1. I add a domain to the server: User level -> Domain setup -> Add new -> enter domain name example.com-> Create
2. I issue Let's Encrypt SSL certificates, example.com loads fine, also www.example.com, no problems.
3. I delete the domain from the server: User level -> Domain setup -> select domain -> Delete -> Delete web data -> Delete -> DOMAIN DELETION RESULTS:
example.com deleted successfully. example.com's config files have been removed
But, in DirectAdmin's error logs shows:
2022:06:23-23:39:45: db_domain_delete: example.com: 2022/06/23 23:39:45 fatal executing cli command error=unrecognized target
In DirectAdmin sistem log there is:
2022:06:23-23:39:45: Ssl::set_sni_domains:admin,example.com: removed *.example.com from snidomains
2022:06:23-23:39:45: Ssl::set_sni_domains:admin,example.com: removed example.com from snidomains
2022:06:23-23:39:46: Domain example.com deleted via manual User deletion by 5.12.95.222
2022:06:23-23:40:36: Tally User admin Begin: mask 20
2022:06:23-23:40:38: Tally User admin Complete
2022:06:23-23:40:38: named reloaded
2022:06:23-23:40:38: dovecot reloaded
2022:06:23-23:40:38: httpd reloaded
2022:06:23-23:40:38: php-fpm74 reloaded
2022:06:23-23:40:38: php-fpm80 reloaded
After this, if I add the domain again:
1. add the domain again to the server: User level -> Domain setup -> Add new -> enter domain name example.com-> Create
2. I issue Let's Encrypt SSL certificates, BUT NOW www.example.com loads fine, example.com timeouts: unable to connect.
I deleted the domain, the same error, added again, the same problem. At DNS level A for domain was there and propagated.
I encountered this problem also on another VPS with DirectAdmin.
Am I doing something wrong?
