I do update_versions in directadmin via web, doing all stuff and some reason stop. When i see why i can't enter anymore directadmin seems to crashed weird i say, then i try to startup again and not let me do it (status=11).
For what i see is problem with the OS, now i can't check it if is wrong or not.
Then i try to update manually maybe fix things and nop but i see something weird.
Your license OS ( ) does not match the OS installed (CentOS 8).
./build: line 2281: [: version_cmp has a blank value when checking : integer expression expected
./build update_versions
