DirectAdmin 1.55.0 RC1
DirectAdmin Support
Administrator
Staff member
We're pleased to announce the Release Candidate for DirectAdmin 1.55.0.
Version: 1.55.0 RC1
The full list of changes can be found here:
https://www.directadmin.com/versions.php?version=1.550
This is a major release with many new features and many bugfixes.
Some of notable items:
Changes
Features
Bug-fixes
Current release date set for December 6th, 2018. This may change if issues are found.
To test these changes, please install the latest pre-release binaries:
https://help.directadmin.com/item.php?id=408
If you find any issues with the changes in 1.55.0 RC1, please report them here on the forum, to avoid any duplicate emails.
I'm missing a fix I reported via the ticket system.
Which was when from a admin or reseller package for example the SSH access was removed, the option was not removed on user level for the customers. So when you checked a customer they could still have ssh in the options, while it was not present anymore in their package.
Or was this already fixed in the previous release? Not sure anymore.
Regarding the feature "Domain Setup: Force SSL redirect" at https://www.directadmin.com/features.php?id=2221 - would it be possible for you to also add this checkbox at the domain SSL page at /CMD_SSL?domain=domain.com ? I think it would be logically and user friendly to have it there, and that when a user install a SSL certificate on a domain, after the domain is installed, on the same page it would then be a checkbox to "Force SSL with https redirect". Then the user can do it all on one place, instad of navigate back to domain administration and do it there.
Eh no, I would not advise to put a button for the user there. Beacuse in that case you force them to use https://hostname.yourserver.com:2222 which some of us don't like. And it also needs some explaining to the users as they see they suddenly land somewhere else.
It would be a lot user friedly'er to change something so it would become http://www.userdomain.com:2222 which is more user friendly and easier for the user to remember because he does not see another name in the url bar. So more like cpanel has it in fact.
We only offer DirectAdmin at https://hostname.yourserver.com:2222 , however then I will still ask DirectAdmin to add the feature/checkbox at /CMD_SSL?domain=domain.com but not enable it as default, and only offer it with a directadmin.conf option to enable it. Consider it a feature request from me.
I see it there:
[ ] Force SSL with https redirect
on a domain setup page. For all existing domains.
I see it there:
Yes, but what my feature request is, is to also have the checkbox on the SSL page at /CMD_SSL?domain=domain.com - so that when a customer install a SSL certificate and click back button, then they can easy click on "Force SSL with https redirect" right after they have installed the certificate, without the need of going to the domain setup page. Only a feature request, and it does not have to be default enabled, but with a option in directadmin.conf
@ditto: I like your suggestion made in your reply in message #5, which would acceptable for everyone. If possible ofcourse.
I don't use RC's, but I assume the force to ssl redirect only shows when there's a certificate for the domain? Otherwise it's pointless, as it'll use the hostname certificate.
The "Force SSL Redirect" button has been added to the "SSL Certificates" page.
Pre-release binaries updated.
I just have upgraded to 1.55.0 (final version)
I want to use the 2 new features.
- force_ssl for easy apache/nginx redirection to https (TEMPLATES)(SKINS)
- Domain Pointers: option to not redirect to www (SKINS)(TEMPLATES)
Redirection to https is working.
However redirection from domain.com to www.domain.com is not working. Although I have pointers www redirect checked on my domain.
Should I enable it somewhere else?
Anyone that can help?
# Auto generated apache config file by DirectAdmin version 1.55.0
# Modifying this file is not recommended as any changes you make will be
# overwritten when the user makes any changes to their website
# For global config changes that affect all Users, see this guide:
# http://help.directadmin.com/item.php?id=2
# For local config changes that only affect one User, see this guide:
# http://help.directadmin.com/item.php?id=3
<Directory "/home/user/public_html">
	<IfModule mod_fcgid.c>
		SuexecUserGroup user user
	</IfModule>
</Directory>
<VirtualHost 00.00.00.00:80 >
	ServerName www.domain.be
	ServerAlias www.domain.be domain.be
	ServerAdmin [email protected]
	DocumentRoot /home/user/domains/domain.be/public_html
	UseCanonicalName OFF
	SetEnvIf X-Forwarded-Proto "https" HTTPS=on
	RewriteEngine On
	RewriteCond %{HTTPS} !=on
	RewriteCond %{HTTP:X-Forwarded-Proto} !https [NC]
	RewriteRule ^ https://%{HTTP_HOST}%{REQUEST_URI} [L,R=301]
	<IfModule !mod_ruid2.c>
	</IfModule>
	CustomLog /var/log/httpd/domains/domain.be.bytes bytes
	CustomLog /var/log/httpd/domains/domain.be.log combined
	ErrorLog /var/log/httpd/domains/domain.be.error.log
	<filesMatch ".(css|jpg|jpeg|png|gif|js|ico)$">
	Header set Cache-Control "max-age=15552000, public"
	</filesMatch>
	<Directory /home/user/domains/domain.be/public_html>
		AllowOverride AuthConfig FileInfo Indexes Limit Options=Indexes,IncludesNOEXEC,MultiViews,SymLinksIfOwnerMatch,FollowSymLinks,None
		Options -ExecCGI -Includes +IncludesNOEXEC
	</Directory>
</VirtualHost>
<VirtualHost 400.00.00.00:443 >
	SSLEngine on
	SSLCertificateFile /usr/local/directadmin/data/users/user/domains/domain.be.cert.combined
	SSLCertificateKeyFile /usr/local/directadmin/data/users/user/domains/domain.be.key
	SSLCACertificateFile /usr/local/directadmin/data/users/user/domains/domain.be.cacert
	Header always set Strict-Transport-Security "max-age=63072000; includeSubDomains; preload"
	DocumentRoot /home/users/domains/domain.be/private_html
	</IfModule>
	</filesMatch>
	<Directory /home/user/domains/domain.be/private_html>
	</Directory>
</VirtualHost>
If mod_rewrite rules under <VirtualHost ...> does not work as intended, then I guess, there are other mod_rewrite rules which have a precedence over them.
Try and see whether or not renaming .htaccess to .htaccess~off in public_html helps.
It's happening on all my domains. I checked in one domain there was an empty .htaccess file.
I even deleted it, but still domain.com does not forward to www.domain.com
EDIT: However I cannot find any mod rewrite rules on the virtual zone files that is transferring domain.com to www.domain.com
I used to have this in the past
        <IfModule mod_rewrite.c>
        RewriteEngine On
        RewriteCond %{HTTP_HOST} !^www\. [NC]
        RewriteRule (.*) https://www.%{HTTP_HOST}%{REQUEST_URI} [L,R=301]
        </IfModule>
But I should not use that anymore because of the new features in Directadmin 1.55
I see a confusion arose.
The feature
is about pointers only, not about domains with sites.
With this feature you can have either
pointer.com redirected to www.maindomain.com, or
pointer.com redirected to maindomain.com
It's not about redirecting maindomain.com <-> www.maindomain.com
Ok thanks for the explaination. I was confused indeed.
Maybe should be nice feature in future release to have redirection for domain.com to www.domain.com or the other way.
Same as you have for SSL redirect.
So for now I still need this in my Virtual Zone file for SSL connections:
        RewriteEngine On
        </IfModule>
Hello, is it DA v1.55 final has been released? I don't see the announcement on the forum but got the upgrade notification on my servers.
