security problem ?
duke28
Montreal - Canada
if one user have added one ssh key
if the user has been suspended, the user can again login ssh with the ssh key
we use the /etc/ssh/sshd_config.plecibo .. is it the problem ?
sorry again for my english lol
scriptkitty
Staff member
You can confirm if changes are being made to the placebo sshd_config or the original sshd_config by running 'stat' on the files, logging the timestamps, unsuspending and quickly suspending the user again. Then again run stat on the files and see which was modified. If the original was modified, then the placebo sshd_config would need to be manually modified or modified via post hooks like described in the following:
https://forum.directadmin.com/threads/sshd_config-match-user-conflicts-with-allowusers.51787/
bdacus01
Murfreesboro
we use that because "Starting sshd: /etc/ssh/sshd_config line 371: too many allow users"
we have so many users on many servers :)
Looks like a way to create a dummy sshd config for DA to make changes to so that you can use a different SSHd file if your desired SSHd config conflicts with changes that DA adds (I had to search it myself! o_O):
