I'm trying to install PeopleAggregator (cms). PeopleAggregator was unable to run the setup because :
FATAL: XSL extension is not installed; your host probably needs to install a PHP XML/XSL package.
So i tryed to install it by doing this :
yum install libgcrypt-devel libxslt-devel
Both succesfully installed
Adding a couple of lines to configure.php5 in the custombuild/configure/ap2/ directory :
--with-dom=/usr/lib \
--with-dom-exslt=/usr/lib \
--with-dom-xslt=/usr/lib
then u used ./build clean followed by ./build php n
i noticed during the build this message :
Notice: Following unknown configure options were used:
--with-dom=/usr/lib
--enable-xslt
Check './configure --help' for available options
(Why are they unknown ?? does that effect anything?)
But i just ignored in tryed installing PeopleAggregator anyway but it didnt work same error as before.
When i use php -i | grep DOM i get :
DOM/XML => enabled
DOM/XML API Version => 20031129
When i use php -i | grep XSL i get nothing
i have :
Compiled on Redhat CentOS 5.0
Server Version 1.33.1
Current Available Version 1.331000
Last Updated Mon Mar 23 16:07:11 2009
Does anyone know the solution for this problem ? im really getting frustrated
With kind regards
--with-dom=/usr/lib
--enable-xslt
DOM/XML => enabled
i have :
With kind regards
