We have a number of SSL certificates installed on a server and they all work fine.
However, I just tried to install another certificate for an OLD user, which didn't have dedicated IP/SSL certificate and it doesn't seem to work.
Here is what I did:
1. I assigned IP to a reseller, which created that user.
2. I then logged in as reseller and modified the user to use the new IP and also checked SSL Access checkbox.
That didn't work even after I manually restarted Apache.
Moreover, the following file /usr/local/directadmin/data/users/USER/httpd.conf doesn't even contains secure server entry (with port 443).
I wonder if there is a resolution for that.
Thank you.
