After updating to custombuild 2.0.0 (rev: 2496) and DirectAdmin V1.61.0, Bind doesn't work anymore
I failed in my research...
Any idea ?
~# service bind9 status
~# /etc/init.d/bind9 restart
~# systemctl status bind9.service
~# nano /var/log/messages
Iptable and CSF
Ip's are unknown and not blocked
But Bind seems working in the same time !!!!!!
~# dig @localhost 91.121.37.27
Any idea ?
bind9.service - BIND Domain Name Server
Loaded: loaded (/lib/systemd/system/bind9.service; disabled; vendor preset: enabled)
Active: inactive (dead)
Docs: man:named(8)
[....] Restarting bind9 (via systemctl): bind9.serviceJob for bind9.service failed because the control process exited with error code.
See "systemctl status bind9.service" and "journalctl -xe" for details.
failed!
Active: failed (Result: exit-code) since Sun 2020-05-24 05:21:01 CEST; 21min ago
Docs: man:named(8)
Process: 27770 ExecStart=/usr/sbin/named $OPTIONS (code=exited, status=1/FAILURE)
Tasks: 0 (limit: 2319)
Memory: 396.0K
CGroup: /system.slice/bind9.service
May 24 05:21:01 vps123456.ovh.net named[27771]: listening on IPv4 interface eth0, 91.121.37.27#53
May 24 05:21:01 vps123456.ovh.net named[27771]: binding TCP socket: address in use
May 24 05:21:01 vps123456.ovh.net named[27771]: listening on IPv4 interface eth0, 91.121.45.207#53
May 24 05:21:01 vps123456.ovh.net named[27771]: unable to listen on any configured interfaces
May 24 05:21:01 vps123456.ovh.net named[27771]: loading configuration: failure
May 24 05:21:01 vps123456.ovh.net named[27771]: exiting (due to fatal error)
May 24 05:21:01 vps123456.ovh.net systemd[1]: bind9.service: Control process exited, code=exited, status=1/FAILURE
May 24 05:21:01 vps123456.ovh.net systemd[1]: bind9.service: Failed with result 'exit-code'.
May 24 05:21:01 vps123456.ovh.net systemd[1]: Failed to start BIND Domain Name Server.
May 24 03:33:00 vps123456 kernel: [ 1504.328879] Firewall: *ICMP_IN Blocked* IN=eth0 OUT= MAC=fa:16:3e:08:e5:ba:02:fa:6a:50:b3:70:08:00 SRC=92.222.186.1 DST=87.98.169.140 LEN=32 TOS=0x08 PREC=0x00 TTL=7 ID=1 DF PROTO=ICMP TYPE=8 CODE=0 ID=47744 SEQ=1
May 24 03:33:00 vps123456 kernel: [ 1504.695458] Firewall: *TCP_IN Blocked* IN=eth0 OUT= MAC=fa:16:3e:08:e5:ba:02:fa:6a:50:b3:70:08:00 SRC=213.217.0.101 DST=51.38.215.43 LEN=40 TOS=0x00 PREC=0x00 TTL=241 ID=31311 PROTO=TCP SPT=42185 DPT=5381 WINDOW=1024 RES=0x00 SYN URGP=0
May 24 03:33:01 vps123456 kernel: [ 1505.179205] Firewall: *ICMP_IN Blocked* IN=eth0 OUT= MAC=fa:16:3e:08:e5:ba:02:fa:6a:50:b3:70:08:00 SRC=92.222.185.1 DST=91.121.45.207 LEN=32 TOS=0x08 PREC=0x00 TTL=5 ID=1 DF PROTO=ICMP TYPE=8 CODE=0 ID=39936 SEQ=1
Iptable and CSF
; <<>> DiG 9.11.5-P4-5.1+deb10u1-Debian <<>> @localhost 91.121.37.27
; (2 servers found)
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: REFUSED, id: 55666
;; flags: qr rd; QUERY: 1, ANSWER: 0, AUTHORITY: 0, ADDITIONAL: 1
;; WARNING: recursion requested but not available
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 4096
; COOKIE: 49bbdff1ebd4a0ec6cc0b5cc5ec9ee42b0e1fa583c7d7a2a (good)
;; QUESTION SECTION:
;91.121.37.27. IN A
;; Query time: 4 msec
;; SERVER: ::1#53(::1)
;; WHEN: Sun May 24 05:47:14 CEST 2020
;; MSG SIZE rcvd: 69
