PHP.ini Selector add-on for Users
Cyprian
To make it easier for users to change PHP.ini configuration.
I've seen something like this for Cloud Linux but I don't use it.
Is there any standalone solution?
Maybe someone used, met with such?
PHP settings editor comes by default in user-level, isn't it what you're looking for?
maybe he meant
php.ini config group
Example
Group1:
Memory:256;
post_max_size = 8Mb
upload_max_filesize = 16Mb
Group2:
Memory:512;
post_max_size = 16Mb
upload_max_filesize = 32Mb
that have <select> Box, to apply one change click
you can future request here
I know I can edit the text file:
/domains/domain.com/php.ini
I am looking for Add-on that allows the user to change settings
directly from the Panel using the form.
Solution similar to the ones in the screenshot.
You'd need to switch the theme to Evolution to see it in GUI.
I don't see the features like above in Evolution theme.
Unless I need to reconfigure the panel something?
Or maybe I need to install an additional add-on?
It's there in user level. Maybe you have customized the menu in "Customize Evolution Skin"? Is that the latest version of DIrectAdmin?
I have only a drop downfield to select php versions, and then - nothing from the above php selector with extensions tab. Under which URL should this be?
I was happy looking at the awesome extension selector in DA (excited with the new release) until someone told me this is for cloudlinux selector.
I have the same GUI as the first attachment.
So, there is no PHP GUI for DA if we don't use Cloud Linux?
Thanks.
I mean any kind of GUI PHP extension selector for the user.
I can only see this 2 options in post #12, first image
