[PLUGIN] ConfigServer Security & Firewall
Ok disregard this. Even though It passes the check via Plugin it will still fails when you try to restart csf/lfd. You will not be able to take it out of test mode so it' unless to me. I'll report back if I manage to resolve it but it's not looking good.
That's odd, you could try to update your server, and re-install it, because it worked for me without a problem.
csf removed from plugin
i have a problem with csf in directadmin.
i installed csf 2 month ago , and working fine .but when i go to directadmin panel and go to ConfigServer Firewall&Security in extra features
i see a blank page and havent any csf option , but before i have very option in this plugins
see attachment
problem dose not solve with csf restarting and upgrading.
how i can solved this problem
tnx
sorry from all !!!!
attached again
hi
when i try to update csf i see this message
[root@server1 ~]# csf -u
csf is already at the latest version: v5.10
but the problem dosent solve.
I guess you can simply resolve this by reinstalling CSF/LFD.
Only don't forget to backup csf.pignore, csf.conf, csf.allow, csf.deny
What if you enable TESTING in csf.conf, restarting csf AND lfd. Still nothing, then it has nothing to do with CSF/LFD.
i uninstalling CSF and then install it again.
but the problem dose not solve
please help me
Is anyone getting this error when trying to upgrade? I get this on two boxes but a few boxes actually work fine. They are all configured the same as far as my memory goes.
Timeout on configserver.com during the upgrade
hi
but the problem dose not solve.
and now i recieve the email with this subject
New Message: The service 'lfd' on server (ServerName) is currently down
A new message or response with subject:
has arrived for you to view.
Follow this link to view it:
http://myserver.com:2222/CMD_TICKET?action=view&number=000000142&type=ticket
how i can solved this problem.
if you want i should take a look on your box, i never had this problem so.. ive no idea about how to solve.. but.. i should try if you want. just pm me.
regards
hi
is it vps ? openvz?
this problem is occur when huge load apply on server network. like DOS attack. any way you must try it on command line :
csf -e
ors service csf start
Phoee... I have to think very hard. Because I had this problem and there is a very easy solution for it.
Ah... found it, post #45 in this thread:
Figured it out. It was because /usr/bin/perl wasn't given the correct permissions.
Maybe this will fix your problem too, in fact I'm quite sure of it.
