CentOS 5.8 to 6.x upgrade?
Samplex
Is it possible to upgrade my server with CentOS v5.8 to v6.x?
If yes, how do i do that?
Is my license still working then?
How can i upgrade my license?
Also is it possible to upgrade cents 5.8 to 6.x?
Not recommended by Red Hat (redhat.com), and they should know.
You probably shouldn't try it unless you're a very experienced Systems Administrator and know what you're doing. Note that I'm a very experienced Systems Administrator (I've been administering Red Hat systems since approximately 1994, and other Unixes since even earlier) and I choose to not do it.
In DirectAdmin Client Area.
Not always; that permission isn't given out to all DirectAdmin clients; you may need to contact DirectAdmin Sales to have it done.
I have a lot of experience too with Linux and many other Unixes, so I do know what I am doing. I have even attempted a few times to upgrade CentOS5.x to CentOS6.x and the success rate was quite low (1 out of 3). Luckily they were all VMs, I didn't want to attempt it for real with a live system. There are far too many places to fail, and if you have a remote system you are taking a huge chance of rendering your whole system unbootable. If you need CentOS6, you are much better off and safer getting a new system with that version of the OS and migrating the data from the CentOS5 system. It is actually a lot less work that way and when you have everything working correctly on the new system, just change the DNS entries at your registrar to point to the new system so you have virtually no down time.
As others have mentioned your DA license would then need to be changed to a RHEL6 version to work properly.
