httpd' on server suddenly stop
seachen
my server httpd' on server suddenly stop. i try reboot it, but it is not working
may i know how to solve it?
now the httpd suddenly stop!
httpd error :
[Sun Feb 06 15:22:42 2011] [warn] RSA server certificate CommonName (CN) `localhost' does NOT match server name!?
[Sun Feb 06 15:22:42 2011] [warn] Init: SSL server IP/port conflict: localhost:443 (/etc/httpd/conf/extra/httpd-vhosts.conf:38) vs. www.newmsr.com:443 (/usr/local/directadmin/data/users/newmsr/httpd.conf:49)
[Sun Feb 06 15:22:42 2011] [warn] Init: You should not use name-based virtual hosts in conjunction with SSL!!
[Sun Feb 06 15:22:42 2011] [emerg] (28)No space left on device: Couldn't create accept lock (/var/log/httpd/accept.lock.28824) (5)
[Sun Feb 06 15:23:02 2011] [warn] RSA server certificate CommonName (CN) `localhost' does NOT match server name!?
[Sun Feb 06 15:23:02 2011] [warn] Init: SSL server IP/port conflict: localhost:443 (/etc/httpd/conf/extra/httpd-vhosts.conf:38) vs. www.newmsr.com:443 (/usr/local/directadmin/data/users/newmsr/httpd.conf:49)
[Sun Feb 06 15:23:02 2011] [warn] Init: You should not use name-based virtual hosts in conjunction with SSL!!
[Sun Feb 06 15:23:02 2011] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Sun Feb 06 15:23:02 2011] [warn] module clamav_module is already loaded, skipping
[Sun Feb 06 15:23:03 2011] [warn] RSA server certificate CommonName (CN) `localhost' does NOT match server name!?
[Sun Feb 06 15:23:03 2011] [warn] Init: SSL server IP/port conflict: localhost:443 (/etc/httpd/conf/extra/httpd-vhosts.conf:38) vs. www.newmsr.com:443 (/usr/local/directadmin/data/users/newmsr/httpd.conf:49)
[Sun Feb 06 15:23:03 2011] [warn] Init: You should not use name-based virtual hosts in conjunction with SSL!!
[Sun Feb 06 15:23:03 2011] [warn] pid file /var/run/httpd.pid overwritten -- Unclean shutdown of previous Apache run?
[Sun Feb 06 15:23:03 2011] [emerg] (28)No space left on device: Couldn't create accept lock (/var/log/httpd/accept.lock.28857) (5)
[Sun Feb 06 15:23:12 2011] [warn] RSA server certificate CommonName (CN) `localhost' does NOT match server name!?
[Sun Feb 06 15:23:12 2011] [warn] Init: SSL server IP/port conflict: localhost:443 (/etc/httpd/conf/extra/httpd-vhosts.conf:38) vs. www.newmsr.com:443 (/usr/local/directadmin/data/users/newmsr/httpd.conf:49)
[Sun Feb 06 15:23:12 2011] [warn] Init: You should not use name-based virtual hosts in conjunction with SSL!!
[Sun Feb 06 15:23:12 2011] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Sun Feb 06 15:23:12 2011] [warn] module clamav_module is already loaded, skipping
[Sun Feb 06 15:23:13 2011] [warn] RSA server certificate CommonName (CN) `localhost' does NOT match server name!?
[Sun Feb 06 15:23:13 2011] [warn] Init: SSL server IP/port conflict: localhost:443 (/etc/httpd/conf/extra/httpd-vhosts.conf:38) vs. www.newmsr.com:443 (/usr/local/directadmin/data/users/newmsr/httpd.conf:49)
[Sun Feb 06 15:23:13 2011] [warn] Init: You should not use name-based virtual hosts in conjunction with SSL!!
[Sun Feb 06 15:23:13 2011] [emerg] (28)No space left on device: Couldn't create accept lock (/var/log/httpd/accept.lock.28877) (5)
[Sun Feb 06 15:23:26 2011] [warn] RSA server certificate CommonName (CN) `localhost' does NOT match server name!?
[Sun Feb 06 15:23:26 2011] [warn] Init: SSL server IP/port conflict: localhost:443 (/etc/httpd/conf/extra/httpd-vhosts.conf:38) vs. www.newmsr.com:443 (/usr/local/directadmin/data/users/newmsr/httpd.conf:49)
[Sun Feb 06 15:23:26 2011] [warn] Init: You should not use name-based virtual hosts in conjunction with SSL!!
[Sun Feb 06 15:23:26 2011] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Sun Feb 06 15:23:26 2011] [warn] module clamav_module is already loaded, skipping
[Sun Feb 06 15:23:27 2011] [warn] RSA server certificate CommonName (CN) `localhost' does NOT match server name!?
[Sun Feb 06 15:23:27 2011] [warn] Init: SSL server IP/port conflict: localhost:443 (/etc/httpd/conf/extra/httpd-vhosts.conf:38) vs. www.newmsr.com:443 (/usr/local/directadmin/data/users/newmsr/httpd.conf:49)
[Sun Feb 06 15:23:27 2011] [warn] Init: You should not use name-based virtual hosts in conjunction with SSL!!
[Sun Feb 06 15:23:27 2011] [warn] pid file /var/run/httpd.pid overwritten -- Unclean shutdown of previous Apache run?
[Sun Feb 06 15:23:27 2011] [emerg] (28)No space left on device: Couldn't create accept lock (/var/log/httpd/accept.lock.28904) (5)
[Sun Feb 06 15:23:43 2011] [warn] RSA server certificate CommonName (CN) `localhost' does NOT match server name!?
[Sun Feb 06 15:23:43 2011] [warn] Init: SSL server IP/port conflict: localhost:443 (/etc/httpd/conf/extra/httpd-vhosts.conf:38) vs. www.newmsr.com:443 (/usr/local/directadmin/data/users/newmsr/httpd.conf:49)
[Sun Feb 06 15:23:43 2011] [warn] Init: You should not use name-based virtual hosts in conjunction with SSL!!
[Sun Feb 06 15:23:43 2011] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Sun Feb 06 15:23:43 2011] [warn] module clamav_module is already loaded, skipping
[Sun Feb 06 15:23:44 2011] [warn] RSA server certificate CommonName (CN) `localhost' does NOT match server name!?
[Sun Feb 06 15:23:44 2011] [warn] Init: SSL server IP/port conflict: localhost:443 (/etc/httpd/conf/extra/httpd-vhosts.conf:38) vs. www.newmsr.com:443 (/usr/local/directadmin/data/users/newmsr/httpd.conf:49)
[Sun Feb 06 15:23:44 2011] [warn] Init: You should not use name-based virtual hosts in conjunction with SSL!!
[Sun Feb 06 15:23:44 2011] [emerg] (28)No space left on device: Couldn't create accept lock (/var/log/httpd/accept.lock.28958) (5)
directadmin error:
011:02:06-15:19:01: service httpd wasn't running, starting it
2011:02:06-15:19:12: service httpd didn't start, re-starting it
2011:02:06-15:20:01: service httpd wasn't running, starting it
2011:02:06-15:20:12: service httpd didn't start, re-starting it
2011:02:06-15:21:01: service httpd wasn't running, starting it
2011:02:06-15:21:12: service httpd didn't start, re-starting it
2011:02:06-15:23:01: service httpd wasn't running, starting it
2011:02:06-15:24:01: service httpd wasn't running, starting it
2011:02:06-15:24:12: service httpd didn't start, re-starting it
2011:02:06-15:24:13: Error restarting service httpd : uid 0 gid 0 : /sbin/service httpd restart                         >>/dev/null 2>>/dev/null
what is the problem???
after server reboot its work and in httpd error log is:
shmem.c:35: cannot create shared memory /var/tmp/clamav.shm: statistics will not be available
Hi jlasman,Thank you
I need a simple explanation..Iam Afraid of any fatal error..
1)Check your disk space.i Attached image..that what mean? my space is 2x500
2) Review filesystem quotas(i Attached image..that look ok)?
3) I'd assume if you're reading this article, Apache has stopped running. Run this command as root:
# ipcs -s
i see a list of semaphores, to Clear them out with this command:
I tried placing this command, but there is still much! do i need to type the command like this?
# for i in `ipcs -s | awk '/httpd/ {print $2}'`; do (ipcrm -s $i); done
i've Add this to /etc/sysctl.conf:
kernel.msgmni = 1024
kernel.sem = 250 256000 32 1024
you sure this will not Destroy any thing?
thank you man:)
what you mean? i have no space? no way!
Service Description IS-13737 (RS Dedicated Server)
- Intel Core2 Quad Q9650
- 8GB Memory
- 2x 500GB 7200rpm Hard Disk
- CentOS 5.x
- JBMC Software DirectAdmin
- 10 TB Bandwidth
And i have backup server:
NAS Accounts
Share
[NAS] \\10.0.5.8\IS-13737
Free : 41.8 GB
Reseller Stats for admin:
Setting Current Usage Allocated Maximum Usage
Bandwidth: (MB) 49803 unlimited unlimited
Disk Space: (MB) 38959 unlimited unlimited
Processor Speed (MHz) 1998.000
Total Memory: 8303964 kB
Free Memory : 5132692 kB
Any idea??:D
do you mean df -h? if yes i've attached image please take a look
thank you
Please see and follow this link [carlosrivero.com] hope it helps
Hi Peter,
So this line or command will fix the problem (Follow command need edit?)
ipcs -s | grep apache | perl -e 'while (<STDIN>) { @a=split(/\s+/); print `ipcrm sem $a[1]`}'
wait for your replay!
thank you,
should help, even fix it.
What distro is it? CentOS?
Do you still want my help? If so, hit me up on WLM
Hi Peter,You are the light of this great forum! thank you man.we will talk!
And A Big thank for tomtom901,jlasman,zeiter
:D
Unfortunately httpd still always stop!
Sometimes when I add a new domain
Stopped yesterday when I deleted user
Today suddenly stopped without reason
I do not know why and what to do !
There is thing it is not prepared correctly!
please any idea?
Hi SeLLeRoNe ,
could i rebuild apache with updatescript??
what is the command please? i attached photo
thank you man
after done the appach not start!
i made reboot for system to let him start :(
I found this good website which explain some of the reasons that may be causing the problem
I have done all the tests, and data were successfully!
When I arrived to the following test:
Check for port 80 and 443
# netstat -tulpn
# netstat -tulpn | grep
# netstat -tulpn | grep ':80'
This was the result:
[root@server ~]# netstat -tulpn
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address               Foreign Address             State       PID/Program name
tcp        0      0 0.0.0.0:993                 0.0.0.0:*                   LISTEN      2523/dovecot
tcp        0      0 0.0.0.0:995                 0.0.0.0:*                   LISTEN      2523/dovecot
tcp        0      0 0.0.0.0:3306                0.0.0.0:*                   LISTEN      2675/mysqld
tcp        0      0 0.0.0.0:587                 0.0.0.0:*                   LISTEN      3112/exim
tcp        0      0 0.0.0.0:747                 0.0.0.0:*                   LISTEN      2261/rpc.statd
tcp        0      0 127.0.0.1:3310              0.0.0.0:*                   LISTEN      3525/clamd
tcp        0      0 0.0.0.0:2222                0.0.0.0:*                   LISTEN      3102/directadmin
tcp        0      0 0.0.0.0:110                 0.0.0.0:*                   LISTEN      2523/dovecot
tcp        0      0 0.0.0.0:143                 0.0.0.0:*                   LISTEN      2523/dovecot
tcp        0      0 0.0.0.0:111                 0.0.0.0:*                   LISTEN      2218/portmap
tcp        0      0 127.0.0.1:54321             0.0.0.0:*                   LISTEN      3129/avgtcpd
tcp        0      0 127.0.0.1:54322             0.0.0.0:*                   LISTEN      3129/avgtcpd
tcp        0      0 10.0.6.45:53                0.0.0.0:*                   LISTEN      3605/named
tcp        0      0 78.129.175.66:53            0.0.0.0:*                   LISTEN      3605/named
tcp        0      0 78.129.175.65:53            0.0.0.0:*                   LISTEN      3605/named
tcp        0      0 127.0.0.1:53                0.0.0.0:*                   LISTEN      3605/named
tcp        0      0 127.0.0.1:631               0.0.0.0:*                   LISTEN      2585/cupsd
tcp        0      0 127.0.0.1:953               0.0.0.0:*                   LISTEN      3605/named
tcp        0      0 0.0.0.0:25                  0.0.0.0:*                   LISTEN      3112/exim
tcp        0      0 :::80                       :::*                        LISTEN      3210/httpd
tcp        0      0 :::21                       :::*                        LISTEN      3318/proftpd: (acce
tcp        0      0 :::22                       :::*                        LISTEN      2574/sshd
tcp        0      0 :::443                      :::*                        LISTEN      3210/httpd
udp        0      0 10.0.6.45:53                0.0.0.0:*                               3605/named
udp        0      0 78.129.175.66:53            0.0.0.0:*                               3605/named
udp        0      0 78.129.175.65:53            0.0.0.0:*                               3605/named
udp        0      0 127.0.0.1:53                0.0.0.0:*                               3605/named
udp        0      0 0.0.0.0:68                  0.0.0.0:*                               2033/dhclient
udp        0      0 0.0.0.0:741                 0.0.0.0:*                               2261/rpc.statd
udp        0      0 0.0.0.0:744                 0.0.0.0:*                               2261/rpc.statd
udp        0      0 0.0.0.0:5353                0.0.0.0:*                               3395/avahi-daemon:
udp        0      0 0.0.0.0:111                 0.0.0.0:*                               2218/portmap
udp        0      0 0.0.0.0:33904               0.0.0.0:*                               3395/avahi-daemon:
udp        0      0 0.0.0.0:631                 0.0.0.0:*                               2585/cupsd
udp        0      0 :::33679                    :::*                                    3395/avahi-daemon:
udp        0      0 :::5353                     :::*                                    3395/avahi-daemon:
you can see there is two things use port 80 and 443
in that site he said: If other process using port 80 / 443, you need to stop them or assign another port to Apache.
how can i do that please??
