Hi all,
I tried to update my freebsd 4.1 DA with PHP4, MYSQL 4 and apache 1.3
I did manage to upgrade it to PHP5 and apache 2.
while looking for a way to upgrade to MYSQL 5, I found the 1.1 script on the site:
http://files.directadmin.com/services/custombuild/1.1/
which I also read will upgrade my MYSQL version.
I followed the instructions and got the file, extracted it and tried to build.
and got :
I tried getting files from my backup, but nothing helps, I even tried ./build update_data and got the same error.
I have no idea what's wrong and I am stuck. Here is the options.conf
thanks for any help you can suggest
./build update_data
and got :
grep: invalid option -- m
Usage: grep [OPTION]... PATTERN [FILE]...
Try `grep --help' for more information.
There is wrong default PHP in /usr/local/directadmin/custombuild/options.conf set.
#PHP settings. default_php possible values - 4 or 5
default_php=5
php4_cli=no
php4_cgi=no
php5_cli=yes
php5_cgi=no
zend=no
#Possible values - 4.1, 5.0
mysql=5.0
mysql_inst=no
mysql_backup=yes
#Possible values - 1.3, 2.0 or 2.2
apache_ver=2.2
#Web applications
phpmyadmin=yes
atmail=no
squirrelmail=yes
roundcube=yes
uebimiau=no
#Mail options
exim=no
mail-header-patch=yes
dovecot=yes
#Statistics
awstats=no
webalizer=yes
#FTP options
proftpd=yes
#Jailed shell (beta)
jail=no
#CustomBuild options
custombuild=1.1
autover=no
bold=yes
clean=yes
clean_old_webapps=no
#Cron settings
cron=no
[email protected]
notifications=yes
updates=no
#CustomBuild 1.2 settings
php6_cli=no
php6_cgi=no
php_ini=no
#Possible values - recommended or dist
php_ini_type=recommended
cleanapache=no
fileserver=1
eximconf=no
