Basic Firewall in Directadmin
walo
As the subject says...
this is my second request for this, and i think it is very simple to make an iptables handler as KISS firewall. Just that simple.
Block/allow ports/ips
APF is very easy to install and configure on DA server already. Do we really need another firewall in DA?
I should recommend CSF/LFD instead of APF/BFD. Since you have also a nice webinterface into DA with CSF/LFD.
I like it more when CSF/LFD will be default installed.
Maybe we can make a poll?
A Control Panel should control website stuff (apache, exim, mysql, bind, etc) and the systems admin should control the system at system level (SSH).... Thats my opinion anyway.
Exactly, but some customers that having a dedicated don't have knownledge about SSH, so then they can easy use the webinterface to manage the firewall.
Then they shouldn't have a dedicated server if they can't/don't understand Linux/etc..... Harsh I know.......
Besides, what walo suggested can be managed in webmin (free!) anyway..... which I have running side-by-side on my servers.....
No everything is web in a control panel. ftp, email, dns, sql, are noe web staff. a control panel is a gui for the server administration.
But APF if not part of directadmin
Other control panels offer firewall services - so I don't see what is wrong with requesting this. At the end of the day, it is a request.
Really? Name one control panel that lets you update & compile programs - to me thats server administration.
Besides, you need to use SSH to install control panels initially anyway.
You can update your server with YUM in the controlpanel of InterWorx. Without logging in to SSH.
Anyways, we dont have webmin on our servers, its useless for us.
@daveyw
I was going to say webmin too - but I didn't want to get into the argument ;)
and Peter did say "& compile programs" - that one is going to be hard to beat :)
This is the last reply from me....
DA is meant to administrate websites for our customers, that's its main purpose (personal opinion).... Yes, it has a few extra quirks for admins, like: mail queue, system backup, DA update page, top, custom apache config options, etc....
Of course, an IPTables option in DA could be useful, but to who? Not your customers - for admins, yes - and if you're an admin, then you have to know (a moderate amount of) Linux, bash, etc to start with........
As I said (webmin), theres other programs out there to help administrate at the system level, who have limited knowledge, which works perfectly along side DA - of course, you need to be careful about using webmin to edit stuff that DA uses.
Sorry that this thread has gone off topic.......
Just to point out again: FreeBSD and Linux have different firewall systems. To include a firewall in DirectAdmin, it would have to be written to create a generic file, and then there'd have to be separate code for converting the code to either iptables or (I believe IPFW) for FreeBSD.
Guess he wants an all in one solution so he doesnt have to learn how to properly administer a server via ssh. Once you get a good ruleset you shouldnt be needing to change it much anyways. If you **** up a rule you are still gonna lock yourself out of your server. So whats the point just so you can have a nice gui to do it from instead of doing it from ssh like you should be? So just use webmin ontop of directadmin if you want that. I dont want directadmin to be another cpanel with a bunch of bull**** that is not needed and makes it bloatware.
Of course, scsi, one advantage of having it in DirectAdmin, is that with enough intelligence it could keep us from making that dumb mistake that might cause us to look ourselves out of the server.
I agree that DirectAdmin doesn't need it, and the good folk at JBMC, publishers of DirectAdmin must as well, since they haven't responded.
I agree with others that this does not belong in DirectAdmin.
For one, because DirectAdmin should focus on excelling at what it does -- automation tasks and features for resellers/users, not the system administrator.
Second, DirectAdmin runs on Linux and FreeBSD which would have completely different firewall implementations.
There's no reason why 3rd party developers can't write a plugin for DA that can do this - if you want it, write it or pay someone to write it for you :)
Ok, I lied....... :P
One feature I'd really like to see added is this one - and I mean with no work-around, like suggested....
This is a feature from a customer's point of view, so I think its a valid one.
Regarding firewalls, we need to draw a line at some point where the scope of DirectAdmin stops. With our current model, firewalls are past that line. When it comes to one-time installations of things that don't scale with more Users, we tend to leave that to the system administrator. DirectAdmin is designed to automate the tasks required to add/manage users and domains on a webserver. I'm sure there are some exceptions to that rule, but at this time, firewalls are not one of them. Other one-time setups might be a root kit, or even a security guard with a rifle standing in front of your server... they're just out of the scope of DA.
Regarding the other request you've linked to, adding email to a subdomain will use all of the resource of a full domain anyway. If you want to allow them to create emails on their subdomains, simply allocate them more domains, and they can create a full new domain called sub.domain.com. It's not a workaround, it's how it's done.
