My DA server is up and running fine. I have a few domains on it and each domain has a LetsEncrypt certificate that works just fine when you go to it's webpage. No problem there. But if I take that same domain name and try to get to it's DA control panel port (2222), I'm getting an error.
https://domain.xyz ==> Works properly with a LetsEncrypt cert
http://domain.xyz ==> redirects properly to the https: domain and displays the cert
http://domain.xyz:2222 ==> connects to the DA admin port but not securely
https://domain.xyz:2222 ==> gives me the browser error "Secure Connection Failed - An error occurred during a connection to domain.xyz:2222. PR_CONNECT_RESET_ERROR"
Same issue with all my domains. How can I fix this so I get SSL encryption when connecting to the DA port?
Thanks, GeoDirk
Thanks, GeoDirk
