Remco00
- Feb 22, 2006
update perl module
perl -MCPAN -eshell
install version
But I do have Perl 5.8.5 installed.
update perl module
perl -MCPAN -eshell
install version
msc_xml.h:17:31: error: libxml/xmlschemas.h: No such file or directory
msc_xml.h:18:26: error: libxml/xpath.h: No such file or directory
In file included from modsecurity.h:38,
from mod_security2.c:16:
msc_xml.h:23: error: expected specifier-qualifier-list before 'xmlSAXHandler'
make: *** [mod_security2.slo] Error 1
make[1]: Entering directory `/usr/local/updatescript/modsecurity2/modsecurity-apache_2.1.5/apache2'
/usr/local/directadmin/custombuild/httpd-2.2.8/srclib/apr/libtool --silent --mode=compile gcc -g -O2 -pthread -I/usr/local/include -O2 -g -Wuninitialized -Wall -Wmissing-prototypes -Wshadow -Wunused-variable -Wunused-value -Wchar-subscripts -Wsign-compare -DWITH_LIBXML2 -DLINUX=2 -D_REENTRANT -D_GNU_SOURCE -I /usr/include/libxml2 -I /path/to/httpd-x.y/srclib/pcre -I. -I/usr/local/directadmin/custombuild/httpd-2.2.8/os/unix -I/usr/local/directadmin/custombuild/httpd-2.2.8/server/mpm/prefork -I/usr/local/directadmin/custombuild/httpd-2.2.8/modules/http -I/usr/local/directadmin/custombuild/httpd-2.2.8/modules/filters -I/usr/local/directadmin/custombuild/httpd-2.2.8/modules/proxy -I/usr/local/directadmin/custombuild/httpd-2.2.8/include -I/usr/local/directadmin/custombuild/httpd-2.2.8/modules/generators -I/usr/local/directadmin/custombuild/httpd-2.2.8/modules/mappers -I/usr/local/directadmin/custombuild/httpd-2.2.8/modules/database -I/usr/local/directadmin/custombuild/httpd-2.2.8/srclib/apr/include -I/usr/local/directadmin/custombuild/httpd-2.2.8/srclib/apr-util/include -I/usr/local/directadmin/custombuild/httpd-2.2.8/srclib/apr-util/xml/expat/lib -I/usr/local/include -I/usr/local/directadmin/custombuild/httpd-2.2.8/modules/proxy/../generators -I/usr/include -I/usr/kerberos/include -I/usr/local/directadmin/custombuild/httpd-2.2.8/modules/ssl -I/usr/local/directadmin/custombuild/httpd-2.2.8/modules/dav/main -prefer-pic -c mod_security2.c && touch mod_security2.slo
make[1]: *** [mod_security2.slo] Error 1
make[1]: Leaving directory `/usr/local/updatescript/modsecurity2/modsecurity-apache_2.1.5/apache2'
make: *** [install-recursive] Error 1
Starting httpd: [Wed Jan 30 18:44:12 2008] [warn] module php5_module is already loaded, skipping
httpd: Syntax error on line 20 of /etc/httpd/conf/httpd.conf: Cannot load /usr/lib/libxml2.so into server: /usr/lib/libxml2.so: cannot open shared object file: No such file or directory
[root@rack15 squirrelmail-1.4.13]# ls -la
total 4152
drwxr-xr-x 17 root root 4096 Feb 5 10:31 .
drwxr-xr-x 10 root root 4096 Feb 1 11:38 ..
-rw-r--r-- 1 root root 3958484 Jan 6 2007 all_locales-1.4.9-20070106.tar.gz
drwx------ 2 apache apache 4096 Feb 5 10:36 attachments
etc...
restart apache or remove # trojans.conf , useragents.confCode:<IfModule mod_security2.c> # ModSecurity2 ONLY # All time config.conf and apache2-rules.conf ON # Do not change anything in included files # Include /etc/modsecurity2/config.conf #Include /etc/modsecurity2/apache2-rules.conf #Include /etc/modsecurity2/bad_robots.conf #Include /etc/modsecurity2/blacklist.conf #Include /etc/modsecurity2/blacklist2.conf #Include /etc/modsecurity2/exclude.conf ## stop #Include /etc/modsecurity2/generic_attacks.conf #Include /etc/modsecurity2/http_policy.conf #Include /etc/modsecurity2/jitp.conf #Include /etc/modsecurity2/outbound.conf #Include /etc/modsecurity2/protocol_anomalies.conf #Include /etc/modsecurity2/protocol_violations.conf #Include /etc/modsecurity2/recons.conf #Include /etc/modsecurity2/request_limits.conf #Include /etc/modsecurity2/rootkits.conf #Include /etc/modsecurity2/trojans.conf #Include /etc/modsecurity2/useragents.conf </IfModule>
use any rules you want![]()
Wael
But these are gotroot rules? From my experience I must use these rules and not the standard rules? Or can I add them to the above list? Also, why can I not activate the log function by editing the config.conf file of the modsecurity module?
Hi.
Try to run: ./update.script OPENSSL
It's a new clean CentOS 4.6 with custombuild latest "standard" version.
Xen VPS server
Here are the error I revcived:
/sbin/ldconfig: Cannot stat /usr/lib/tls/i686/libdb-4.2.so: No such file or directory
libdb_cxx-4.2.so -> libdb_cxx-4.2.so
/usr/lib/tls/i486: (hwcap: 0x8002000000000000)
/sbin/ldconfig: Cannot stat /usr/lib/tls/i486/libdb-4.2.so: No such file or directory
/usr/lib/tls/i586: (hwcap: 0x8004000000000000)
/sbin/ldconfig: Cannot stat /usr/lib/tls/i586/libdb-4.2.so: No such file or directory
Openssl update done
I try the "ldconfig" gives error down in post.
bash-3.00# /sbin/ldconfig
/sbin/ldconfig: /usr/lib/mysql/libmysqlclient.so.15 is not a symbolic link
No one that have any idea about this error![]()
