./update.script SUHOSIN
--2012-02-07 02:31:07--  http://download.suhosin.org/suhosin-0.9.32.1.tar.gz
Resolving download.suhosin.org... 85.214.93.8
Connecting to download.suhosin.org|85.214.93.8|:80... connected.
Length: 119117 (116K) [application/x-gzip]
Saving to: “suhosin-0.9.32.1.tar.gz”
100%[======================================>] 119,117      278K/s   in 0.4s
2012-02-07 02:31:12 (278 KB/s) - “suhosin-0.9.32.1.tar.gz” saved [119117/119117]
MD5 valid.
suhosin-0.9.32.1/
suhosin-0.9.32.1/aes.c
suhosin-0.9.32.1/Changelog
suhosin-0.9.32.1/compat_snprintf.c
suhosin-0.9.32.1/config.m4
suhosin-0.9.32.1/config.w32
suhosin-0.9.32.1/CREDITS
suhosin-0.9.32.1/crypt.c
suhosin-0.9.32.1/crypt_blowfish.c
suhosin-0.9.32.1/crypt_md5.c
suhosin-0.9.32.1/crypt_md5.h
suhosin-0.9.32.1/crypt_win32.c
suhosin-0.9.32.1/crypt_win32.h
suhosin-0.9.32.1/ex_imp.c
suhosin-0.9.32.1/execute.c
suhosin-0.9.32.1/header.c
suhosin-0.9.32.1/ifilter.c
suhosin-0.9.32.1/log.c
suhosin-0.9.32.1/mbregex/
suhosin-0.9.32.1/mbregex.h
suhosin-0.9.32.1/memory_limit.c
suhosin-0.9.32.1/php_suhosin.h
suhosin-0.9.32.1/post_handler.c
suhosin-0.9.32.1/rfc1867.c
suhosin-0.9.32.1/session.c
suhosin-0.9.32.1/sha256.c
suhosin-0.9.32.1/sha256.h
suhosin-0.9.32.1/suhosin.c
suhosin-0.9.32.1/suhosin.ini
suhosin-0.9.32.1/suhosin_logo.h
suhosin-0.9.32.1/suhosin_rfc1867.h
suhosin-0.9.32.1/tests/
suhosin-0.9.32.1/treat_data.c
suhosin-0.9.32.1/ufilter.c
suhosin-0.9.32.1/tests/empty.inc
suhosin-0.9.32.1/tests/executor/
suhosin-0.9.32.1/tests/filter/
suhosin-0.9.32.1/tests/funcs/
suhosin-0.9.32.1/tests/include/
suhosin-0.9.32.1/tests/skipif.inc
suhosin-0.9.32.1/tests/skipifcli.inc
suhosin-0.9.32.1/tests/skipifnotcli.inc
suhosin-0.9.32.1/tests/include/include_constant.phpt
suhosin-0.9.32.1/tests/include/include_etc_passwd.phpt
suhosin-0.9.32.1/tests/include/include_once_constant.phpt
suhosin-0.9.32.1/tests/include/include_once_tmpvar.phpt
suhosin-0.9.32.1/tests/include/include_once_var.phpt
suhosin-0.9.32.1/tests/include/include_tmpvar.phpt
suhosin-0.9.32.1/tests/include/include_var.phpt
suhosin-0.9.32.1/tests/include/require_constant.phpt
suhosin-0.9.32.1/tests/include/require_once_constant.phpt
suhosin-0.9.32.1/tests/include/require_once_tmpvar.phpt
suhosin-0.9.32.1/tests/include/require_once_var.phpt
suhosin-0.9.32.1/tests/include/require_tmpvar.phpt
suhosin-0.9.32.1/tests/include/require_var.phpt
suhosin-0.9.32.1/tests/funcs/crypt_blowfish.phpt
suhosin-0.9.32.1/tests/funcs/crypt_ext_des.phpt
suhosin-0.9.32.1/tests/funcs/crypt_md5.phpt
suhosin-0.9.32.1/tests/funcs/crypt_std_des.phpt
suhosin-0.9.32.1/tests/funcs/sha256.phpt
suhosin-0.9.32.1/tests/filter/get_globals.phpt
suhosin-0.9.32.1/tests/executor/disable_emod_off.phpt
suhosin-0.9.32.1/tests/executor/disable_emod_on.phpt
suhosin-0.9.32.1/tests/executor/disable_eval_off.phpt
suhosin-0.9.32.1/tests/executor/disable_eval_on.phpt
suhosin-0.9.32.1/tests/executor/memory_limit.phpt
suhosin-0.9.32.1/tests/executor/memory_limit_other_hardlimit.phpt
suhosin-0.9.32.1/tests/executor/negative_memory_limit.phpt
suhosin-0.9.32.1/tests/executor/preg_replace.phpt
suhosin-0.9.32.1/tests/executor/preg_replace_error.phpt
suhosin-0.9.32.1/tests/executor/recursion_maxdepth.phpt
suhosin-0.9.32.1/mbregex/COPYING.LIB
suhosin-0.9.32.1/mbregex/mbregex.h
Configuring for:
PHP Api Version:         20041225
Zend Module Api No:      20060613
Zend Extension Api No:   220060519
Cannot find autoconf. Please check your autoconf installation and the
$PHP_AUTOCONF environment variable. Then, rerun this script.
./update.script: line 1356: ./configure: No such file or directory
make: *** No targets specified and no makefile found.  Stop.
make: *** No rule to make target `install'.  Stop.
Suhosin 0.9.32.1 install/update Done
