DirectAdmin 1.59.0 Release Candidate
DirectAdmin Support
Administrator
Staff member
We're very pleased to announce the first release candidate for DirectAdmin 1.59.0:
Version: 1.59.0 RC2
This has new features and bugfixes, all changes are listed here:
https://www.directadmin.com/versions.php?version=1.590000
New Features:
Bugfixes:
End-Of-Life:
plus other less significant changes, listed in the versions system.
As usual, the binaries are currently available in the pre-release area:
https://help.directadmin.com/item.php?id=408
If you have any issues, please report them here to avoid duplicates emails/tickets.
I love the new template in this build, it's super fast and looks awesome.
However there are just a few issues noticed
1. Roundcube Login gives an error "Invalid token"
2. From Mysql management, clicking login redirects to an empty page
We've released RC2 of DirectAdmin with a few fixes and minor changes.
If you're having any issues (eg: with tokens), please update to the most recent release candidate.
Also ensure you re-install roundcube and phpMyAdmin to ensure the latest direct_login module is installed if you've enabled the one-click SSO logins for webmail/PMA:
./build roundcube
./build phpmyadmin
at the time of this writing, you'd be looking for
roundcube_direct_login-0.5.tar.gz
phpMyAdmin_direct_login-0.3.tar.gz
going by when you re-install them.
./build roundcube
./build phpmyadmin
We still have issue with invalid tokens after update DA 1.59 Release john
Use Latest DA + Evolution skin
Just done the update and have to say it is a great update!
I really like he SSO and also the SMTP in/out log.... It could be a bit easier to read thou! It would be great to have something like this in the admin area where we can see per account usage / then show the account in and out in detail.
Update to 1.59.3 but in the reseller level the search domain bar continue to not work (only the user search work fine)
Please check this thread:
https://forum.directadmin.com/showthread.php?t=59281&p=303471#post303471
There are 2 bugs at play, but could be just 1.
For very high usage like yours it's more likely a combination of both an older OLS bug which logged bad data, plus a DA fix which is only now showing the missing BW usage for deleted Users.
If you never used OpenLiteSpeed, then it's more likely a smaller increase in Reseller bandwidth, in which case that's likely the correct usage as a result of the fix, only now showing up from the DA fix for an older bug where it wasn't being shown. 1.59.4 will be released shortly which now includes a field to clarify where the extra reserller bandwidth is coming from, when an Admin views a Reseller.
For the Reseller search bar, I'm not able to reproduce it for either Evo nor Enhanced.. so not sure.
If you're using any other skin, it would need to be updated, since the List Users page has columns moved around, so the search form needs to be adjust to search on the correct column.
