Banisaeed
- Sep 23, 2015
Hello
I received this ticket:
Subject: Warning: The system load average is 32.73
#PHP Settings
php1_release=7.3
php1_mode=php-fpm
php2_release=no
php2_mode=php-fpm
mod_ruid2=no
apache_mpm=event
How to fix this problem?
Need to edit php-fpm settings?
if yes, where is php-fpm config and what changes should i make?
thanks
This is an automated message notifying you that the 5 minute load average on your system is 32.73.
This has exceeded the 10 threshold.
One Minute - 75.95
Five Minutes - 32.73
Fifteen Minutes - 12.51
top - 12:17:36 up 29 days, 8:11, 0 users, load average: 78.64, 39.45, 15.74
Tasks: 240 total, 53 running, 187 sleeping, 0 stopped, 0 zombie
%Cpu(s): 11.0 us, 81.0 sy, 0.0 ni, 0.0 id, 0.0 wa, 0.0 hi, 8.0 si, 0.0 st
KiB Mem : 1833068 total, 52216 free, 1689820 used, 91032 buff/cache
KiB Swap: 2097148 total, 1060 free, 2096088 used. 4764 avail Mem
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
14883 mysql 20 0 1336528 32980 0 S 12.2 1.8 14:44.53 /usr/sbin/mysqld
14666 apache 20 0 2091076 6352 40 S 4.7 0.3 0:25.66 /usr/sbin/httpd -DFOREGROUND
14664 apache 20 0 1958276 3952 52 S 3.7 0.2 0:18.37 /usr/sbin/httpd -DFOREGROUND
33 root 20 0 0 0 0 R 1.0 0.0 0:17.22 [kswapd0]
14647 named 20 0 169320 948 388 S 0.9 0.1 0:02.08 /usr/sbin/named -u named -c /etc/named.conf
1 root 20 0 191268 1036 252 S 0.5 0.1 10:02.34 /usr/lib/systemd/systemd --switched-root --system --deserialize 21
17607 admin 20 0 338948 4864 68 R 0.5 0.3 0:14.62 php-fpm: pool admin
3403 root 20 0 574064 464 0 S 0.4 0.0 6:53.66 /usr/bin/python2 -Es /usr/sbin/tuned -l -P
17606 admin 20 0 342944 26176 1188 R 0.4 1.4 0:19.20 php-fpm: pool admin
17652 admin 20 0 338188 26180 1232 R 0.4 1.4 0:03.68 php-fpm: pool admin
17656 admin 20 0 342148 11952 1280 R 0.4 0.7 0:03.34 php-fpm: pool admin
17661 admin 20 0 337532 21556 572 R 0.4 1.2 0:03.64 php-fpm: pool admin
17673 admin 20 0 340148 26436 888 R 0.4 1.4 0:03.35 php-fpm: pool admin
17629 admin 20 0 340900 24572 1220 R 0.4 1.3 0:07.64 php-fpm: pool admin
17648 admin 20 0 337836 19440 1256 R 0.4 1.1 0:03.60 php-fpm: pool admin
17662 admin 20 0 337600 18348 996 D 0.4 1.0 0:03.66 php-fpm: pool admin
17668 admin 20 0 335552 20152 1164 R 0.4 1.1 0:03.47 php-fpm: pool admin
17675 admin 20 0 335512 21800 508 R 0.4 1.2 0:03.64 php-fpm: pool admin
17685 admin 20 0 337572 20024 1052 R 0.4 1.1 0:03.09 php-fpm: pool admin
2087 polkitd 20 0 612580 404 0 S 0.3 0.0 1:40.57 /usr/lib/polkit-1/polkitd --no-debug
17631 admin 20 0 340880 25944 1344 R 0.3 1.4 0:07.50 php-fpm: pool admin
17665 admin 20 0 340092 22424 900 S 0.3 1.2 0:03.41 php-fpm: pool admin
17644 admin 20 0 337588 8556 924 S 0.3 0.5 0:03.14 php-fpm: pool admin
Connection counts:
1 151.234.87.32
1 157.119.188.22
1 157.119.190.110
1 157.119.190.67
1 157.119.190.84
1 178.131.178.136
1 185.105.184.46
1 185.105.184.47
1 185.120.222.77
1 185.165.102.49
1 185.213.166.28
1 185.23.128.234
1 185.49.87.74
1 194.5.176.153
1 194.5.177.123
1 194.5.177.147
1 194.5.177.195
1 2.180.57.166
1 31.217.210.97
1 31.56.67.91
1 31.58.21.25
1 31.7.104.229
1 37.156.234.58
1 37.27.134.164
1 46.143.64.49
1 46.143.67.105
1 46.143.88.220
1 46.225.205.127
1 46.34.104.68
1 5.121.13.55
1 5.125.171.166
1 5.160.243.106
1 5.200.100.214
1 5.202.222.197
1 5.232.88.173
1 5.63.14.182
1 78.47.108.214
1 78.47.170.100
1 80.191.105.202
1 86.57.4.235
1 87.236.213.24
1 87.236.214.14
1 89.32.250.227
1 91.92.214.2
1 94.182.192.28
1 95.82.56.161
2 151.241.253.50
2 185.105.184.61
2 185.105.184.62
2 185.42.25.203
2 2.182.167.239
2 31.56.109.211
2 31.58.167.38
2 31.59.45.13
2 46.143.102.84
2 5.160.61.84
2 5.232.219.142
2 91.98.11.111
3 5.234.20.44
IP '91.98.11.111' currently has '2' connections
Connection info for '91.98.11.111':
tcp6 1 0 159.69.210.88:443 91.98.11.111:54142 CLOSE_WAIT
tcp6 1 0 159.69.210.88:443 91.98.11.111:54116 CLOSE_WAIT
/usr/sbin/ss output:
Netid State Recv-Q Send-Q Local Address:Port Peer Address:Port
u_str ESTAB 0 0 @0028f 6875656 * 6875673
u_str ESTAB 0 0 @0028e 6875597 * 6875598
u_str ESTAB 0 0 * 6842623 * 6842663
u_str ESTAB 0 0 * 6842315 * 6842427
u_str ESTAB 8 0 /usr/local/php73/sockets/admin.sock 6873691 * 6873814
u_str ESTAB 0 0 * 6842641 * 6842669
u_str ESTAB 0 0 * 6842479 * 6842497
u_str ESTAB 0 0 /var/run/dovecot/config 6842340 * 6842241
u_str ESTAB 0 0 /var/run/dovecot/login/login 6842731 * 6842622
u_str ESTAB 0 0 /var/run/dovecot/anvil 6842487 * 6842443
u_str ESTAB 0 0 /var/run/dovecot/config 6842376 * 6842314
u_str ESTAB 0 0 /var/run/dovecot/login/login 6842737 * 6842640
u_str ESTAB 0 0 /var/run/dovecot/login/login 6842730 * 6842616
u_str ESTAB 0 0 * 6842241 * 6842340
u_str ESTAB 0 0 /run/systemd/journal/stdout 6841982 * 6841981
u_str ESTAB 0 0 /var/run/dovecot/anvil 6842673 * 6842653
u_str ESTAB 0 0 /var/run/dovecot/login/login 6842713 * 6842445
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 6842426 * 6842311
u_str ESTAB 0 0 * 6873899 * 0
u_str ESTAB 0 0 * 6842640 * 6842737
u_str ESTAB 0 0 /var/run/dovecot/login/login 6842722 * 6842477
u_str ESTAB 0 0 /var/run/dovecot/login/login 6842742 * 6842655
u_str ESTAB 0 0 /var/run/dovecot/anvil 6842663 * 6842623
u_str ESTAB 0 0 * 6842445 * 6842713
u_str ESTAB 0 0 * 6842314 * 6842376
u_str ESTAB 0 0 * 6842477 * 6842722
u_str ESTAB 0 0 * 6842242 * 6842392
u_str ESTAB 0 0 * 6842655 * 6842742
u_str ESTAB 0 768 * 6873623 * 6873652
u_str ESTAB 0 0 /var/run/dovecot/login/login 6842732 * 6842625
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 6842427 * 6842315
u_str ESTAB 0 768 * 6873564 * 6873505
u_str ESTAB 0 0 /var/run/dovecot/anvil 6842668 * 6842638
u_str ESTAB 0 0 /var/run/dovecot/anvil 6842662 * 6842620
u_str ESTAB 0 0 * 6873893 * 0
u_str ESTAB 0 0 * 6841981 * 6841982
u_str ESTAB 0 0 * 6842652 * 6842741
u_str ESTAB 0 768 * 6873603 * 6873572
u_str ESTAB 0 0 * 6842625 * 6842732
u_str ESTAB 0 0 * 6842638 * 6842668
u_str ESTAB 0 0 * 6842620 * 6842662
u_str ESTAB 0 0 /var/run/dovecot/anvil 6842496 * 6842475
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 6842392 * 6842242
u_str ESTAB 8 0 /usr/local/php73/sockets/admin.sock 6873572 * 6873603
u_str ESTAB 0 0 /var/run/dovecot/anvil 6842664 * 6842626
u_str ESTAB 0 0 * 6842449 * 6842488
u_str ESTAB 0 0 /var/run/dovecot/config 6842379 * 6842319
u_str ESTAB 0 768 * 6873814 * 6873691
u_str ESTAB 8 0 /usr/local/php73/sockets/admin.sock 6873505 * 6873564
u_str ESTAB 0 0 /var/run/dovecot/login/login 6842736 * 6842637
u_str ESTAB 0 0 * 6842622 * 6842731
u_str ESTAB 0 0 * 6842475 * 6842496
u_str ESTAB 0 0 * 6842443 * 6842487
u_str ESTAB 0 0 * 6842653 * 6842673
u_str ESTAB 0 0 * 6842626 * 6842664
u_str ESTAB 0 0 * 6842311 * 6842426
u_str ESTAB 0 0 * 6842637 * 6842736
u_str ESTAB 0 0 /var/run/dovecot/login/login 6842721 * 6842474
u_str ESTAB 0 0 /var/run/dovecot/login/login 6842741 * 6842652
u_str ESTAB 0 0 * 6842325 * 6842382
u_str ESTAB 0 0 /var/run/dovecot/config 6842351 * 6842262
u_str ESTAB 0 0 * 20082 * 20083
u_str ESTAB 0 0 /var/run/dovecot/anvil 6842666 * 6842632
u_str ESTAB 0 0 /var/run/dovecot/anvil 6842660 * 6842611
u_str ESTAB 8 0 /usr/local/php73/sockets/admin.sock 6873740 * 6873872
u_str ESTAB 0 0 /run/dbus/system_bus_socket 18944 * 18779
u_str ESTAB 0 0 /var/run/dovecot/config 6842372 * 6842304
u_str ESTAB 8 0 /usr/local/php73/sockets/admin.sock 6873252 * 6873221
u_str ESTAB 0 0 * 6842326 * 6842432
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 6842401 * 6842261
u_str ESTAB 0 0 * 6842632 * 6842666
u_str ESTAB 0 0 * 6842251 * 6842396
u_str ESTAB 8 0 /usr/local/php73/sockets/admin.sock 6873743 * 6873881
u_str ESTAB 0 0 /var/run/dovecot/config 6842382 * 6842325
u_str ESTAB 0 0 /var/run/dovecot/config 6842350 * 6842260
u_str ESTAB 0 0 /run/systemd/journal/stdout 20083 * 20082
u_str ESTAB 0 0 * 6842634 * 6842735
u_str ESTAB 0 0 * 6842613 * 6842729
u_str ESTAB 0 0 /var/run/dovecot/config 6842344 * 6842248
u_str ESTAB 0 0 * 6842275 * 6842408
u_str ESTAB 0 0 * 6842262 * 6842351
u_str ESTAB 0 0 /var/run/dovecot/login/login 6842729 * 6842613
u_str ESTAB 0 0 * 6842250 * 6842345
u_str ESTAB 0 768 * 6873221 * 6873252
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 6842431 * 6842324
u_str ESTAB 0 0 * 6842635 * 6842667
u_str ESTAB 0 0 * 6842614 * 6842661
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 6842395 * 6842249
u_str ESTAB 8 0 /usr/local/php73/sockets/admin.sock 6873652 * 6873623
u_str ESTAB 0 0 * 6842692 * 6842743
u_str ESTAB 0 768 * 6873230 * 6873349
u_str ESTAB 0 0 * 6842327 * 6842383
u_str ESTAB 0 0 * 6842261 * 6842401
u_str ESTAB 0 0 /var/run/dovecot/login/login 6842735 * 6842634
u_str ESTAB 0 0 /var/run/dovecot/anvil 6842661 * 6842614
u_str ESTAB 0 0 * 6842249 * 6842395
u_str ESTAB 0 0 /var/run/dovecot/login/login 6842743 * 6842692
u_str ESTAB 0 0 /var/run/dovecot/config 6842345 * 6842250
u_str ESTAB 0 768 * 6873875 * 6873741
u_str ESTAB 8 0 /usr/local/php73/sockets/admin.sock 6873349 * 6873230
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 6842432 * 6842326
u_str ESTAB 0 0 * 6842263 * 6842402
u_str ESTAB 0 0 /var/run/dovecot/anvil 6842667 * 6842635
u_str ESTAB 0 0 * 6842616 * 6842730
u_str ESTAB 0 0 * 6842248 * 6842344
u_str ESTAB 0 768 * 6873872 * 6873740
u_str ESTAB 0 0 * 18941 * 18942
u_str ESTAB 0 768 * 6874062 * 6873779
u_str ESTAB 0 768 * 6873679 * 6873687
u_str ESTAB 0 0 /var/run/dovecot/config 6842371 * 6842302
u_str ESTAB 0 0 * 6842295 * 6842418
u_str ESTAB 0 0 /var/run/dovecot/config 6842358 * 6842276
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 6842406 * 6842271
u_str ESTAB 0 0 /var/run/dovecot/config 6842347 * 6842254
u_str ESTAB 0 0 * 6842293 * 6842417
u_str ESTAB 0 0 * 6842247 * 6842394
u_str ESTAB 0 0 /run/systemd/private 6875673 * 6875656
u_str ESTAB 8 0 /usr/local/php73/sockets/admin.sock 6873909 * 6875647
u_str ESTAB 0 0 * 6874108 * 0
u_str ESTAB 0 0 * 6842303 * 6842422
u_str ESTAB 0 0 /var/run/dovecot/config 6842368 * 6842296
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 6842409 * 6842277
u_str ESTAB 0 0 * 6842272 * 6842356
u_str ESTAB 0 0 * 6842254 * 6842347
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 6842416 * 6842291
u_str ESTAB 0 0 * 6842235 * 6842338
u_str ESTAB 0 0 /run/systemd/journal/stdout 6875750 * 6875749
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 6842422 * 6842303
u_str ESTAB 0 0 * 6842298 * 6842369
u_str ESTAB 0 0 * 6842276 * 6842358
u_str ESTAB 0 0 /var/run/dovecot/config 6842356 * 6842272
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 6842397 * 6842253
u_str ESTAB 0 768 * 6873172 * 6873237
u_str ESTAB 0 0 /var/run/dovecot/config 6842367 * 6842294
u_str ESTAB 0 0 /var/run/dovecot/config 6842343 * 6842246
u_str ESTAB 0 0 * 6842236 * 6842390
u_str ESTAB 0 0 * 6841755 * 6841757
u_str ESTAB 0 768 * 6875654 * 6873910
u_str ESTAB 0 0 * 6873861 * 0
u_str ESTAB 0 0 * 6842302 * 6842371
u_str ESTAB 0 0 * 6842271 * 6842406
u_str ESTAB 0 0 * 6842252 * 6842346
u_str ESTAB 0 0 /run/systemd/journal/stdout 18735 * 18734
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 6842417 * 6842293
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 6842412 * 6842283
u_str ESTAB 0 0 /var/run/dovecot/config 6842361 * 6842282
u_str ESTAB 0 0 /var/run/dovecot/config 6842338 * 6842235
u_str ESTAB 0 0 /run/systemd/journal/stdout 6841757 * 6841755
u_str ESTAB 8 0 /usr/local/php73/sockets/admin.sock 6873910 * 6875654
u_str ESTAB 8 0 /usr/local/php73/sockets/admin.sock 6873687 * 6873679
u_str ESTAB 8 0 /usr/local/php73/sockets/admin.sock 6873629 * 6873613
u_str ESTAB 0 0 * 6842296 * 6842368
u_str ESTAB 0 0 * 6842277 * 6842409
u_str ESTAB 0 0 * 6842324 * 6842431
u_str ESTAB 8 0 /usr/local/php73/sockets/admin.sock 6873711 * 6873818
u_str ESTAB 0 0 /var/run/dovecot/config 6842366 * 6842292
u_str ESTAB 0 0 * 6842282 * 6842361
u_str ESTAB 0 0 /run/systemd/journal/stdout 24570 * 24569
u_str ESTAB 8 0 /usr/local/php73/sockets/admin.sock 6873582 * 6873610
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 6842418 * 6842295
u_str ESTAB 0 0 /var/run/dovecot/config 6842355 * 6842270
u_str ESTAB 0 0 /var/run/dovecot/config 6842346 * 6842252
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 6842394 * 6842247
u_str ESTAB 0 0 * 6842294 * 6842367
u_str ESTAB 0 0 * 6842283 * 6842412
u_str ESTAB 0 0 * 6842281 * 6842411
u_str ESTAB 0 0 * 6842246 * 6842343
u_str ESTAB 0 768 * 6873610 * 6873582
u_str ESTAB 0 0 * 6842297 * 6842419
u_str ESTAB 0 0 * 6842253 * 6842397
u_str ESTAB 0 0 /run/systemd/journal/stdout 22128 * 22127
u_str ESTAB 0 0 * 6842292 * 6842366
u_str ESTAB 0 0 * 6875749 * 6875750
u_str ESTAB 0 768 * 6875647 * 6873909
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 6842419 * 6842297
u_str ESTAB 0 0 * 22127 * 22128
u_str ESTAB 0 768 * 6873600 * 6873571
u_str ESTAB 0 768 * 6873818 * 6873711
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 6842411 * 6842281
u_str ESTAB 0 0 * 24569 * 24570
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 6842437 * 6842336
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 6842402 * 6842263
u_str ESTAB 0 768 * 6873841 * 6873731
u_str ESTAB 0 768 * 6873617 * 6873630
u_str ESTAB 0 0 /var/run/dovecot/anvil 6842659 * 6842608
u_str ESTAB 0 0 * 6842290 * 6842365
u_str ESTAB 0 0 /run/dbus/system_bus_socket 23696 * 23695
u_str ESTAB 8 0 /usr/local/php73/sockets/admin.sock 6873237 * 6873172
u_str ESTAB 0 0 * 6842484 * 6842724
u_str ESTAB 0 0 * 6842336 * 6842437
u_str ESTAB 8 0 /usr/local/php73/sockets/admin.sock 6873731 * 6873841
u_str ESTAB 0 0 * 6842608 * 6842659
u_str ESTAB 0 0 /var/run/dovecot/config 6842364 * 6842288
u_str ESTAB 0 0 * 6842482 * 6842498
u_str ESTAB 0 0 /var/run/dovecot/config 6842352 * 6842264
u_str ESTAB 0 768 * 6873817 * 6873710
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 6842675 * 6842674
u_str ESTAB 0 0 /var/run/dovecot/login/login 6842727 * 6842607
u_str ESTAB 0 0 * 23695 * 23696
u_str ESTAB 0 0 * 6873901 * 0
u_str ESTAB 0 0 /var/run/dovecot/anvil 6842498 * 6842482
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 6842403 * 6842265
u_str ESTAB 0 768 * 6873644 * 6873663
u_str ESTAB 0 0 * 6842674 * 6842675
u_str ESTAB 0 0 * 6842607 * 6842727
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 6842415 * 6842289
u_str ESTAB 0 0 * 6842481 * 6842723
u_str ESTAB 0 0 * 6842439 * 6842486
u_str ESTAB 0 0 * 6842273 * 6842407
u_str ESTAB 0 0 * 6842265 * 6842403
u_str ESTAB 0 0 /var/run/dovecot/config 6842354 * 6842268
u_str ESTAB 8 0 /usr/local/php73/sockets/admin.sock 6873688 * 6873682
u_str ESTAB 0 768 * 6873547 * 6873497
u_str ESTAB 0 0 * 6842611 * 6842660
u_str ESTAB 0 0 * 6842289 * 6842415
u_str ESTAB 0 0 /var/run/dovecot/login/login 6842723 * 6842481
u_str ESTAB 0 0 * 6842006 * 6842005
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 6842405 * 6842269
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 6842396 * 6842251
u_str ESTAB 0 0 /var/run/dovecot/anvil 6842698 * 6842690
u_str ESTAB 0 0 /var/run/dovecot/login/login 6842728 * 6842610
u_str ESTAB 0 0 /var/run/dovecot/config 6842365 * 6842290
u_str ESTAB 0 0 /var/run/dovecot/anvil 6842497 * 6842479
u_str ESTAB 0 0 * 6842005 * 6842006
u_str ESTAB 0 0 * 6842270 * 6842355
u_str ESTAB 8 0 /usr/local/php73/sockets/admin.sock 6873663 * 6873644
u_str ESTAB 0 0 * 6842690 * 6842698
u_str ESTAB 0 0 * 6842610 * 6842728
u_str ESTAB 0 0 * 6842288 * 6842364
u_str ESTAB 0 0 * 6874555 * 0
u_str ESTAB 0 0 /var/run/dovecot/anvil 6842486 * 6842439
u_str ESTAB 0 0 * 6842269 * 6842405
u_str ESTAB 8 0 /usr/local/php73/sockets/admin.sock 6873710 * 6873817
u_str ESTAB 8 0 /usr/local/php73/sockets/admin.sock 6873497 * 6873547
u_str ESTAB 0 0 * 6842291 * 6842416
u_str ESTAB 0 0 * 6842441 * 6842712
u_str ESTAB 0 0 /run/systemd/private 6875598 * 6875597
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 6842400 * 6842259
u_str ESTAB 0 0 * 6874314 * 0
u_str ESTAB 8 0 /usr/local/php73/sockets/admin.sock 6873732 * 6873844
u_str ESTAB 0 0 * 6842318 * 6842428
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 6842421 * 6842301
u_str ESTAB 0 0 * 6873887 * 0
u_str ESTAB 0 0 * 6873859 * 0
u_str ESTAB 0 768 * 6873844 * 6873732
u_str ESTAB 0 0 * 6842317 * 6842378
u_str ESTAB 0 768 * 6873811 * 6873690
u_str ESTAB 0 0 * 6842260 * 6842350
u_str ESTAB 0 0 /run/systemd/journal/stdout 18161 * 18160
u_str ESTAB 8 0 /usr/local/php73/sockets/admin.sock 6873468 * 6873520
u_str ESTAB 0 768 * 6873830 * 6873715
u_str ESTAB 8 0 /usr/local/php73/sockets/admin.sock 6873779 * 6874062
u_str ESTAB 8 0 /usr/local/php73/sockets/admin.sock 6873571 * 6873600
u_str ESTAB 0 0 * 6843015 * 6843014
u_str ESTAB 0 0 * 6842319 * 6842379
u_str ESTAB 0 0 * 6873895 * 0
u_str ESTAB 0 0 * 18160 * 18161
u_str ESTAB 8 0 /usr/local/php73/sockets/admin.sock 6873744 * 6874055
u_str ESTAB 0 0 /var/run/dovecot/anvil-auth-penalty 6842709 * 6842707
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 6842428 * 6842318
u_str ESTAB 0 0 * 6874321 * 0
u_str ESTAB 0 768 * 6873520 * 6873468
u_str ESTAB 0 0 * 6842707 * 6842709
u_str ESTAB 0 0 /var/run/dovecot/config 6842378 * 6842317
u_str ESTAB 8 0 /usr/local/php73/sockets/admin.sock 6873715 * 6873830
u_str ESTAB 0 768 * 6874055 * 6873744
u_str ESTAB 8 0 /usr/local/php73/sockets/admin.sock 6873690 * 6873811
u_str ESTAB 0 0 /var/run/dovecot/login/login 6842712 * 6842441
u_str ESTAB 8 0 /usr/local/php73/sockets/admin.sock 6873529 * 6873588
u_str ESTAB 0 0 /var/run/dovecot/anvil 6842491 * 6842458
u_str ESTAB 0 0 * 6842304 * 6842372
u_str ESTAB 0 0 * 6842301 * 6842421
u_str ESTAB 0 0 /var/run/dovecot/config 6842349 * 6842258
u_str ESTAB 0 0 * 6842335 * 6842387
u_str ESTAB 0 0 * 6842328 * 6842433
u_str ESTAB 0 0 * 6842309 * 6842425
u_str ESTAB 8 0 /usr/local/php73/sockets/admin.sock 6873513 * 6873577
u_str ESTAB 0 0 * 6842649 * 6842740
u_str ESTAB 0 0 * 6842458 * 6842491
u_str ESTAB 0 0 * 6842300 * 6842370
u_str ESTAB 0 0 * 6842264 * 6842352
u_str ESTAB 0 0 * 6842259 * 6842400
u_str ESTAB 0 768 * 6873641 * 6873662
u_str ESTAB 0 0 /var/run/dovecot/config 6842387 * 6842335
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 6842433 * 6842328
u_str ESTAB 0 0 /var/run/dovecot/config 6842374 * 6842308
u_str ESTAB 8 0 /usr/local/php73/sockets/admin.sock 6873837 * 6874095
u_str ESTAB 0 0 * 6842604 * 6842726
u_str ESTAB 0 0 /var/run/dovecot/login/login 6842740 * 6842649
u_str ESTAB 0 0 * 6842299 * 6842420
u_str ESTAB 0 768 * 6873836 * 6873724
u_str ESTAB 0 0 /var/run/dovecot/login/login 6842716 * 6842457
u_str ESTAB 0 0 * 6842256 * 6842348
u_str ESTAB 0 0 * 6842334 * 6842436
u_str ESTAB 0 0 * 6842329 * 6842384
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 6842424 * 6842307
u_str ESTAB 8 0 /usr/local/php73/sockets/admin.sock 6873838 * 6874098
u_str ESTAB 8 0 /usr/local/php73/sockets/admin.sock 6873689 * 6873708
u_str ESTAB 0 0 * 6842602 * 6842657
u_str ESTAB 0 0 * 6842650 * 6842672
u_str ESTAB 0 0 /var/run/dovecot/config 6842369 * 6842298
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 6842390 * 6842236
u_str ESTAB 0 0 /run/dbus/system_bus_socket 18943 * 18362
u_str ESTAB 0 0 * 6842457 * 6842716
u_str ESTAB 0 0 /var/run/dovecot/config 6842348 * 6842256
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 6842436 * 6842334
u_str ESTAB 0 0 /var/run/dovecot/config 6842384 * 6842329
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 6842425 * 6842309
u_str ESTAB 0 0 /var/run/dovecot/anvil 6842657 * 6842602
u_str ESTAB 0 768 * 6873613 * 6873629
u_str ESTAB 0 0 /var/run/dovecot/anvil 6842672 * 6842650
u_str ESTAB 0 0 /var/run/dovecot/config 6842339 * 6842239
u_str ESTAB 0 0 /run/systemd/journal/stdout 24276 * 24274
u_str ESTAB 8 0 /usr/local/php73/sockets/admin.sock 6873724 * 6873836
u_str ESTAB 0 0 /var/run/dovecot/config 6842370 * 6842300
u_str ESTAB 0 0 * 6842258 * 6842349
u_str ESTAB 0 0 * 6843014 * 6843015
u_str ESTAB 0 0 * 6842333 * 6842386
u_str ESTAB 0 0 * 6842330 * 6842434
u_str ESTAB 0 0 /var/run/dovecot/anvil 6842658 * 6842605
u_str ESTAB 0 0 /var/run/dovecot/login/login 6842739 * 6842646
u_str ESTAB 0 0 * 6842240 * 6842391
u_str ESTAB 0 0 * 24274 * 24276
u_str ESTAB 0 0 * 6873889 * 0
u_str ESTAB 8 0 /usr/local/php73/sockets/admin.sock 6873662 * 6873641
u_str ESTAB 0 0 /var/run/dovecot/anvil 6842490 * 6842455
u_str ESTAB 0 0 * 6842257 * 6842399
u_str ESTAB 0 0 * 18779 * 18944
u_str ESTAB 0 0 /var/run/dovecot/config 6842386 * 6842333
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 6842434 * 6842330
u_str ESTAB 0 0 * 6842310 * 6842375
u_str ESTAB 0 768 * 6874095 * 6873837
u_str ESTAB 0 0 * 6842647 * 6842671
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 6842391 * 6842240
u_str ESTAB 0 0 * 18362 * 18943
u_str ESTAB 0 0 * 6842455 * 6842490
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 6842399 * 6842257
u_str ESTAB 0 0 * 6842332 * 6842435
u_str ESTAB 0 0 * 6842331 * 6842385
u_str ESTAB 0 0 * 6842308 * 6842374
u_str ESTAB 0 768 * 6874098 * 6873838
u_str ESTAB 0 0 /var/run/dovecot/login/login 6842726 * 6842604
u_str ESTAB 0 0 /var/run/dovecot/anvil 6842671 * 6842647
u_str ESTAB 0 0 * 6842239 * 6842339
u_str ESTAB 0 0 * 18734 * 18735
u_str ESTAB 0 0 /var/run/dovecot/login/login 6842715 * 6842454
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 6842435 * 6842332
u_str ESTAB 0 0 /var/run/dovecot/config 6842385 * 6842331
u_str ESTAB 0 0 /var/run/dovecot/config 6842375 * 6842310
u_str ESTAB 0 768 * 6873708 * 6873689
u_str ESTAB 8 0 /usr/local/php73/sockets/admin.sock 6873630 * 6873617
u_str ESTAB 0 0 * 6842605 * 6842658
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 6842420 * 6842299
u_str ESTAB 0 0 * 6842629 * 6842665
u_str ESTAB 0 0 * 6842278 * 6842359
u_str ESTAB 0 0 * 6842266 * 6842353
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 6842430 * 6842322
u_str ESTAB 8 0 /usr/local/php73/sockets/admin.sock 6873723 * 6873833
u_str ESTAB 0 0 /var/run/dovecot/login/login 6842733 * 6842628
u_str ESTAB 8 0 /usr/local/php73/sockets/admin.sock 6873741 * 6873875
u_str ESTAB 0 0 * 6842454 * 6842715
u_str ESTAB 0 0 /var/run/dovecot/config 6842353 * 6842266
u_str ESTAB 0 0 /var/run/dovecot/config 6842383 * 6842327
u_str ESTAB 0 0 * 6842321 * 6842380
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 6842407 * 6842273
u_str ESTAB 0 0 * 6842628 * 6842733
u_str ESTAB 8 0 /usr/local/php73/sockets/admin.sock 6873633 * 6873620
u_str ESTAB 0 0 * 6842452 * 6842489
u_str ESTAB 0 0 * 6842322 * 6842430
u_str ESTAB 0 0 * 18571 * 18572
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 6842410 * 6842279
u_str ESTAB 0 0 /var/run/dovecot/anvil 6842489 * 6842452
u_str ESTAB 0 0 * 6842268 * 6842354
u_str ESTAB 0 0 * 20079 * 20080
u_str ESTAB 0 0 /run/systemd/journal/stdout 18572 * 18571
u_str ESTAB 0 0 /var/run/dovecot/login/login 6842734 * 6842631
u_str ESTAB 0 0 /var/run/dovecot/config 6842360 * 6842280
u_str ESTAB 0 0 * 6842451 * 6842714
u_str ESTAB 0 768 * 6873561 * 6873504
u_str ESTAB 8 0 /usr/local/php73/sockets/admin.sock 6873686 * 6873678
u_str ESTAB 0 0 * 6842323 * 6842381
u_str ESTAB 0 0 * 6842274 * 6842357
u_str ESTAB 0 0 * 6842631 * 6842734
u_str ESTAB 0 0 * 6842280 * 6842360
u_str ESTAB 0 0 /var/run/dovecot/login/login 6842714 * 6842451
u_str ESTAB 0 0 * 6842267 * 6842404
u_str ESTAB 8 0 /usr/local/php73/sockets/admin.sock 6873504 * 6873561
u_str ESTAB 0 0 /run/systemd/journal/stdout 20080 * 20079
u_str ESTAB 0 768 * 6873678 * 6873686
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 6842429 * 6842320
u_str ESTAB 0 768 * 6873833 * 6873723
u_str ESTAB 0 0 * 6842279 * 6842410
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 6842408 * 6842275
u_str ESTAB 0 768 * 6873620 * 6873633
u_str ESTAB 8 0 /usr/local/php73/sockets/admin.sock 6873498 * 6873558
u_str ESTAB 0 0 /var/run/dovecot/anvil 6842488 * 6842449
u_str ESTAB 0 0 /var/run/dovecot/config 6842381 * 6842323
u_str ESTAB 0 0 /var/run/dovecot/config 6842357 * 6842274
u_str ESTAB 0 0 /var/run/dovecot/anvil 6842665 * 6842629
u_str ESTAB 0 0 /var/run/dovecot/config 6842359 * 6842278
u_str ESTAB 0 768 * 6873682 * 6873688
u_str ESTAB 0 768 * 6873558 * 6873498
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 6842404 * 6842267
u_str ESTAB 0 0 /var/run/dovecot/config 6842380 * 6842321
u_str ESTAB 0 0 /var/run/dovecot/anvil 6842669 * 6842641
u_str ESTAB 0 0 * 18942 * 18941
u_str ESTAB 0 0 /var/run/dovecot/login/login 6842725 * 6842601
u_str ESTAB 0 0 * 6842287 * 6842414
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 6842393 * 6842245
u_str ESTAB 0 0 /var/run/dovecot/login/login 6842717 * 6842460
u_str ESTAB 0 0 * 6842307 * 6842424
u_str ESTAB 0 0 * 6842474 * 6842721
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 6842414 * 6842287
u_str ESTAB 0 0 /run/systemd/journal/stdout 14921 * 14920
u_str ESTAB 0 0 * 6842601 * 6842725
u_str ESTAB 0 0 * 6842466 * 6842719
u_str ESTAB 0 0 * 6842255 * 6842398
u_str ESTAB 0 0 * 6842245 * 6842393
u_str ESTAB 0 768 * 6873098 * 6873094
u_str ESTAB 0 0 * 6842461 * 6842492
u_str ESTAB 0 768 * 6873577 * 6873513
u_str ESTAB 0 0 /run/dbus/system_bus_socket 18945 * 18807
u_str ESTAB 0 0 * 6842643 * 6842738
u_str ESTAB 0 0 * 14920 * 14921
u_str ESTAB 0 0 * 6842464 * 6842493
u_str ESTAB 0 0 /var/run/dovecot/config 6842363 * 6842286
u_str ESTAB 0 0 * 6842305 * 6842423
u_str ESTAB 0 0 /var/run/dovecot/anvil 6842495 * 6842472
u_str ESTAB 0 0 * 18807 * 18945
u_str ESTAB 0 0 /var/run/dovecot/login/login 6842738 * 6842643
u_str ESTAB 0 0 /var/run/dovecot/anvil 6842656 * 6842599
u_str ESTAB 0 0 /var/run/dovecot/anvil 6842493 * 6842464
u_str ESTAB 0 0 /var/run/dovecot/config 6842362 * 6842284
u_str ESTAB 0 0 /var/run/dovecot/config 6842342 * 6842244
u_str ESTAB 8 0 /usr/local/php73/sockets/admin.sock 6873094 * 6873098
u_str ESTAB 0 0 * 6842460 * 6842717
u_str ESTAB 0 0 * 6842472 * 6842495
u_str ESTAB 0 0 * 6842644 * 6842670
u_str ESTAB 0 0 * 6842599 * 6842656
u_str ESTAB 0 0 * 6842285 * 6842413
u_str ESTAB 0 0 * 6842463 * 6842718
u_str ESTAB 0 0 * 6842306 * 6842373
u_str ESTAB 8 0 /usr/local/php73/sockets/admin.sock 6873466 * 6873485
u_str ESTAB 0 0 /var/run/dovecot/login/login 6842720 * 6842471
u_str ESTAB 0 0 /var/run/dovecot/anvil 6842670 * 6842644
u_str ESTAB 0 0 * 6842469 * 6842494
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 6842413 * 6842285
u_str ESTAB 0 0 * 6842244 * 6842342
u_str ESTAB 0 0 /var/run/dovecot/login/login 6842718 * 6842463
u_str ESTAB 0 0 /var/run/dovecot/config 6842373 * 6842306
u_str ESTAB 0 768 * 6873881 * 6873743
u_str ESTAB 0 768 * 6873588 * 6873529
u_str ESTAB 0 0 * 6842471 * 6842720
u_str ESTAB 8 0 /usr/local/php73/sockets/admin.sock 6873742 * 6873878
u_str ESTAB 0 0 /var/run/dovecot/login/login 6842719 * 6842466
u_str ESTAB 0 0 * 6842284 * 6842362
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 6842398 * 6842255
u_str ESTAB 0 0 * 16296 * 16297
u_str ESTAB 0 0 /var/run/dovecot/anvil 6842492 * 6842461
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 6842423 * 6842305
u_str ESTAB 0 0 * 6842646 * 6842739
u_str ESTAB 0 0 * 16297 * 16296
u_str ESTAB 0 768 * 6873878 * 6873742
u_str ESTAB 0 0 /var/run/dovecot/login/login 6842724 * 6842484
u_str ESTAB 0 0 * 6842286 * 6842363
u_str ESTAB 0 768 * 6873485 * 6873466
u_str ESTAB 0 0 /var/run/dovecot/anvil 6842494 * 6842469
u_str ESTAB 0 0 * 6842320 * 6842429
tcp CLOSE-WAIT 78 0 ::ffff:159.69.210.88:443 ::ffff:194.5.177.123:55493
tcp ESTAB 0 0 ::ffff:159.69.210.88:443 ::ffff:5.202.222.197:49216
tcp CLOSE-WAIT 78 0 ::ffff:159.69.210.88:443 ::ffff:31.58.167.38:25350
tcp LAST-ACK 0 32 ::ffff:159.69.210.88:443 ::ffff:46.143.102.84:64968
tcp LAST-ACK 0 32 ::ffff:159.69.210.88:443 ::ffff:46.143.102.84:64905
tcp CLOSE-WAIT 1 0 ::ffff:159.69.210.88:443 ::ffff:157.119.190.84:59679
tcp CLOSE-WAIT 78 0 ::ffff:159.69.210.88:443 ::ffff:31.58.21.25:56180
tcp CLOSE-WAIT 78 0 ::ffff:159.69.210.88:443 ::ffff:185.165.102.49:51565
tcp CLOSE-WAIT 78 0 ::ffff:159.69.210.88:443 ::ffff:2.180.57.166:16528
tcp CLOSE-WAIT 78 0 ::ffff:159.69.210.88:443 ::ffff:194.5.177.147:57751
tcp LAST-ACK 0 32 ::ffff:159.69.210.88:443 ::ffff:5.232.219.142:65177
tcp LAST-ACK 0 32 ::ffff:159.69.210.88:443 ::ffff:157.119.188.22:55958
tcp CLOSE-WAIT 1 0 ::ffff:159.69.210.88:443 ::ffff:91.98.11.111:54142
tcp CLOSE-WAIT 78 0 ::ffff:159.69.210.88:443 ::ffff:31.59.45.13:14311
tcp LAST-ACK 0 32 ::ffff:159.69.210.88:443 ::ffff:46.143.64.49:13083
tcp ESTAB 0 0 ::ffff:159.69.210.88:443 ::ffff:5.202.222.197:17840
tcp LAST-ACK 0 32 ::ffff:159.69.210.88:443 ::ffff:31.56.67.91:20849
tcp LAST-ACK 0 32 ::ffff:159.69.210.88:443 ::ffff:95.82.56.161:10607
tcp LAST-ACK 0 32 ::ffff:159.69.210.88:443 ::ffff:46.143.67.105:58319
tcp LAST-ACK 0 32 ::ffff:159.69.210.88:443 ::ffff:185.23.128.234:37287
tcp LAST-ACK 0 32 ::ffff:159.69.210.88:443 ::ffff:5.232.88.173:17107
tcp CLOSE-WAIT 78 0 ::ffff:159.69.210.88:443 ::ffff:94.182.192.28:3271
tcp CLOSE-WAIT 78 0 ::ffff:159.69.210.88:443 ::ffff:2.182.167.239:65220
tcp LAST-ACK 0 32 ::ffff:159.69.210.88:443 ::ffff:78.47.170.100:59047
tcp LAST-ACK 0 32 ::ffff:159.69.210.88:443 ::ffff:185.105.184.47:63042
tcp LAST-ACK 0 603 ::ffff:159.69.210.88:443 ::ffff:185.42.25.203:48725
tcp CLOSE-WAIT 78 0 ::ffff:159.69.210.88:443 ::ffff:5.234.20.44:56076
tcp CLOSE-WAIT 1 0 ::ffff:159.69.210.88:443 ::ffff:46.143.88.220:13369
tcp LAST-ACK 0 32 ::ffff:159.69.210.88:443 ::ffff:5.202.222.197:52619
tcp ESTAB 0 0 ::ffff:159.69.210.88:443 ::ffff:5.160.243.106:2244
tcp LAST-ACK 0 32 ::ffff:159.69.210.88:443 ::ffff:31.56.109.211:45606
tcp LAST-ACK 0 32 ::ffff:159.69.210.88:443 ::ffff:5.160.61.84:63855
tcp LAST-ACK 0 32 ::ffff:159.69.210.88:443 ::ffff:185.105.184.46:60256
tcp LAST-ACK 0 32 ::ffff:159.69.210.88:443 ::ffff:37.156.234.58:56586
tcp ESTAB 0 0 ::ffff:159.69.210.88:443 ::ffff:185.105.184.58:57979
tcp CLOSE-WAIT 78 0 ::ffff:159.69.210.88:443 ::ffff:185.105.184.61:64530
tcp LAST-ACK 0 32 ::ffff:159.69.210.88:443 ::ffff:31.56.109.211:17061
tcp LAST-ACK 0 32 ::ffff:159.69.210.88:443 ::ffff:87.236.213.24:1382
tcp LAST-ACK 0 32 ::ffff:159.69.210.88:443 ::ffff:5.200.100.214:37187
tcp LAST-ACK 0 32 ::ffff:159.69.210.88:443 ::ffff:31.58.167.38:23000
tcp CLOSE-WAIT 78 0 ::ffff:159.69.210.88:443 ::ffff:5.160.61.84:63860
tcp CLOSE-WAIT 78 0 ::ffff:159.69.210.88:443 ::ffff:157.119.190.110:58864
tcp LAST-ACK 0 32 ::ffff:159.69.210.88:443 ::ffff:5.234.20.44:56044
tcp LAST-ACK 0 32 ::ffff:159.69.210.88:443 ::ffff:37.27.134.164:60728
tcp LAST-ACK 0 32 ::ffff:159.69.210.88:443 ::ffff:178.131.178.136:58841
tcp ESTAB 0 0 ::ffff:159.69.210.88:443 ::ffff:46.100.95.20:50448
tcp CLOSE-WAIT 78 0 ::ffff:159.69.210.88:443 ::ffff:185.105.184.62:58058
tcp LAST-ACK 0 32 ::ffff:159.69.210.88:443 ::ffff:151.241.253.50:65503
tcp LAST-ACK 0 32 ::ffff:159.69.210.88:443 ::ffff:5.232.219.142:65035
tcp LAST-ACK 0 32 ::ffff:159.69.210.88:443 ::ffff:31.59.45.13:58793
tcp LAST-ACK 0 32 ::ffff:159.69.210.88:443 ::ffff:2.182.167.239:65215
tcp CLOSE-WAIT 1 0 ::ffff:159.69.210.88:443 ::ffff:5.121.13.55:43247
tcp CLOSE-WAIT 78 0 ::ffff:159.69.210.88:443 ::ffff:87.236.214.14:2058
tcp LAST-ACK 0 1627 ::ffff:159.69.210.88:443 ::ffff:185.42.25.203:49108
Top Memory Usage:
admin 17701 1.2 1.8 337896 34776 ? R 12:14 0:02 php-fpm: pool admin
admin 17688 1.4 1.8 340120 34528 ? S 12:13 0:03 php-fpm: pool admin
admin 17685 1.3 1.8 337644 33456 ? D 12:13 0:03 php-fpm: pool admin
admin 17668 1.4 1.8 335512 33460 ? D 12:13 0:03 php-fpm: pool admin
admin 17661 1.5 1.8 340292 34112 ? R 12:13 0:03 php-fpm: pool admin
admin 17648 1.5 1.7 337740 32788 ? R 12:13 0:03 php-fpm: pool admin
admin 17798 0.8 1.6 338904 30708 ? S 12:15 0:00 php-fpm: pool admin
admin 17796 0.9 1.6 338904 30972 ? R 12:15 0:01 php-fpm: pool admin
admin 17686 1.4 1.6 335420 30728 ? R 12:13 0:03 php-fpm: pool admin
admin 17662 1.5 1.6 337588 29960 ? R 12:13 0:03 php-fpm: pool admin
Virtual Memory Info:
procs -----------------------memory---------------------- ---swap-- -----io---- -system-- --------cpu-------- -----timestamp-----
r b swpd free buff cache si so bi bo in cs us sy id wa st +0430
8 7 1312884 72404 332 87820 4 2 40 18 4 15 1 0 99 0 0 2019-06-25 12:17:47
8 7 1258536 57104 312 86608 61700 11608 246428 11632 8040 4335 37 63 0 0 0 2019-06-25 12:17:48
7 6 1245080 60996 208 82348 31944 8648 531072 8680 7898 3038 22 77 0 1 0 2019-06-25 12:17:49
Automated Message Generated by DirectAdmin
#PHP Settings
php1_release=7.3
php1_mode=php-fpm
php2_release=no
php2_mode=php-fpm
mod_ruid2=no
apache_mpm=event
thanks
