recompile PHP with Suhosin
fastsvc
does anyone know the steps to recompile PHP with Suhosin after installing directadmin?
can you help please?
For PHP 5.2.13:
./build set clean no
tar xzf php-5.2.13.tar.gz
wget http://download.suhosin.org/suhosin-patch-5.2.13-0.9.7.patch.gz
gunzip suhosin-patch-5.2.13-0.9.7.patch.gz
patch -p0 < suhosin-patch-5.2.13-0.9.7.patch
cd php-5.2.13
`../build used_configs | grep PHP5 | cut -d: -f2`
make
make install
/etc/init.d/httpd restart
cd ..
./build set clean yes
PHP 5.3.2:
tar xzf php-5.3.2.tar.gz
wget http://download.suhosin.org/suhosin-patch-5.3.2-0.9.9.1.patch.gz
gunzip suhosin-patch-5.3.2-0.9.9.1.patch.gz
patch -p0 < suhosin-patch-5.3.2-0.9.9.1.patch
cd php-5.3.2
make
make install
cd ..
Restart apache using the following command on FreeBSD systems (instead of /etc/init.d/httpd restart):
/usr/local/etc/rc.d/httpd  restart
Alternative way:
Do the same to the "patch -p0 < ....." line, then open "build" file, find:
FILE=${CWD}/php-${PHP5_VER}.tar.gz
checkFile ${FILE}
echo "Extracting ...";
tar xzf ${FILE}
Replace with (comment tar line out):
checkFile ${FILE}
#tar xzf ${FILE}
Save the file and run "./build php n".
first I got this error when i try :
i get this error:
# tar xzf php-5.3.2.tar.gz
tar: php-5.3.2.tar.gz: Cannot open: No such file or directory
tar: Error is not recoverable: exiting now
tar: Child returned status 2
tar: Error exit delayed from previous errors
so i edited options.conf and changed php to 5.3
but then i got this question when i typed :
File to patch: /usr/local/lib/php.ini
patching file /usr/local/lib/php.ini
Hunk #1 FAILED at 60.
Hunk #2 FAILED at 92.
2 out of 2 hunks FAILED -- saving rejects to file /usr/local/lib/php.ini.rej
can't find file to patch at input line 141
Perhaps you used the wrong -p or --strip option?
The text leading up to this was:
|diff -Nura php-5.3.2RC3/Zend/zend.h suhosin-patch-5.3.2-0.9.9.1/Zend/zend.h
|--- php-5.3.2RC3/Zend/zend.h 2010-02-03 21:44:43.000000000 +0100
|+++ suhosin-patch-5.3.2-0.9.9.1/Zend/zend.h 2010-03-04 11:51:11.000000000 +0100
File to patch:
no idea? so what do you think is next?
Check php for Suhosin
i formatted the server and started all over . then i used PHP 5.2.13 , when i was done i checked csf and i still have the message saying :
You should recompile PHP with Suhosin to add greater security to PHP
and i typed php -v i got this :
PHP 5.2.13 (cli) (built: Mar 14 2010 04:08:21)
Copyright (c) 1997-2010 The PHP Group
Zend Engine v2.2.0, Copyright (c) 1998-2010 Zend Technologies
any Idea?
Hi, I try
./build php n
And suhosin is not installed.
No error message
Ok, I follow this :
cd /usr/local/
wget http://www.hardened-php.net/suhosin/_media/suhosin-0.9.18.tgz
tar -zxvf suhosin-0.9.18.tgz
cd suhosin-0.9.18
phpize
(if needed : yum install autoconf )
./configure
make
make test
make install
ls –lah /usr/local/lib/php/extensions//no-debug-non-zts-20060613/
cp /usr/local/lib/php/extensions//no-debug-non-zts-20060613/suhosin.so /usr/lib64/php
Modify PHP.INI
Write :
extension_dir = /usr/lib64/php
In Dynamic Extensions ;
Write
extension=suhosin.so
Now :
php -v
PHP 5.2.13 (cli) (built: Mar 17 2010 09:41:38)
    with Suhosin v0.9.18, Copyright (c) 2002-2006, by Hardened-PHP Project
:D
I hope it can help you !!
(note it is the first time I can help someone :) )
I've updated my how-to post :) PHP package was extracted second time by the CustomBuild script, so the patched files were overwritten with "./build php n". There should be no problems now. Good luck!
hi, im having a problem with your guide...
[14:09:13] [email protected] [/usr/local/directadmin/custombuild/php-5.2.13]
shell-init: error retrieving current directory: getcwd: cannot access parent directories: No such file or directory
/usr/local/directadmin/custombuild/configure/ap2/configure.php5: line 3: ./configure: No such file or directory
[14:09:19] [email protected] [/usr/local/directadmin/custombuild/php-5.2.13]
>ls
[14:09:32] [email protected] [/usr/local/directadmin/custombuild/php-5.2.13]
>cd ..
Has you can see the build give error, ive tryed without ' aswell
[14:11:11] [email protected] [/usr/local/directadmin/custombuild/php-5.2.13]
[14:11:24] [email protected] [/usr/local/directadmin/custombuild/php-5.2.13]
>ls
[14:11:26] [email protected] [/usr/local/directadmin/custombuild/php-5.2.13]
>make
make: getcwd: No such file or directory
make: *** No targets specified and no makefile found.  Stop.
Seems that the build command clean the directory after configure (probably is a custombuild option)
What i should do for dont clean the directory after configure and why if is a security patch has not been implemented has option in custombuild system?
thanks
Make sure you execute "./build set clean no" after "./build update".
hehe exact what i was thinkin.. thanks for add in your tutorial...
now i come up with a new error :)
checking for MySQL UNIX socket location... /var/tmp/mysql.sock
configure: error: Cannot find MySQL header files under yes.
Note that the MySQL client library is not bundled anymore!
during compiling, of course im not able to make ^^
worked perfectly thank you.
I did make test..
EXPECTED FAILED TEST SUMMARY
output buffering - fatalism [tests/output/ob_011.phpt]
ob_start(): Ensure unerasable buffer cannot be flushed by ob_flush() [tests/outp                 ut/ob_start_basic_unerasable_005.phpt]
SPL: ArrayObject::exchangeArray() basic usage with object as underlying data sto                 re. [ext/spl/tests/arrayObject_exchangeArray_basic3.phpt]
but installed it anyway
error when trying in php 5.3
[root@server custombuild]# patch -p0 < suhosin-patch-5.3.2-0.9.9.1.patch
can't find file to patch at input line 4
|diff -Nura php-5.3.2RC3/Zend/Makefile.am suhosin-patch-5.3.2-0.9.9.1/Zend/Makefile.am
|--- php-5.3.2RC3/Zend/Makefile.am 2009-03-18 11:18:10.000000000 +0100
|+++ suhosin-patch-5.3.2-0.9.9.1/Zend/Makefile.am 2010-03-03 20:19:19.000000000 +0100
File to patch:
not works
hi,
i run this commands, but not appears how installed.
cd php-5.2.13
make
make install
cd ..
It's work fine for me. Thank you a lot
I have a question why after recompile php I check server security from csf it still show " WARNING You should recompile PHP with Suhosin to add greater security to PHP"
Any Idea ?
