I cant receive email
104229
I cant receive email from gmail and some other provider, if anyone send email from their gmail to show sent but i dont get them
try this
If the server is new you mostlikly are not trusted as a sender
i dont understand someone as me to create new thread and when i did someone else is saying why am i doing double the thread What should i do?
server is not new, i can send email but i cant receive email, what should i do
Also, have them send you a mail and then tail your logfiles like:
tail -f /var/log/exim/mainlog
and
tail -f /var/log/exim/rejectlog
Then you can see what is happening to the mail.
U can send, but not receive? Are you sure port 25 is open? Are you sure your provider allows port 25 to be open?
So it more than 3 months old?
Did you see if you are on any blocklist like in the link i sent?
yes server is more than 3 months old
and yes i check there is no error just a warning of Name Servers are on the Same Subnet
2022-03-04 08:14:49 login authenticator failed for (localhost) [5.34.207.81]: 535 Incorrect authentication data (set_id=[email protected])
2022-03-04 08:14:51 login authenticator failed for (localhost) [5.34.207.97]: 535 Incorrect authentication data (set_id=route)
2022-03-04 08:14:52 login authenticator failed for (localhost) [5.34.207.81]: 535 Incorrect authentication data (set_id=[email protected])
2022-03-04 08:17:41 login authenticator failed for (localhost) [5.34.207.81]: 535 Incorrect authentication data (set_id=[email protected])
2022-03-04 08:17:42 login authenticator failed for (localhost) [5.34.207.97]: 535 Incorrect authentication data (set_id=public_key)
2022-03-04 08:17:42 login authenticator failed for (localhost) [5.34.207.81]: 535 Incorrect authentication data (set_id=[email protected])
2022-03-04 08:17:45 login authenticator failed for (User) [87.246.7.246]: 535 Incorrect authentication data (set_id=[email protected])
2022-03-04 08:17:45 login authenticator failed for (localhost) [5.34.207.81]: 535 Incorrect authentication data (set_id=[email protected])
2022-03-04 08:17:49 login authenticator failed for (localhost) [5.34.207.97]: 535 Incorrect authentication data (set_id=novo)
2022-03-04 08:17:50 login authenticator failed for (localhost) [5.34.207.81]: 535 Incorrect authentication data (set_id=[email protected])
2022-03-04 08:17:52 login authenticator failed for (localhost) [5.34.207.97]: 535 Incorrect authentication data (set_id=client2)
2022-03-04 08:17:52 login authenticator failed for (localhost) [5.34.207.81]: 535 Incorrect authentication data (set_id=[email protected])
2022-03-04 08:17:56 login authenticator failed for (localhost) [5.34.20
when i send an email from [email protected] to [email protected]
then email got failed and it gives me this error
TLS Negotiation failed: FAILED_PRECONDITION: starttls error (71): 24918174613512:error:10000458:SSL routines:OPENSSL_internal:TLSV1_ALERT_UNRECOGNIZED_NAME:third_party/openssl/boringssl/src/ssl/tls_record.cc:594:SSL alert number 112
Your certificate seems perfect, got an A status on ssllabs, but did you install something from boringssl?
Otherwise it might be something on the sending party. We don't use boringssl, but Google might.
I checked the reporsitory of boringssl here:
and error 112 says it's this:
SSL,307,NO_APPLICATION_PROTOCOL
It's confusing to me as an SSL 307 might also point to a redirection fail somehow.
If you did not install anything from boringSSL, I don't know.
1.) You did not install anything from boringSSL?
2.) What OS are you on and which version?
3.) Which DA version?
Also, visit mail-tester.com and follow instructions there and see if you get at least a 9/10 score.
From the logs:
this means user and/or pass is invalid. I don't see anything about Gmail here tho.
i have not installed anything from Boring SSL
Ubuntu 20.04
DirectAdmin v.1.63.7
Thanks guys for helping me out but the issue is resolve now , here is quick tip for all of you who is having similar problem
i goto the custom build from admin
and i updated the exim and lets encrypt after update everything works ok
