Wanabo
Thanks zEitEr!
Yes indeed I use PHP-FPM, instead of httpd.
I did a manual install of mod_security like I did on my old server. It works but I'm not sure it is properly configured for nginx. Is this possible with custom build?
It could be related to the problem I have using SSL. Or more likely is a nginx problem.
When viewing my site as http://subdomain.example.com all css, js and graphics are loaded.
When viewing my site as https://subdomain.example.com no css is loaded. js and graphics seems fine.
Edit: It seemed: "Use a symbolic link from private_html to public_html - allows for same data in http and https" was not set! I expected this to be set, but the user backup did not restore this setting. Problem solved.
