Problems setting up IMAP e-mail
roef
I have some problems with setting up e-mail on my VPS running DirectAdmin. So basically everything is working. I have domain on user level, installed Let's Encrypt certificates for mail, smtp, pop etc. But when I try to connect via IMAP on my iPhone mail app, it says Cannot Connect Using SSL
Then when I want to continue it says "mail.mydomain.com" is not responding. However when I try the POP option through the mail app I can connect perfectly fine, can send e-mail and receive etc. But I would like to use IMAP.
Open firewall ports: 2222, 80, 443, 465, 995, 110, 587, 25
Domain i try to connect through my mail through: nowifashion.nl
When I try the mail app through my macbook I get: The server “mail.nowifashion.nl” refused to allow a connection on the default ports.
Can somebody help me please?
Richard G
Maastricht
Imap is using other ports for incoming mail.
If you want to use imap you have to open port 143 normally or 993 for SSL.
