Use subdomain with Laravel and Directadmin
rkytie
Hello.
I have a Laravel project and i want subdomain on this project.
I create subdomain and i add this route;
Route::domain('subdomain.mysite.com')->group(function () {
Route::get('/', '[email protected]')->name('name');
but... i have a problem. Its opening default page, i dont see my view.
How can i do?
I dont know enough level English btw. If u dont understand, i will can write better than.
Keizan
You have to set the root of your subdomain to the public folder of your Laravel project.
GR_
hello . please help me . i have same problem . i need to set subdomain point to root (laravel app) , after search in web i find bellow link but it explan for one subdomain i need set root any subdomain to root https://help.directadmin.com/item.php?id=199
The very easy way is to install your Laravel project, lets say in:
/home/DOMAIN_USER/domains/YOUR_DOMAIN/web/
directory, alongside with
/home/DOMAIN_USER/domains/YOUR_DOMAIN/pulic_html/
directory and then just simply point
as an alias to
/home/DOMAIN_USER/domains/YOUR_DOMAIN/web/public
via next command line:
ln -s /home/DOMAIN_USER/domains/YOUR_DOMAIN/web/public /home/DOMAIN_USER/domains/YOUR_DOMAIN/public_html
P.S. in `ln` use full paths!!! Not relative paths, otherwise you'll have problems with SSL.
ish
h
Hello.
How can i do?
ow you fix it bro same problem here
