websitetests is not a valid username [Urgent help needed]
sufiyanshaikh
I am facing this error while restoring backup taken from DirectAdmin backup module.
Need solution. Support is not replying
ditto
Are you running the newest version of DirectAdmin?
Do yo have the following line in /usr/local/directadmin/conf/directadmin.conf ?:
max_username_length=
If so make sure the value is 12 or higher. If not change it to 12 or higher and restart DirectAdmin.
bdacus01
Murfreesboro
Also all of this for review if you are migrating from cpanel
sufiyanshaikh
Thanks for reply.
It was fixed.
However, DirectAdmin support team should provide support in case of emergency.
sufiyanshaikh
It was DA to DA migration (One server to another)
bdacus01
Murfreesboro
Thanks for reply.
It was fixed.
very bottom.. As far as I know it only M-F they are not 24/7 365. Not that I dont agree with you.
2016 JBMC Software, Suite 173 3-11 Bellerose Drive, St Albert, AB T8N 1P7 Canada. Mon - Fri 9AM - 5PM MST
