PASSWORD') ? DB_PASSWORD : ''); SmartyValidate :: connect($tpl, true); SmartyValidate :: register_form('install', true); SmartyValidate :: register_validator('v_db_host' , 'db_host' , 'notEmpty' , false, false, 'trim', 'install'); SmartyValidate :: register_validator('v_db_name' , 'db_name' , 'notEmpty' , false, false, 'trim', 'install'); SmartyValidate :: register_validator('v_db_user' , 'db_user' , 'notEmpty' , false, false, 'trim', 'install'); SmartyValidate :: register_validator('v_db_password', 'db_password', 'dummyValid', true , false, 'trim', 'install'); } elseif (!empty ($_POST['submit'])) { SmartyValidate :: connect($tpl); if (SmartyValidate :: is_valid($_POST, 'install')) { $db_details = array (); $db_details['db_driver'] = 'mysql'; $db_details['db_host'] = (!empty ($_POST['db_host']) ? $_POST['db_host'] : ''); $db_details['db_name'] = (!empty ($_POST['db_name']) ?
I copy some of it ,for you to see
In Cpanel i got straight link to installer
and look like this
in Your panel link look like this
Click oon link you will see the path
that confuse everything ,
my website is use as reseller account run tow panels
user and reseller :confused:
Why my post is removed from
General Technical Discussion & Troubleshooting directory?
semco
New things happend
Hello
something new
If I change permission to 777
the message is like this
Please make sure that the folders templates/Core/ and templates/Core/install/ are available and readable by the user the webserver runs under.
If I change permission to 755
Please make sure that the folder /home/cemco18/domains/enomal.com/public_html
/temp/templates is writeable by the user the webserver runs under.
I follow install instruction and
permission for files are 777
Any help ? any one? make me smile again
