DirectAdmin 1.50.0 has been released
DirectAdmin Support
Administrator
Staff member
We're pleased to announce the release of DirectAdmin 1.50.0
Version: 1.50.0
This is a major release with numerous new features and fixes.
The full list can be Found Here
New Features
plus many more.
Bugfixes
Plus various other fixes.
Have fun!
Version: 1.50.0
New Features
  • LetsEncrypt automatic 1-click install of FREE SSL certificates.
Have fun!
This is just great! Now I'm just wondering (if possible) how to added subdomains to the cert. Can we just comma seperate them? Don't want to test it too much due too the rate limit. :)
I have enabled the SSL functie (Lets Encrypt), but there is no checkbox on the page with 'Free & automatic certificate from Let's Encrypt'.
In Users\ssl.htm is no text shown.
|*if LETSENCRYPT="1"|
<br><input type=radio name=request value="letsencrypt" disabled>Free & automatic certificate from <a class='listtitle' target=_blank href="https://letsencrypt.org/">Let's Encrypt</a></td>
|*endif|
updated and did this as you recommended
./build rewrite_confs
still got this issue
Challenge is invalid. Details: Invalid response
john sent you email about the issue
I had to set letsencrypt=2, with 1 it would not work.
Is it possible to request a SSL certificate for my subdomains?
Works fine for me with letsencrypt=1
# grep well /etc/httpd/conf/extra/httpd-alias.conf
Alias /.well-known /var/www/html/.well-known
ACTION REQUIRED
You must have the .well-known Alias pointing to /var/www/html/.well-known, so update your CustomBuild configs:
http://www.directadmin.com/features.php?id=1828
Add you subdomain as a domain with its own public_html.
nah with =2
and ive made sure to restart DA- i want my ssl to be on /home/admin/username/public_html
Is there no other way? It would be a lot easier if DirectAdmin would request a SSL certificate for the subdomains as well. The third-party plugin for Let's Encrypt support in DirectAdmin was able to do this.
Directadmin does not allow to install separate SSL certs for subdomains.
Whether you use
letsencrypt=1 with /var/www/html/.well-known
or letsencrypt=2 with /home/user/domains/domain.com/public_html/.well-known
it regulates only where a file will be set which is used once for domain ownership validation. All the certs are stored as always in /usr/local/directadmin/data/users/<user>/domains/
yes i know and thats the issue it doesnt create certificate at all there
the folders are there
Getting challenge from acme-server...
Waiting for domain verification...
Challenge is invalid. Details: Invalid response from http://domain/.well-known/acme-challenge/M68DRuvdR9DhC3WGWDP7IrmCnN6vFOAfzO7TOZ4o3to [ip]: 404. Exiting...
Whether you use
What error do you get?
Currently I see an error on one server of the following kind:
Command::doCommand(/CMD_SSL)Domain domain.com  defaultdomain=yes usertype=2 multiple_ips=0 enable_ssl_sni=1
Dynamic(api=0, error=1):
        text='Cannot Execute Your Request'
        result='Getting challenge for domain.com from acme-server...<br>
Waiting for domain verification...<br>
Challenge is invalid. Details: Could not connect to http://domain.com/.well-known/acme-challenge/R4eaNjBi9gwB6Tio-Ui3qtvi4HIStPU46gvsX8RFHKI. Exiting...
at the same too 200 code in logs:
66.133.109.36 - - [21/Feb/2016:18:50:36 +0600] "GET /.well-known/acme-challenge/R4eaNjBi9gwB6Tio-Ui3qtvi4HIStPU46gvsX8RFHKI HTTP/1.1" 200 108 "-" "Mozilla/5.0 (compatible; Let's Encrypt validation server; +https://www.letsencrypt.org)"
What might it be caused by?
letsencrypt fails with me with:
Getting challenge for cphpvb.net from acme-server...
[: : bad number
[: : bad number
/usr/local/directadmin/scripts/letsencrypt.sh: cannot create /var/www/html/.well-known/acme-challenge/: Is a directory
[: -ne: unexpected operator
rm: /var/www/html/.well-known/acme-challenge/: is a directory
Challenge is . Details: . Exiting...
p.s. both =1 and =2 options
The first ouput is directadmin's... debug mode. The same text you can see in browser.
The second output that's Domain's apache/nginx logs from one of my servers.
Tested with two domains on nginx+apache server.
p.s. Other server is fine.
