SeLLeRoNe
Super Moderator
oh ok
thanks for precisation
2011-02-02 18:12:25 H=(din-31-75-231-77.ipcom.comunitel.net) [77.231.75.31] F=<[email protected]> rejected RCPT <[B][email protected][/B]>: Sender verify failed
#EDIT#41:
#EDIT#42:
# deny message = Email blocked by $dnslist_domain
# hosts = !+relay_hosts
# domains = +use_rbl_domains
# domains = !+skip_rbl_domains
# !authenticated = *
# dnslists = \
# rhsbl.ahbl.org/$sender_address_domain
One: somene will need to do a diff on my exim.pl file vs the one at DirectAdmin, and let me know what it is and I'll figure out the problem with the DirectAdmin exim.pl file.
This message was created automatically by mail delivery software.
A message that you sent could not be delivered to one or more of its
recipients. This is a permanent error. The following address(es) failed:
[email protected]
SMTP error from remote mail server after RCPT TO:<[email protected]>:
host mail.crazynetwork.it [89.97.218.93]: 550-Verification failed for <[email protected]>
550-Unrouteable address
550 Sender verify failed
2011-02-24 17:19:29 H=mail.reasonthat.com (w3service.reasonthat.com) [89.97.218.91] sender verify fail for <[email protected]>: Unrouteable address
2011-02-24 17:19:29 H=mail.reasonthat.com (w3service.reasonthat.com) [89.97.218.91] F=<[email protected]> rejected RCPT <[email protected]>: Sender verify failed
Which should I change? The documentation or the behavior? I recommend changing the documentation and leaving the behavior. Only the domain is checked, and not the full email address.
Anybody feel differently?
verify = sender should do the following: for local senders: verify the user and domain exist; for non-local senders verify the sending domain exists.
2011-03-03 13:36:44 1Pv7ls-0004Dp-AR <= [email protected] H=localhost (www.prism.nl) [127.0.0.1] P=esmtpa A=login:test S=800 [email protected] T="Test" from <[email protected]> for w******@gmail.com
2011-03-03 13:36:45 1Pv7ls-0004Dp-AR => w******@gmail.com F=<[email protected]> R=lookuphost T=remote_smtp S=831 H=gmail-smtp-in.l.google.com [74.125.79.27] X=TLSv1:RC4-SHA:128 C="250 2.0.0 OK 1299155805 w12si2184449eeh.80"
2011-03-03 13:36:45 1Pv7ls-0004Dp-AR Completed
