regarding redirection using subdomains
raghuveer
kakinada, india
hai
regarding the subdomains:
I want to know how to redirect a subdomain to a particular http address,
we can do this in cpanel control panel by using the "setup redirection" feature, but here in this direct admin control panel ,I am not able to understand how to do that.
I think for folders in the web space root folder, we can achieve this easily, but for long http addresses, how to do this
please tell me.
regarding the virtual domains:
please tell me some info about virtual domains
what is the purpose of virtual domains and how can we use them
thanks in advance
ProWebUK
UK
raghuveer said:
hai
please tell me.
Im not sure if this is possinble *yet* with DirectAdmin, i will leave support to confirm that.
thanks in advance
Virtual domains are basically when multiple domains are hosted on a single web server.
Regards
Chris
DirectAdmin Sales
Administrator
Staff member
User Panel --> Advanced Tools --> Site Redirection
If your subdomain is sub.domain.com, you would enter '/sub' for the Local URL Path and then enter the full http address you want to redirect to.
Mark
raghuveer
kakinada, india
hai
I did the way it was posted here, but not able tounderstand why I am not getting the url I want.
I am getting the folllowing message in the status bar
website found. waiting for reply....
the page is not beiong loaded.
I will tell now what I want to redirect.
here in the e-mail menu, we will have webmail feature to check pop3 e-mail accounts directly using browser na with out the help of e-mail clients,
I had created a sub-domain webmail.securitywonks.org for this purpose.
for:
Local URL Path : /webmail
destination url: http://www.securitywonks.org/webmail
please tell me is this right and if not, what t do to redirect a subdomain to get webmail feature through it
thanks
ProWebUK
UK
im not sure of the directory structures for DA, although the PATH is usually something like var/www/html/
so you will most likely require:
var/www/html/webmail
as your local path
Chris
EDIT:
just checked and it looks like you will need:
/domains/public_html/webmail
^ for directadmin :D
loopforever
/home/admin
The simpiliest way to do what you're trying to do, would be to do the following:
- Add a subdomain via DA called "webmail"
- Throw an .htaccess file in the public_html directory of this subdomain, with the following contents:
Redirect index.html http://www.domain.com/webmail
Be sure you remove the index.html file from the public_html directory first.
This will redirect anyone visiting webmail.domain.com to domain.com/webmail.
Have fun :).
kcook
uk
I wanted to do this too, and eventually discovered that the following works in a .htaccess file in the subdomain's directory,
ie in /domains/www.domain.com/public_html/webmail/ (there isn't a public_html directory for the subdomain)
Redirect / http://www.domain.com/webmail
using 'index.html' didn't seem to work.
Keven.
