Thank you, @smtalk. I have now upgraded two servers to Apache 2.4.9, they are running CentOS 6.5 64bit, one with php 5.5.x and another with php 5.4.x, and there was no problems. I will now upgrade the rest of my servers. I did not run ./build rewrite_confs, because I am thinking it is better to wait until the next version of DirectAdmin is released before I do that.
However when I check my servers at https://www.ssllabs.com/ssltest/index.html , I get "only" a "A-", it would be nice to get a "A" without the "-".
Is this something that you can consider to change/improve as default for custombuild/apache? Here are the reason I get the "-" when running test on the link above:
(Click on "MORE INFO" link in the quoted text for information about these things.) It would be great if the default DirectAdmin settings for Apache could be with changes for these two things. Thanks!
RC4 cipher is used with TLS 1.1 or newer protocols, even though stronger ciphers are available. Grade reduced to A-. MORE INFO »
The server does not support Forward Secrecy with the reference browsers. Grade reduced to A-. MORE INFO »
