Spamassassin install problem
Magician
EU / PL
After build spamassassin i get:
Running sa-update.
Starting SpamAssassin.
setlogsock(): type='unix': path not available at /usr/share/perl/5.14.2/Mail/SpamAssassin/Logger/Syslog.pm line 100
setlogsock(): type='tcp': TCP service unavailable at /usr/share/perl/5.14.2/Mail/SpamAssassin/Logger/Syslog.pm line 121
logger: failed to add syslog method: logger: syslog initialization failed
Restarting exim.
Shutting down exim:
spamd: no process found
Starting exim:
root@server:/usr/local/directadmin/custombuild#
Any suggestion how to fix it?
"spamd: no process found" - it`s ok?
Magician
EU / PL
Maybe it help: sa-update.log
Mar  6 00:51:10.345 [19980] dbg: logger: adding facilities: all
Mar  6 00:51:10.345 [19980] dbg: logger: logging level is DBG
Mar  6 00:51:10.345 [19980] dbg: generic: SpamAssassin version 3.4.1
Mar  6 00:51:10.345 [19980] dbg: generic: Perl 5.014002, PREFIX=/usr, DEF_RULES_DIR=/usr/share/spamassassin, LOCAL_RULES_DIR=/etc/mail/spamassassin, LOCAL_STATE_DIR=/var/lib/spamassassin
Mar  6 00:51:10.345 [19980] dbg: config: timing enabled
Mar  6 00:51:10.348 [19980] dbg: config: score set 0 chosen.
Mar  6 00:51:10.351 [19980] dbg: generic: sa-update version svn1652181
Mar  6 00:51:10.352 [19980] dbg: generic: using update directory: /var/lib/spamassassin/3.004001
Mar  6 00:51:10.492 [19980] dbg: diag: perl platform: 5.014002 linux
Mar  6 00:51:10.492 [19980] dbg: diag: [...] module installed: Digest::SHA1, version 2.13
Mar  6 00:51:10.492 [19980] dbg: diag: [...] module installed: HTML::Parser, version 3.72
Mar  6 00:51:10.492 [19980] dbg: diag: [...] module installed: Net::DNS, version 1.04
Mar  6 00:51:10.492 [19980] dbg: diag: [...] module installed: NetAddr::IP, version 4.078
Mar  6 00:51:10.492 [19980] dbg: diag: [...] module installed: Time::HiRes, version 1.9728
Mar  6 00:51:10.492 [19980] dbg: diag: [...] module installed: Archive::Tar, version 1.76
Mar  6 00:51:10.492 [19980] dbg: diag: [...] module installed: IO::Zlib, version 1.10
Mar  6 00:51:10.492 [19980] dbg: diag: [...] module installed: MIME::Base64, version 3.15
Mar  6 00:51:10.492 [19980] dbg: diag: [...] module installed: DB_File, version 1.835
Mar  6 00:51:10.492 [19980] dbg: diag: [...] module installed: Net::SMTP, version 2.31
Mar  6 00:51:10.492 [19980] dbg: diag: [...] module installed: Mail::SPF, version v2.008
Mar  6 00:51:10.492 [19980] dbg: diag: [...] module installed: Geo::IP, version 1.45
Mar  6 00:51:10.492 [19980] dbg: diag: [...] module installed: Net::CIDR::Lite, version 0.21
Mar  6 00:51:10.492 [19980] dbg: diag: [...] module installed: Razor2::Client::Agent, version 2.84
Mar  6 00:51:10.492 [19980] dbg: diag: [...] module installed: IO::Socket::IP, version 0.37
Mar  6 00:51:10.492 [19980] dbg: diag: [...] module installed: IO::Socket::INET6, version 2.72
Mar  6 00:51:10.492 [19980] dbg: diag: [...] module installed: IO::Socket::SSL, version 2.024
Mar  6 00:51:10.492 [19980] dbg: diag: [...] module installed: Compress::Zlib, version 2.033
Mar  6 00:51:10.492 [19980] dbg: diag: [...] module installed: Mail::DKIM, version 0.4
Mar  6 00:51:10.492 [19980] dbg: diag: [...] module installed: DBI, version 1.634
Mar  6 00:51:10.492 [19980] dbg: diag: [...] module installed: Getopt::Long, version 2.38
Mar  6 00:51:10.492 [19980] dbg: diag: [...] module installed: LWP::UserAgent, version 6.15
Mar  6 00:51:10.492 [19980] dbg: diag: [...] module installed: HTTP::Date, version 6.02
Mar  6 00:51:10.493 [19980] dbg: diag: [...] module installed: Encode::Detect::Detector, version 1.01
Mar  6 00:51:10.493 [19980] dbg: diag: [...] module installed: Net::Patricia, version 1.22
Mar  6 00:51:10.493 [19980] dbg: diag: [...] module installed: Net::DNS::Nameserver, version 1406
Mar  6 00:51:10.494 [19980] dbg: util: secure_tmpfile created a temporary file /tmp/.spamassassin19980hZPM1Atmp
Mar  6 00:51:10.494 [19980] dbg: channel: attempting channel updates.spamassassin.org
Mar  6 00:51:10.494 [19980] dbg: channel: using existing directory /var/lib/spamassassin/3.004001/updates_spamassassin_org
Mar  6 00:51:10.494 [19980] dbg: channel: channel cf file /var/lib/spamassassin/3.004001/updates_spamassassin_org.cf
Mar  6 00:51:10.494 [19980] dbg: channel: channel pre file /var/lib/spamassassin/3.004001/updates_spamassassin_org.pre
Mar  6 00:51:10.494 [19980] dbg: channel: metadata version = 1732432, from file /var/lib/spamassassin/3.004001/updates_spamassassin_org.cf
Mar  6 00:51:10.625 [19980] dbg: dns: 1.4.3.updates.spamassassin.org => 1732432, parsed as 1732432
Mar  6 00:51:10.625 [19980] dbg: channel: current version is 1732432, new version is 1732432, skipping channel
Mar  6 00:51:10.625 [19980] dbg: diag: updates complete, exiting with code 1
server socket setup failed, retry 1: spamd: could not create IO::Socket::IP socket on [127.0.0.1]:783: Address already in use
server socket setup failed, retry 2: spamd: could not create IO::Socket::IP socket on [127.0.0.1]:783: Address already in use
server socket setup failed, retry 3: spamd: could not create IO::Socket::IP socket on [127.0.0.1]:783: Address already in use
server socket setup failed, retry 4: spamd: could not create IO::Socket::IP socket on [127.0.0.1]:783: Address already in use
server socket setup failed, retry 5: spamd: could not create IO::Socket::IP socket on [127.0.0.1]:783: Address already in use
server socket setup failed, retry 6: spamd: could not create IO::Socket::IP socket on [127.0.0.1]:783: Address already in use
server socket setup failed, retry 7: spamd: could not create IO::Socket::IP socket on [127.0.0.1]:783: Address already in use
server socket setup failed, retry 8: spamd: could not create IO::Socket::IP socket on [127.0.0.1]:783: Address already in use
server socket setup failed, retry 9: spamd: could not create IO::Socket::IP socket on [127.0.0.1]:783: Address already in use
Richard G
Maastricht
Just out of curiousity, is the syslog daemon running?
Try to restart syslog via SSH and see if it works.
Magician
EU / PL
@Richard G - great idea! Afterr update Debian to 7 syslog didn`t upgrade. After install apt-get install rsyslog syslog works again.
Beside start/stop spamd works strang
