The problem user_create_post.sh
s_dastjani
hello
I want to change the config.php file
perl -pi -e 's/dbnameuser/$username_db/gi' /home/$username/domains/$domain/public_html/config.php
This command file is written
/usr/local/directadmin/scripts/custom/user_create_post.sh
Content config.php
<?php
$database = "dbnameuser";		//Datenbankname
$sqlhost = "localhost";    	//Datenbank Hostname
$sqluser = "dbnameuser";         	//Datenbank Username
$sqlpass = "dbpass";    			//Datenbank Passwort
After making a account contains config.php
<?php
$database = "";		//Datenbankname
$sqluser = "";         	//Datenbank Username
What is the problem?
smtalk
Administrator
Staff member
LT, EU
Please use double quotes in your perl regex, also, you should use curly brackets to expand the variable in string:
perl -pi -e "s/dbnameuser/${username}_db/g" /home/${username}/domains/${domain}/public_html/config.php
Good luck!
s_dastjani
Good luck!
Very Very Very Thanks
