Still got my phpize error
I still got my phpize error and did change the peclconfig as stated in step 1.
Here's my pecl config :
and when i want to run the command pecl install pdo_mysql i get :
Any ideas?
Configuration (channel pecl.php.net):
Auto-discover new Channels auto_discover <not set>
Default Channel default_channel pecl.php.net
HTTP Proxy Server Address http_proxy <not set>
PEAR server [DEPRECATED] master_server pear.php.net
Default Channel Mirror preferred_mirror pecl.php.net
Remote Configuration File remote_config <not set>
PEAR executables directory bin_dir /usr/local/bin
PEAR documentation directory doc_dir /usr/local/lib/php/doc
PHP extension directory ext_dir ./
PEAR directory php_dir /usr/local/lib/php
PEAR Installer cache directory cache_dir /root/tmp/pear/cache
PEAR configuration file cfg_dir /usr/local/lib/php/cfg
directory
PEAR data directory data_dir /usr/local/lib/php/data
PEAR Installer download download_dir /root/tmp/pear/cache
directory
PHP CLI/CGI binary php_bin /usr/local/bin/php
php.ini location php_ini <not set>
PEAR Installer temp directory temp_dir /var/tmp/pear/temp
PEAR test directory test_dir /usr/local/lib/php/test
PEAR www files directory www_dir /usr/local/lib/php/www
Cache TimeToLive cache_ttl 3600
Preferred Package State preferred_state stable
Unix file mask umask 22
Debug Log Level verbose 1
PEAR password (for password <not set>
maintainers)
Signature Handling Program sig_bin /usr/bin/gpg
Signature Key Directory sig_keydir /usr/local/etc/pearkeys
Signature Key Id sig_keyid <not set>
Package Signature Type sig_type gpg
PEAR username (for username <not set>
maintainers)
User Configuration File Filename /root/.pearrc
System Configuration File Filename /usr/local/etc/pear.conf
downloading PDO_MYSQL-1.0.2.tgz ...
Starting to download PDO_MYSQL-1.0.2.tgz (14,778 bytes)
.....done: 14,778 bytes
downloading PDO-1.0.3.tgz ...
Starting to download PDO-1.0.3.tgz (52,613 bytes)
...done: 52,613 bytes
12 source files, building
running: phpize
Configuring for:
PHP Api Version: 20041225
Zend Module Api No: 20060613
Zend Extension Api No: 220060519
Cannot find autoconf. Please check your autoconf installation and the $PHP_AUTOCONF
environment variable is set correctly and then rerun this script.
ERROR: `phpize' failed
7 source files, building
running: phpize
Configuring for:
Any ideas?
