DirectAdmin 1.644 has been released
fln
Administrator
Staff member
Hi everyone!
We are happy to announce the release of DirectAdmin 1.644.
This is a maintenance release focusing on fixing stuff and continuing with our planned changes. There is a big change in Evolution login page inner workings, but they are not visible.
Release Changelog can can be found here:
DirectAdmin 1.644
fln
Who's have facing with error "No valid session key" when open some page. eg plugin csf firewall (/admin/plugins/csf?path=index.html). Please clear cache and re-open your browser. Issued will solved. Thanks
OS:Rocky Linux 8
hi, upgrade Lua 5.3.5 to Lua 5.4.4 fail.
Executing /usr/local/directadmin/plugins/custombuild/admin/build lua...
#=#=# ############# 18.2% ############################################# 63.6% ########################################################## 81.7% ######################################################################## 100.0%
Found /usr/local/directadmin/custombuild/lua-5.4.4.tar.gz
Extracting ...
Done.
patching file src/Makefile
Hunk #2 FAILED at 8.
Hunk #3 succeeded at 45 (offset 1 line).
Hunk #4 succeeded at 62 (offset 1 line).
1 out of 4 hunks FAILED -- saving rejects to file src/Makefile.rej
patching file Makefile
Hunk #1 succeeded at 38 with fuzz 2.
Hunk #2 FAILED at 56.
Hunk #3 succeeded at 64 (offset -3 lines).
1 out of 3 hunks FAILED -- saving rejects to file Makefile.rej
Installing lua...
make[1]: Entering directory '/usr/local/directadmin/custombuild/lua-5.4.4/src'
make all SYSCFLAGS="-DLUA_USE_LINUX" SYSLIBS="-Wl,-E -ldl"
make[2]: Entering directory '/usr/local/directadmin/custombuild/lua-5.4.4/src'
gcc -std=gnu99 -O2 -Wall -Wextra -DLUA_COMPAT_5_3 -DLUA_USE_LINUX -c -o lapi.o lapi.c
gcc -std=gnu99 -O2 -Wall -Wextra -DLUA_COMPAT_5_3 -DLUA_USE_LINUX -c lcode.c
gcc -std=gnu99 -O2 -Wall -Wextra -DLUA_COMPAT_5_3 -DLUA_USE_LINUX -c -o lctype.o lctype.c
gcc -std=gnu99 -O2 -Wall -Wextra -DLUA_COMPAT_5_3 -DLUA_USE_LINUX -c -o ldebug.o ldebug.c
gcc -std=gnu99 -O2 -Wall -Wextra -DLUA_COMPAT_5_3 -DLUA_USE_LINUX -c -o ldo.o ldo.c
gcc -std=gnu99 -O2 -Wall -Wextra -DLUA_COMPAT_5_3 -DLUA_USE_LINUX -c -o ldump.o ldump.c
gcc -std=gnu99 -O2 -Wall -Wextra -DLUA_COMPAT_5_3 -DLUA_USE_LINUX -c -o lfunc.o lfunc.c
gcc -std=gnu99 -O2 -Wall -Wextra -DLUA_COMPAT_5_3 -DLUA_USE_LINUX -c -o lgc.o lgc.c
gcc -std=gnu99 -O2 -Wall -Wextra -DLUA_COMPAT_5_3 -DLUA_USE_LINUX -c llex.c
gcc -std=gnu99 -O2 -Wall -Wextra -DLUA_COMPAT_5_3 -DLUA_USE_LINUX -c -o lmem.o lmem.c
gcc -std=gnu99 -O2 -Wall -Wextra -DLUA_COMPAT_5_3 -DLUA_USE_LINUX -c -o lobject.o lobject.c
gcc -std=gnu99 -O2 -Wall -Wextra -DLUA_COMPAT_5_3 -DLUA_USE_LINUX -c -o lopcodes.o lopcodes.c
gcc -std=gnu99 -O2 -Wall -Wextra -DLUA_COMPAT_5_3 -DLUA_USE_LINUX -c lparser.c
gcc -std=gnu99 -O2 -Wall -Wextra -DLUA_COMPAT_5_3 -DLUA_USE_LINUX -c -o lstate.o lstate.c
gcc -std=gnu99 -O2 -Wall -Wextra -DLUA_COMPAT_5_3 -DLUA_USE_LINUX -c -o lstring.o lstring.c
gcc -std=gnu99 -O2 -Wall -Wextra -DLUA_COMPAT_5_3 -DLUA_USE_LINUX -c -o ltable.o ltable.c
gcc -std=gnu99 -O2 -Wall -Wextra -DLUA_COMPAT_5_3 -DLUA_USE_LINUX -c -o ltm.o ltm.c
gcc -std=gnu99 -O2 -Wall -Wextra -DLUA_COMPAT_5_3 -DLUA_USE_LINUX -c -o lundump.o lundump.c
gcc -std=gnu99 -O2 -Wall -Wextra -DLUA_COMPAT_5_3 -DLUA_USE_LINUX -c -o lvm.o lvm.c
gcc -std=gnu99 -O2 -Wall -Wextra -DLUA_COMPAT_5_3 -DLUA_USE_LINUX -c -o lzio.o lzio.c
gcc -std=gnu99 -O2 -Wall -Wextra -DLUA_COMPAT_5_3 -DLUA_USE_LINUX -c -o lauxlib.o lauxlib.c
gcc -std=gnu99 -O2 -Wall -Wextra -DLUA_COMPAT_5_3 -DLUA_USE_LINUX -c -o lbaselib.o lbaselib.c
gcc -std=gnu99 -O2 -Wall -Wextra -DLUA_COMPAT_5_3 -DLUA_USE_LINUX -c -o lcorolib.o lcorolib.c
gcc -std=gnu99 -O2 -Wall -Wextra -DLUA_COMPAT_5_3 -DLUA_USE_LINUX -c -o ldblib.o ldblib.c
gcc -std=gnu99 -O2 -Wall -Wextra -DLUA_COMPAT_5_3 -DLUA_USE_LINUX -c -o liolib.o liolib.c
gcc -std=gnu99 -O2 -Wall -Wextra -DLUA_COMPAT_5_3 -DLUA_USE_LINUX -c -o lmathlib.o lmathlib.c
gcc -std=gnu99 -O2 -Wall -Wextra -DLUA_COMPAT_5_3 -DLUA_USE_LINUX -c -o loadlib.o loadlib.c
gcc -std=gnu99 -O2 -Wall -Wextra -DLUA_COMPAT_5_3 -DLUA_USE_LINUX -c -o loslib.o loslib.c
gcc -std=gnu99 -O2 -Wall -Wextra -DLUA_COMPAT_5_3 -DLUA_USE_LINUX -c -o lstrlib.o lstrlib.c
gcc -std=gnu99 -O2 -Wall -Wextra -DLUA_COMPAT_5_3 -DLUA_USE_LINUX -c -o ltablib.o ltablib.c
gcc -std=gnu99 -O2 -Wall -Wextra -DLUA_COMPAT_5_3 -DLUA_USE_LINUX -c -o lutf8lib.o lutf8lib.c
gcc -std=gnu99 -O2 -Wall -Wextra -DLUA_COMPAT_5_3 -DLUA_USE_LINUX -c -o linit.o linit.c
ar rcu liblua.a lapi.o lcode.o lctype.o ldebug.o ldo.o ldump.o lfunc.o lgc.o llex.o lmem.o lobject.o lopcodes.o lparser.o lstate.o lstring.o ltable.o ltm.o lundump.o lvm.o lzio.o lauxlib.o lbaselib.o lcorolib.o ldblib.o liolib.o lmathlib.o loadlib.o loslib.o lstrlib.o ltablib.o lutf8lib.o linit.o
ranlib liblua.a
gcc -std=gnu99 -O2 -Wall -Wextra -DLUA_COMPAT_5_3 -DLUA_USE_LINUX -c -o lua.o lua.c
gcc -std=gnu99 -o lua lua.o liblua.a -lm -Wl,-E -ldl
gcc -std=gnu99 -O2 -Wall -Wextra -DLUA_COMPAT_5_3 -DLUA_USE_LINUX -c -o luac.o luac.c
gcc -std=gnu99 -o luac luac.o liblua.a -lm -Wl,-E -ldl
gcc -std=gnu99 -shared -ldl -Wl,-soname,liblua.so. -o liblua.so. lapi.o lcode.o lctype.o ldebug.o ldo.o ldump.o lfunc.o lgc.o llex.o lmem.o lobject.o lopcodes.o lparser.o lstate.o lstring.o ltable.o ltm.o lundump.o lvm.o lzio.o lauxlib.o lbaselib.o lcorolib.o ldblib.o liolib.o lmathlib.o loadlib.o loslib.o lstrlib.o ltablib.o lutf8lib.o linit.o -lm
/bin/ld: lapi.o: relocation R_X86_64_32S against internal symbol `luaT_typenames_' can not be used when making a shared object
/bin/ld: lcode.o: relocation R_X86_64_32S against internal symbol `luaP_opmodes' can not be used when making a shared object
/bin/ld: ldebug.o: relocation R_X86_64_32S against internal symbol `luaP_opmodes' can not be used when making a shared object
/bin/ld: ldo.o: relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/bin/ld: ldump.o: relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/bin/ld: lfunc.o: relocation R_X86_64_32 against `.rodata.str1.8' can not be used when making a shared object; recompile with -fPIC
/bin/ld: lgc.o: relocation R_X86_64_32S against `.rodata' can not be used when making a shared object; recompile with -fPIC
/bin/ld: llex.o: relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/bin/ld: lmem.o: relocation R_X86_64_32 against `.rodata.str1.8' can not be used when making a shared object; recompile with -fPIC
/bin/ld: lobject.o: relocation R_X86_64_32S against `.rodata' can not be used when making a shared object; recompile with -fPIC
/bin/ld: lparser.o: relocation R_X86_64_32 against `.rodata.str1.8' can not be used when making a shared object; recompile with -fPIC
/bin/ld: lstate.o: relocation R_X86_64_32S against symbol `lua_newstate' can not be used when making a shared object; recompile with -fPIC
/bin/ld: lstring.o: relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/bin/ld: ltable.o: relocation R_X86_64_32S against `.rodata' can not be used when making a shared object; recompile with -fPIC
/bin/ld: ltm.o: relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/bin/ld: lundump.o: relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/bin/ld: lvm.o: relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/bin/ld: lauxlib.o: relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/bin/ld: lbaselib.o: relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/bin/ld: lcorolib.o: relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/bin/ld: ldblib.o: relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/bin/ld: liolib.o: relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/bin/ld: lmathlib.o: relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/bin/ld: loadlib.o: relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/bin/ld: loslib.o: relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/bin/ld: lstrlib.o: relocation R_X86_64_32 against `.rodata.str1.8' can not be used when making a shared object; recompile with -fPIC
/bin/ld: ltablib.o: relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/bin/ld: lutf8lib.o: relocation R_X86_64_32S against `.rodata' can not be used when making a shared object; recompile with -fPIC
/bin/ld: linit.o: relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
/bin/ld: final link failed: Nonrepresentable section on output
collect2: error: ld returned 1 exit status
make[2]: *** [Makefile:66: liblua.so] Error 1
make[2]: Leaving directory '/usr/local/directadmin/custombuild/lua-5.4.4/src'
make[1]: Leaving directory '/usr/local/directadmin/custombuild/lua-5.4.4/src'
make[1]: *** [Makefile:130: linux-noreadline] Error 2
make: *** [Makefile:59: linux] Error 2
*** The make has failed. Exiting...
Done!
In regard to "Deprecation of login_pre.sh, all_pre.sh, all_post.sh hooks":
  1. On https://help.directadmin.com/?query=all_pre.sh there is link to "I only want my IP to be able to execute Admin level commands", which does not seem to exists anymore. How that functionality can be restored without all_pre.sh? In short, how to force new /api/... requests for admin users to be made only from VPN network?
  2. CMD_MODIFY_USER multi_ip hooks also has to use all_post.sh: https://forum.directadmin.com/threads/no-hooks-for-additional-ips.66808/
OS:Rocky Linux 8
Extracting ...
Done.
Installing lua...
ranlib liblua.a
Done!
DirectAdmin alpha branch has an update which solves the issue. Thank you for the report.
Alma Linux 8.6
Upgrade pure-ftpd from 1.0.49 to 1.0.51 failed
EDIT: On CentOS 7.9 and CentOS 8.6 it worked so I guess it's something with Alma Linux (even if it's also CentOS xD)
Bash:
     Executing /usr/local/directadmin/plugins/custombuild/admin/build pureftpd...
    ######## 12.1% ######################################################################## 100.0%
    Found /usr/local/directadmin/custombuild/pure-ftpd-1.0.51.tar.gz
    Extracting /usr/local/directadmin/custombuild/pure-ftpd-1.0.51.tar.gz...
    patching file src/tls.c
    Hunk #1 succeeded at 159 (offset 21 lines).
    Configuring pure-ftpd-1.0.51...
    /usr/local/directadmin/custombuild/configure/pureftpd/configure.pureftpd: line 3: ./configure: No such file or directory
    Done. Making pure-ftpd-1.0.51...
    Trying to make Pure-FTPd...
    make: *** No targets specified and no makefile found. Stop.
    Done!
What's your download server? Try:
/usr/local/directadmin/custombuild/build set_fastest
Is files-fr.directadmin.com still ok to use?
Anyone having problems with an empty cronjob page after the upgrade to v1.644?
Thanks @xyntanl, create new cron-job action indeed shows an empty page, will release a hot-fix for it soon.
When we try to access CSF or CMQ it gives error as:
Security Error: No valid session key
Information saved to [/var/lib/csf/da1666093632.error]
We logout from panel and access again without any issue.
Thanks,
Melih
same error more than 2 years, first we went to ssh and removing problem session key, then we find out that logout/login solves problem - and do this still each time. Error appears each 10-20 accesses to CSF so not big problem.
Most of the time when logging in with mobile we get this error, but accessing from pc never have this tissue
We also had a few servers where pure-ftpd-1.0.51 failed to start after the update because pure-ftpd.pem was missing:
Oct 18 12:58:20 server pure-ftpd: (?@?) [ERROR] Sorry, but that file doesn't exist: [/etc/pure-ftpd.pem]
I also see that versions.txt on files.directadmin.com still lists older versions, see attached screenshot.
A new DA build 7258c4dea64c9f5b910f80a85e756146a02c728e in current is released, with the following hot-fixes:
  • Lua version reverted to 5.3.5
  • Evolution new cron job page fixed
Hello;
I found two problems in the new version of DirectAdmin:
1) When trying to change the user's password, receive the following error message:
The referer request set (reseller/users/<USER>/view/domains) is not in the allowed list: CMD_API_USER_PASSWD, CMD_USER_PASSWD, HTM_USER_PASSWD, admin/passwords, admin/users, reseller/passwords
2) System notifications take time to update. In the example below, even though the message has already been read or deleted, the system still says that it is pending reading (1).
Only when refreshing the browser page (F5), the notification disappears and goes back to empty (0).
  • Like
Reactions: fln
