I am new to DA, I just took over the server and now I noticed that Roundcube does not display emails. Actually those emails are not delivered to users home dir.
if I login to roundcube and send an email from it, I receive it, but if I reply, there's nothing in ~/Maildir/new directory. I found out that when I send that reply there's a file created in /var/spool/virtual/mydomain.com/myusername
and basically that file contains all message source of my letters which does not get into maildir.
I am using centos distr with roundcube 0.5
I thought that maybe here is some simple config file I should check or something like that, in case you need more information about the system or logs, please comment.
Thank you in advance for your help,
Cheers!
Simonas
Cheers!
Simonas
