Pb Update Dovecot 2.0.13 to 2.0.15
Hashut
Hello, I have a problem to update dovecote
error
mv -f .deps/mmap-util.Tpo .deps/mmap-util.Plo
mv -f .deps/mountpoint.Tpo .deps/mountpoint.Plo
make[4]: Leaving directory `/usr/local/directadmin/custombuild/dovecot-2.0.15/src/lib'
make[3]: *** [all] Error 2
make[3]: Leaving directory `/usr/local/directadmin/custombuild/dovecot-2.0.15/src/lib'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/usr/local/directadmin/custombuild/dovecot-2.0.15/src'
make[1]: Leaving directory `/usr/local/directadmin/custombuild/dovecot-2.0.15'
make: *** [all] Error 2
have you any idea please
thank you
Was you already using dovecot?
Maybe more long log is more helpful but.. for now i should just suggest to remove dovecot* in your custombuild directory, and then do
./build dovecot
Regards
Ive already asked for a longer log, you should post more detail of the compilation so we should check what is missing and where is falling.
Regards
Here are all the errors
module-dir.c: In function 'module_file_get_name':
module-dir.c:587: error: 'MODULE_SUFFIX' undeclared (first use in this function)
module-dir.c:587: error: (Each undeclared identifier is reported only once
module-dir.c:587: error: for each function it appears in.)
mv -f .deps/mmap-anon.Tpo .deps/mmap-anon.Plo
/bin/sh ../../libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I../.. -I/usr/kerberos/include -std=gnu99 -g -O2 -Wall -W -Wmissing-prototypes -Wmissing-declarations -Wpointer-arith -Wchar-subscripts -Wformat=2 -Wbad-function-cast -Wstrict-aliasing=2 -MT mountpoint.lo -MD -MP -MF .deps/mountpoint.Tpo -c -o mountpoint.lo mountpoint.c
make[4]: *** [module-dir.lo] Error 1
make[4]: *** Waiting for unfinished jobs....
mv -f .deps/mkdir-parents.Tpo .deps/mkdir-parents.Plo
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I../.. -I/usr/kerberos/include -std=gnu99 -g -O2 -Wall -W -Wmissing-prototypes -Wmissing-declarations -Wpointer-arith -Wchar-subscripts -Wformat=2 -Wbad-function-cast -Wstrict-aliasing=2 -MT mountpoint.lo -MD -MP -MF .deps/mountpoint.Tpo -c mountpoint.c -fPIC -DPIC -o .libs/mountpoint.o
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I../.. -I/usr/kerberos/include -std=gnu99 -g -O2 -Wall -W -Wmissing-prototypes -Wmissing-declarations -Wpointer-arith -Wchar-subscripts -Wformat=2 -Wbad-function-cast -Wstrict-aliasing=2 -MT mountpoint.lo -MD -MP -MF .deps/mountpoint.Tpo -c mountpoint.c -o mountpoint.o >/dev/null 2>&1
I understand why this is the
Do you have an idea
thank
what os are you using?
on centos run yum install openssl-devel
on debian should be apt-get install openssl-dev (or -devel if -dev give error)
then try again build dovecot.
Regards
there are several in krb5
freeradius-krb5 - kerberos module for FreeRADIUS server
gosa-plugin-mit-krb5-schema - LDAP schema for GOsa² mit-krb5 plugin
gosa-plugin-mit-krb5 - mit-krb5 plugin for GOsa²
libkrb5-26-heimdal - Heimdal Kerberos - libraries
krb5-config - Configuration files for Kerberos Version 5
krb5-auth-dialog - tray applet for reauthenticating kerberos tickets
krb5-admin-server - MIT Kerberos master server (kadmind)
krb5-doc - Documentation for MIT Kerberos
krb5-kdc-ldap - MIT Kerberos key server (KDC) LDAP plugin
krb5-kdc - MIT Kerberos key server (KDC)
krb5-multidev - Development files for MIT Kerberos without Heimdal conflict
krb5-pkinit - PKINIT plugin for MIT Kerberos
krb5-user - Basic programs to authenticate using MIT Kerberos
libgssapi-krb5-2 - MIT Kerberos runtime libraries - krb5 GSS-API Mechanism
libkrb5-3 - MIT Kerberos runtime libraries
libkrb5-dbg - Debugging files for MIT Kerberos
libkrb5-dev - Headers and development libraries for MIT Kerberos
libkrb53 - transitional package for MIT Kerberos libraries
libkrb5support0 - MIT Kerberos runtime libraries - Support library
libauthen-krb5-admin-perl - Perl extension for MIT Kerberos 5 admin interface
libauthen-krb5-perl - Perl interface to Kerberos 5 API
libauthen-krb5-simple-perl - Perl module for authentication using Kerberos 5
libheimdal-kadm5-perl - Perl module to administer a Heimdal Kerberos KDC
libkrb5-ruby-doc - Documentation for libkrb5-ruby
libkrb5-ruby1.8 - Basic Kerberos ruby binding (Ruby 1.8)
libkrb5-ruby1.9.1 - Basic Kerberos ruby binding (Ruby 1.9.1)
libkrb5-ruby - Basic Kerberos ruby binding
libpam-krb5 - PAM module for MIT Kerberos
libpam-openafs-kaserver - AFS distributed filesystem kaserver PAM module
openafs-client - AFS distributed filesystem client support
openafs-krb5 - AFS distributed filesystem Kerberos 5 integration
ssh-krb5 - secure shell client and server (transitional package)
libpam-krb5-migrate-heimdal - PAM module for migrating to Kerberos
shishi - Command line client for the Shishi Kerberos v5 implementation
libzephyr4-krb5 - The original "Instant Message" system libraries with Kerberos V
zephyr-server-krb5 - The original "Instant Message" system-server with Kerberos 5
krb5-clients - Secure replacements for ftp, telnet and rsh using MIT Kerberos
krb5-ftpd - Secure FTP server supporting MIT Kerberos
krb5-rsh-server - Secure replacements for rshd and rlogind using MIT Kerberos
krb5-telnetd - Secure telnet server supporting MIT Kerberos
