problems with apache 1.3.34 on FreeBSD 4.11
expream
Hello all!
have the following errors in logs
/var/log/httpd/error_log
[Wed Oct 26 00:01:02 2005] [warn] pid file /var/run/httpd.pid overwritten -- Unclean shutdown of previous Apache run?
what does it mean, I understand.. but there was no unclean shutdowns... and it is only in 1.3.34 .. in 33 there was no such messages...
/var/log/messages
Oct 26 00:00:03 server1 /kernel: pid 253 (httpd), uid 0: exited on signal 11 (core dumped)
Oct 26 00:30:01 server1 /kernel: pid 1833 (httpd), uid 0: exited on signal 11 (core dumped)
and this two messages...
squirrelhost
Marylebone, London
something went amiss - the question asked is
just that, a question, as it's a sensible place
to look first.
whic version of php are you running ?
if I googled for
there's be too many results, mostly relating
to php, not apache directly.
expream
php is 4.4.0 .... firstly.. i have installed DA .. about month ago with php 4.3.11 and apache 1.3.33.. then i diceded about week ago to make an update and to update (via customapche) php and pache to 4.4.0 and 1.3.34... and i did it. After that apache dont started at all... In the log I have the same messages when I tried to start apache.... I have wrote to support.... OK.. support has fix it by commenting out php handlers from all users httpd.conf.. and after that apache works...
Now... I diceded to make it one more time... I have reinstall system , and then on clean system installed DA again... now DA is installed with new versions of php (4.4.0) and new apache(1.3.34) ... so I did't need to make custom apache.. but.. there still appers in the log..once in a day, about 00:30:00 ...
squirrelhost
Marylebone, London
you have a core file, could always examine it,
probably a seg fault somewhere.
wonder what cron jobs are running on your
server at that time anyway, to trigger this
problem ?
expream
I have no crons... only thats DA have.. it is fresh install of FreeBSD and fresh install of DA without users... without additional options.... so where can I look for... :) somethink? :)
squirrelhost
Marylebone, London
FreeBSD 5.4, just delivered last week, DA install
has added:
1,31 0-5 * * * root adjkerntz -a
* * * * * root /usr/local/directadmin/dataskq
2 0-23/6 * * * root echo 'action=vacation&value=all' >> /usr/local/directadmin/data/task.queue;
5 0 * * * root /usr/sbin/quotaoff -a; /sbin/quotacheck -aug; /usr/sbin/quotaon -a;
30 0 * * * root echo 'action=tally&value=all' >> /usr/local/directadmin/data/task.queue
40 1 1 * * root echo 'action=reset&value=all' >> /usr/local/directadmin/data/task.queue
0 4 * * * root echo 'action=check&value=license' >> /usr/local/directadmin/data/task.queue
to /etc/crontab
looks like it's webalizer related, if it's
'exactly' 0:30 when it occurs.
blueice
expream said:
Hello all!
/var/log/messages
i have the same problem.
So i have return to 1.3.33 until this resolved
squirrelhost
Marylebone, London
try this:
have a look for the
ScoreBoardFile directive in your
httpd.conf - my guess is that the file
specified doesn't exist.
comment this line out, and
restart your httpd.
then check your error log again.
expream
2squirrelhost.. ok .. I have commented this line oout.. and tomorrow will say.. :) and do you know if freebsd need this scoreboard file? or not? if I manually will make this file? and then chown to apache:apache.. ?
blueice
i have contact support and i have receive this answer:
I'm not quite sure what the problem is, but it seems related to php.
I copied the virtual_host*.conf files to the custom directory (/usr/local/directadmin/data/templates) and commented out all the php flags.. and that seemed to prevent the core dump.
I hope this can help some people.
But in the future i want to use php flags so i hope this problem can be resolved.
Christos
expream
it doesnt help to comment out from httpd.conf scroreboard directive... there errors are still in logs :(
squirrelhost
Marylebone, London
that's correct, posted in wrong thread while
reading three at once - this is a fix
for another problem, now posted in the
correct place. all errors like these
are mostly php related.
(searching on google wil throw up many,
and no need to comment out anything,
which is definitely not a step towards any
sort of solution)
expream
so.. when I have installed DA I have this errors only one at 00:00:00 and one at 00:30:00 .. so only two errors.. and apache works perfectly.
Today I have rebuild php (add --with-iconv, and romove --with-kerberos) ... after install every time I tried to start apache I receive this errors in log.. and apache didnt started up.. until I have commented out php handlers in users http.conf files..
Any ideas? I have nothing found in google...
Gala
I got this error too..
But after I disable Zend..it seem ok..
N!cklas
This is the answer I got from my support (managed server @ Servstra.com)
The notice in the error_logs for Apache are only to notify that suexec mechanism is enabled, there are no errors in the logs, Apache is running fine.
Chrysalis
uk
Sometimes you may get whats known as a warning which can be ignored, a error is generally something that will stop the program from functioning whilst a warning would just be notfying you of something that might cause a problem but isnt critical.
