snmpd problem
nic
Command : > /usr/local/etc/rc.d/snmpd start
Error: /libexec/ld-elf.so.1: Shared object "libperl.so" not found, required by "libnetsnmphelpers.so.20"
WHEN I TYPE THIS COMMAND, I GET THESE:
ldd /usr/local/sbin/snmpd
/usr/local/sbin/snmpd:
libnetsnmpagent.so.20 => /usr/local/lib/libnetsnmpagent.so.20 (0x2807e000)
libnetsnmphelpers.so.20 => /usr/local/lib/libnetsnmphelpers.so.20 (0x280b5000)
libnetsnmpmibs.so.20 => /usr/local/lib/libnetsnmpmibs.so.20 (0x280d2000)
libwrap.so.4 => /usr/lib/libwrap.so.4 (0x281b6000)
libperl.so => /usr/local/lib/perl5/5.10.1/mach/CORE/libperl.so (0x281bd000)
libcrypt.so.3 => /lib/libcrypt.so.3 (0x282db000)
libutil.so.5 => /lib/libutil.so.5 (0x282f3000)
libnetsnmp.so.20 => /usr/local/lib/libnetsnmp.so.20 (0x282ff000)
libm.so.4 => /lib/libm.so.4 (0x283a4000)
libkvm.so.3 => /lib/libkvm.so.3 (0x283ba000)
libdevstat.so.5 => /lib/libdevstat.so.5 (0x283c1000)
libcrypto.so.4 => /lib/libcrypto.so.4 (0x283c6000)
libc.so.6 => /lib/libc.so.6 (0x284b9000)
libperl.so => not found (0x0)
Please give me some solutions
nobaloney
California
I'm presuming the poser is wondering how to install the missing command. Which agreed, has nothing to do with DirectAdmin.
It appears the libperl.so library is missing.
That's what needs to be installed. I have no idea how to do it on FreeBSD; perhaps someone does.
scsi
I would try reinstalling snmp.
cd /usr/ports/net-mgmt/net-snmp
make clean
make config install clean
ben29
isreal
you should have to install perl
[FONT=Courier]cd  /usr/ports/lang/perl5.8[/FONT]
make install clean;
or by using pkg
pkg_add -r perl5.10
