MisterM
- Jul 31, 2022
Hello
I am on a case, that I have never seen, surely all the team of DA would answer me.
I am no longer able to make a backup, the task goes into error when it tries to connect with the command "mysqldump".
But on the other hand, I know how to connect as root and the password used is correct from the setup.txt file of the installation...
Mz
Error while backing up database xxxx_xxxx
Error while backing up database xxxx_xxxx The sql file is 0 bytes in size:
/home/tmp/......
mysqldump error output: mysqldump: Got error: 1045: "Access denied for user 'root'@'localhost' (using password: NO)" when trying to connect
Mz
