Squirrelmail login problem
itman21
Korea
Hi
Squirrelmail login produces below
ERROR
Unknown user or password incorrect.
Go to the login page
It worked fine before and for some reason it just returns above. I could have done something... but not sure what...
Uebimiau works just fine all along, just for information.
Any clue to above ?
Sun Joo
DirectAdmin Support
Administrator
Staff member
Check your /var/log/messages and /var/log/maillog for possible imapd errors.
Else, just try running:
./imapd.sh
./squirrelmail.sh
outpernet
hi. now im having exactly the same problem, but that didnt fix it..
Feb 1 15:11:27 xxx imapd[927]: Command stream end of file, while reading line user=prueba host=localhost.localdomain [127.0$
Feb 1 15:11:46 xxx imapd[931]: imap service init from 127.0.0.1
Feb 1 15:11:49 xxx imapd[931]: Command stream end of file, while reading line user=prueba host=localhost.localdomain [127.0$
Feb 1 15:13:38 ar9 imapd[1194]: imap service init from 127.0.0.1
outpernet
un other domains works well... but for ex. in other:
ERROR:
ERROR : Could not complete request.
Query: SUBSCRIBE "INBOX.Sent"
Reason Given: SUBSCRIBE failed: Already subscribed to mailbox INBOX.Sent
inside squirrelmail.... DA team, you updated the panel today? coz until yesterday all was working fine..
itman21
Korea
Thanks. I think things now work
Thanks for the advice and prompt help.
I followed your instructions. It now works well - I can send and receive messages, and log in okay too.
However, the admin domain (default domain mapped) seems to have some configuration problems..
All other domains work just fine except for this admin domain one.
But I can easily guess why... I will post this issue in another category.
