MaxPower
Well I just purchased their software and had it working for a week.
I updated my DirectAdmin control panel and it totally busted the program.
Customer support just sent me in circles...
First I'm not suppose to have an account setup on my server for the hostname ?? server1.yourdomain.com
Then I am not suppose to remove the enteries from the named.conf
Can anyone here offer any assistance that makes sense?
No of the above configuration work, with or without the domain. I have tried everything, and siteZen does not work.
removed server1.bcservers.net - then tried it. siteZen didn't work.
removed bcservers.net - tried it, siteZen didn't work
removed enteries on named.conf related to bcservers.net - tried it, siteZen didn't work
Now added domain bcservers.net back.
>> I assume you created a da hosting account using the subdomain domain
>> server1.bcservers.net. You can't do that because it makes your server
>> domain point to a hosting account and therefore serves up any urls
>> using that domain using the user associated to that hosting account
>> rather than the unprivileged nobody account that siteZen is configured
>> to run under. So please remove that subdomain (server1) and make sure
>> you can login as zenadmin using the afore mentioned URL. I think you
>> will be find on the DA login as it is now getting to the point of
>> going to the login URL.
>> Let me know how it works out. We are here to help.
Yes I see that now. When you enter the hostname in the browser you
now get a 404 error because you removed all entries from
/etc/named.conf. That won't work.
To use siteZen you have to have the hostname setup with a DNS entry
but without a DA hosting account referring to that domain. You need
the DNS A record for the hostname but you don't want to have a hosting
account on it because DA will add an additional VirtualHost entry to
the http.conf with a user directive in it. Web hosting servers are
almost always setup that way by default and this is the only
configuration in which you can use siteZen DA login features.
